Error code 11 on electrolux wave dishwasher
Had tech out to fix error code 01. - leak detector. Took over 4 hrs. After he left tried washer. Now have error code 11 - drain valve. They want $300+ to come out again to repair. This was purchased in 2008
    Problem Solver:
  • 6 Answers
Success....Error 11 on Electrolux dishwasher?
I have an Electrolux EWDW 6505 which in the start of a wash cycle would start beeping and Error code 11 would display.
The problem: Drain Valve (Small copper lever switch inside)
Solution 1.
1. Kill breaker to dish washer.
2. Pull dish washer out from under counter. (If you open door, usually held in by 2 screws above door that are screwed in under counter top.
3. Tip washer onto its back side.
4. Remove ss front plate below door(Held in with 2 screws).
5. Remove white cover plate from bottom of dish washer (held in by 3 Phillips screws)(TO REMOVE - Pull from bottom front of dish washer then slide towards back of dishwasher).
If the washer is laying on its back, the drain valve is located at the bottom left side of the machine (Closest to the floor).
6. REMOVE THE DRAIN VALVE -
A. Remove the electrical connection to the Drain Valve by pulling
it out from plug like harness socket.
B. There are two star (T-20) head screws holding the drain valve
on. Remove them from the bottom and pull the pump down
and away from the Dishwasher to remove it.
C. There are two hoses connected to the drain valve.
One is held on by a metal screw down clamp fastener.
(just turn the screw counter clockwise till lose then slide hose
off.)
The other is held on by a spring band type fastener.
(Just compress the ends together with pliers and slide off.
7. SEPARATE THE DRAIN VALVE-
If you look at the valve, the top is white and the bottom is
black. There are white tab like structures extending over the
black part of the unit. This is where you want to separate the
unit very carefully. If you bend them too much they will
snap off or crack.
You want to easily and Gently lift and
wiggle them away from the black hook like stops. The unit will
then begin to separate. BE CAREFUL, THERE ARE 3
PIECES TO THIS HOUSING.
A. Remove the white part and set it aside.
B. Look at the black side under the housing. Here is where
you will find the PROBLEM
. There is a blue lever that sits in a stem under a copper arm. When the DRAIN VALVE rotates in normal operation it presses on the blue lever causing it to press on the copper arm, which makes contact with the other copper side and closes the circuit. As the Drain valve continues to rotate, it releases the blue lever WHICH SHOULD SPRING BACK AND OPEN THE CIRCUIT AGAIN.
NOTE: (Try not to separate the two black pieces while doing this or you will see the gears maybe pop out and two copper springs and motor. NOT A BIG DEAL IF IT HAPPENS. the 3 gears will fit together on their stems, the springs both slide one into each hole, the botor goes on top and the two arms come in contact with the springs)
C. THE FIX - LOOK at the blue lever. Right above it you will see a copper arm. Touch the Right side of the arm (where it is connected) with your finger and pull it down in the direction of the blue lever (ever so slightly just to give it its springiness back. so now if you emulate pushing up on the blue lever and release it, the copper arm should make contact with the other copper side, then, spring back on its own. (IT IS NOT FIXED UNTIL IT SPRINGS BACK ON ITS OWN) so adjust the copper arm accordingly.
REVERSE steps above to reassemble the washer.
GOOD LUCK!
Solution 2. Spend $55-75 for Frigidaire Factory Part #154622001 Only $51.52
Posted on Aug 08, 2014
  • Official Brand Answer
  • 4,342 Answers
Hello - Typically error code E11 indications that there is an issue with the drain valve, possibly the main control board is timing out before receiving status of drain valve. I strongly recommend contacting the technician that repaired your unit previously to check the wiring between the main control board and drain valve. Some certified technicians warranty their labor and part for 30 days.
Posted on Nov 05, 2012
reg501
  • 413 Answers
SOURCE: F2 error code on my Kenmore Elite HE3 washer
Based upon your description, the drain pump has either failed or the pump filter has become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) BE READY TO CATCH LOTS OF WATER. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
If you need further assistance, let me know
Regards,
reg501
Posted on Jul 04, 2008
Depending on how fritzed your drain pump is this may or may not work. I've been using HE detergent because it is supposed to cause fewer suds. However, apparently is causing more suds than needed. I need to use only a couple tablespoons? If your clothes are not dirty enough for the soap to grab onto then extra suds are the result. The repair guy said we had an excessive amount of suds in the system and this affects the sensor and causes the drain pump to run and run and run until it shuts off from overheating. This is why we get the F2 and/or suds error code. He said once a month run the machine on the hottest water cycle with a cup of bleach (no clothes). This will clear out any suds build-up and is cheaper than Afresh which works, too, (but smells cleaner than bleach). After sitting for a day our pump started working again (yay!) It also stopped making the horrible loud sound. So glad I do not have to replace the pump!! yet...(knock on wood!).
Posted on May 13, 2009
SOURCE: Electrolux EWF 1087 error code E60
I see many posts about Error Codes that aren't in the user manual. Here's what I found: Go to Google and type in "Electrolux Error Codes" and you will find the following site. It details an Electrolux Service Flash that helps with error codes that don't appear in your user manual. Good Hunting!
Customer Error Codes On All Digital Display Frontload Washers - [ Terjemahkan laman ini ]Electrolux Service Flash LN071 02.13.07. NOTE. These customer error codes are not included in the error code chart on the technical data sheet located ...
www.applianceblog.com/...electrolux/886d1212672468-frigidaire-front-load-washer-doesnt-start-frigidaireerrorcodesonalldigitaldisplayfrontloadwasher...
Posted on Dec 05, 2009
SOURCE: check hose error on electrolux wave touch washing machine
I'm sure nojallo1 has already fixed his but I just ran into the same problem and didn't find anything in my searches for a solution. The problem I had was the test cycle wasn't long enough to get hot water through my water lines so it could verify the hot and cold hoses were in the proper places. Solution: Turn the hot water on in all the sinks in your house until they have hot water running through them. This will prime your hot water line so it is full of hot water instead of cold water. Then run the install cycle again and it should be fine.
Posted on Jan 21, 2010
SOURCE: Bosch Error Code 13 Washer won't drain
First, unplug your washer. After that find the little round plate below your drum opening on the exterior of the washer. It should have a small hole in it. Use something to gently push trough this hole and twist the cover off, Inside there you will find the drain access. Be careful, if there is water in your drum this will make a mess when you unscrew the drain access. Take the usual precautions and unscrew the drain access slowly until it is off. Remove any obstructions and replace access door and cover. Clean up any mess and plug back in your washer and try again. takes about thirty minutes to an hour depending on how much water is in the drum.
Posted on Sep 21, 2010
What additional parts may fix error code 11 on electrolux EDW7505HPS0A
Good Afternoon Friend, thank you for your post!
If you are receiving an error code E11 on your Electrolux dishwasher (EDW7505HPS0A), it usually means that you are experiencing a problem with the drain valve. If you have already replaced the vale and pump, at this point, I would recommend reaching out to a professional or alternatively, visit the manufacturer website for a comprehensive listing of appliance techs in your area that can ensure the wiring between the main control and the drain valve was correctly installed. Best regards! - Z
May 20, 2014 | Electrolux Frigidaire Professional Series...
Electrolux EIDW6305GS1 will not run , keeps flashing error code 11 which indicates drain valve problem. I have replaced drain valve, wash pump, float valve and reed switch but no luck, still flashin
Hello Gene Skates - Typically error code E11 indications that there is an issue with the drain valve, possibly the main control board is timing out before receiving status of drain valve. This is typically not a DIY job and strongly recommend contacting a professional to check the wiring between the main control board and drain valve since you have already replaced the drain valve.
Jan 11, 2013 | Electrolux Frigidaire Professional Series...
Electrolux dishwasher with error code 11
Hello Jason Johnson - Typically error code E11 indications that there is an issue with the drain valve, possibly the main control board is timing out before receiving status of drain valve. I strongly recommend contacting a professional to check the wiring between the main control board and drain valve.
Dec 30, 2012 | Electrolux Frigidaire Professional Series...
I keep getting the 1E code. I go into the washer and try and rearrange the load, and want to be able to restart the load but can't do that. Typically it happens when there is only about 10min. left in...
Hello there and thank you for choosing fixya
  • The error code of "IE" signifies a water inlet error. This means that your machine is not filling to the proper water level, and may be fixed by ensuring that machine's water supply is properly connected and turned on.
  • If every thing there checks out fine then the inlet valve on the machine is faulty and needs to be replaced ...
  • drain error will result in an error code of "OE." This means that your washer is not properly draining. Ensure that your drain hose is free of kinks and clean. Your filter also must be clean
    An error code of "FE" represents an overflow error. This means that the water level is too high, and the machine will start draining itself automatically.
    An error code of "E1" represents a leakage error. This means there is a leak in one of your hose connections.
Aug 04, 2011 | LG WM-2077C Front Load Washer
I have an error 04 showing on my dishwasher, and the cycle will not run. Please help!
dryer damper problem. there is another post that will help from electrolux personnel.
Thank you in advance for allowing Electrolux to assist you in
this matter.
I apologize for the inconvenience and concerns this dishwasher unit has been causing you. Unfortunately the error "E04" code does indicate an issue with the drying damper. Now this is something that a technician would have to assess because wiring is needed to be checked.
Check wiring between Main Control Board and upper fan. If correct, replace upper fan.
If your unit is brand new it is covered under warranty and you can choose to contact your dealer for a repair technician, or visit www.electroluxappliances.com/servicelocator to find a listing in your area.
Kindest Regards,
Chris Polk
Online Outreach Representative
Electrolux Major Appliances
Er 01
Leak Detector - When water is detected under
the tub.
Er 02
Thermistor - When thermistor/turbidity module
fails
Er 03
Wash Pump - Wash pump not operating
Er 04
Drying Damper - Drying damper not operating
Er 05
Upper Fan - When in the dry cycle, the control
board does not receive proper speed feedback
from the upper fan
Er 06
Lower Fan - When in the dry cycle, the control
from the lower fan
Er 07
Drain Valve - When in the drain mode, the control
board does not receive proper position feedback
from the drain valve
Er 08
Tactile or touch switch - Control board has
verified a switch on the user interface is bad or
shorted
Er 09
Communications - Communication failure between
main user board and power supply
Er 10
Mains Relay - Failure in the mains power relay
Er 11
Drain Valve - Time out before finding a state for
the drain valve
Er 12
Drain Valve - The drain valve is running when it
should be off
Er 13
System wide - Lost control of the State Machine
Jun 23, 2011 | Electrolux Dishwashers
07f error code... duet washer W9150
Tech sheet on this model:
FH: If after 30 seconds the control does not detect water entering
machine, the valves will be turned off and the error code will be
displayed. OR If the control has turned the water valves on and after
8 minutes the flow sensor has detected 10.5 gallons of water passing
through it, but has not detected the pressure switch trip, the valves will
be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
-Make sure that both valves at the water source(s) are turned
on all the way.
-Check for plugged or kinked inlet hoses or plugged screens in
the inlet valves.
-Verify inlet valve operation.
If there is water in the unit:
-Verify drain pump operation.
-Verify that the pressure switch hose is in good condition and
properly connected to tub and pressure switch.
1. Verify there is not a siphon problem.
2. Unplug washer or disconnect power.
3. Verify wire harness connections to inlet valves,
pressure switch, drain pump, flow meter, and
Central Control Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and
measuring the resistance.
8. Verify CCU operation by running a Diagnostic test or any cycle.
F-2 Long Drain
If the drain time exceeds eight minutes, the water valves are turned off
and "F/02" is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the "Sud" error will be displayed, then four
minutes later the "F/02" error code will be displayed.
1. Check the drain hose and make sure it is not plugged
or kinked.
3. Check the electrical connections at the pump and
make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
F-5 Water temp sensor failure
If during the water heating step in the wash cycle, the water
temperature sensor (NTC) value is out of range, the "F/05" error code
will be displayed. Possible cause/proceedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Refer to the
"Water Temperature Sensor" section. Check
connections to the water temperature sensor.
3. Check resistance of heating element, if present on this
model. (abnormal = infinity)
F-06 Drive motor Tachometer error
Possible causes/proceedure:
1. Verify the shipping system including shipping bolts, spacers
and cables are removed.
3. Check wire harness connections between the drive motor and
the Motor Control Unit (MCU), and between the MCU and the
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.
6. Check the drive motor for powered rotations.
F-07 Motor control unit error
2. Check wire harness connections between the drive motor and
3. Plug in washer or reconnect power.
4. Check the MCU by looking for operations of the drive motor.
5. Check the drive motor for powered rotations.
F-09 Overflow Condition
or kinked.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Check for drain pump failure.
6. Check the inlet valve for proper shut off.
7. the pressure switch for proper operation.
F10 Motor control unit heat sink thermal trip
1. Check for proper installation, verify the unit is not located
near a source of heat and has proper ventilation.
3. Check wire harness connections to the MCU, the motor,
4. Check the drive system for any worn or failed components.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
F11 Serial communication error
Communication between the Central Control Unit (CCU) and the
Motor Control Unit (MCU) cannot be sent correctly.
Possible causes/procedure:
2. Check wire harness connections to the MCU, the motor, and
3. Check the drive system for any worn or failed components.
5. Verify CCU operation by running a Diagnostic test or any
cycle.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
MCU connectors.
F13 Dispenser circuit error
2. Check mechanical linkage from dispenser motor to the top of
the dispenser.
3. Check wire harness connections to the dispenser motor and
4. Check dispenser motor for powered rotations.
F14 The dreaded EEPROM error
The Central Control Unit (CCU) receives its data from an EEPROM
onboard the CCU. If there is an error reading this data it will cause this
error. Possible causes/proceedure:
¦ A power glitch may cause this error.
1. Unplug washer or disconnect power for two minutes.
2. Verify CCU operation by running a Diagnostic test or any
cycle.
F15 Motor control unit error
If the MCU detects multiple resets or errors during a wash cycle it will
go into this error mode. Possible causes/proceedure:
3. Check drive belt.
F21 F 22 CCU /touchpad/LED assembly unable to transmit/receive data to/from the CCU central control unit
1. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
touch-pad/LED assembly and Central Control Unit (CCU).
F du Door unlock error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to
unlock the door 6 times before displaying the error code.
¦ Door lock mechanism is broken.
¦ Door switch/lock unit failure.
1. Check door switch/lock unit for foreign objects.
3. Check wire harness connections to the door switch/lock
unit and Central Control Unit (CCU).
NOTE: The door switch/lock unit can be manually unlocked. See
"Manually Unlocking The Door Lock System".
F dl Door lock error
A Door Lock Error occurs if the door cannot be locked. It will try to lock
it six times before displaying the error code.
¦ Door lock mechanism is broken or removed from door.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door
switch/lock unit and Central Control Unit (CCU).
Sud: Suds lock (overdose of detergent detected during wash cycle)
The motor control unit senses a suds lock condition by analyzing the
current draw on the drive motor. If "Sud" is displayed a potential Suds
Lock is detected. This may signify a bad pump, an extra heavy load,
excessive detergent, or excessive suds.
¦ If too much detergent was used:
-Run the unit through a Rinse/Spin cycle.
-Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
or kinked.
6. Check drain pump.
7. Check the pressure switch.
cycle.
Tech sheet link:
https://servicematters.com/secured/docs/wiring/Tech%20Sheet%20-%208182277.pdf
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Replaced mother board due to error code c2 11 as per rheem tech department. now code 11 flashes after 3 to 4 minutes of use and unit shuts off. WHAT NOW????
Rheem, Richmond, Ruud, and Paloma are all the same manufacturer. After about 9 months, my tankless RTG-74PVN started giving me error code 11 and cold water!. I fixed it by cleaning the burner, as shown in this video:
www.howtolou.com/clean-a-burner
Dec 29, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Hotpoint WF640
the f-01 error code on your hotpoint all in 1 washer/dryer is a short circuit code for the motor. the only way to clear the code is to have a service tech come and inspect the reason for the error.
May 12, 2008 | Hotpoint Aquarius WD640 Front Load...
Error Code F-01
Hi, After about year and half Whirlpool duet sport gave F01 error code. The technician manual is located under the lower front panel. There are three possible reasons for F0: 1) EEPROM ERROOR. Unplug a washer for two minutes. Try running it again. (Did not work for me). 2) MAIN RELAYS ERROR. The tech manual suggests replacing CCU. The following is what I did and it fixed the problem, however. Unplug the washer. Remove the top cover by removing the three screws on the back. The CCU unit is in the right bottom corner if standing in front of the washer – it has a lot of wiring. Plug in the unit. While listening to the CCU start any washing cycle. After pressing START you should hear the relay to click. If it clicks twice, within a less than a second, it has a problem. Unplug the washer. Without disconnecting any wires remove the CCU cage from the washer wall. Stand now on the right hand side of the washer in such way that the CCU cage is under your left hand. Pull the right upper corner of the CCU plastic cage (it has a tab) away from you, slide the cage to the right by about an inch, and pull the entire cage away from you. Now knock on the back side of the cage 4-5 times with a bit of force (watch “Armageddon” movie for more instructions on it). Install the CCU cage back. Plug in the unit. Try some washing cycle again. If it did not help, repeat the procedure. If it did not work again, see the following. 3) PUMP DRIVE ERROR. The tech manual suggests replacing CCU.
Mar 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error code h-f
Krysil,
I have the service technician's guide to the error codes here. The code you're getting is F/H. The Explanation of this error code is "No Water Detected Entering Machine or Pressure Switch Trip Not Detected."
"If after 30 seconds, the control does not detect water entering machine, the valves will be turned off and the error code will be displayed. OR If the control has turned the water valves on and after 8 minutes the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash."
"Possible Causes / Procedure
  • If there is no water in the unit:
    - Make sure that both valves at the water source are turned on all the way.
    - Check for plugged or kinked inlet hoses or plugged screens in the inlet valves.
    - Verify inlet valve operation.
  • If there IS water in the unit:
    - verify drain pump operation
    - verify that the pressure switch hose is in good condition and properly connected to tub and pressure switch.
  1. Verify that there is not a siphon problem.
  2. Unplug the washer or disconnect power.
  3. Verify wire harness connections to inlet valves, pressure switch, drain pump, flow meter, and Central Control Unit (CCU)
  7. Verify flow meter operation by blowing air through the part and measuring the resistance.
Whew! Well, that's what the service tech manual said. Hope that helps! By the way, I found this service tech manual behind the lower front panel of my washer, attached to the right side of the frame. Yours might be in there too!
Dec 16, 2007 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
977 people viewed this question
Top Washing Machines Experts
