Question about Kenmore Washing Machines
I need scematic
I'm looking for repair manual for toploading Kenmore Oasis HE washing machine. This is not your Gramma's Kenmore. It is one of the newer machines outfitted with DC brushless drive motor and sophisticated electronic control systems. For this old-timer, it is clearly alien technology!
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 05, 2012
  • 1073 Answers
SOURCE: replacing a coupling, motor and isolation (3 piece part) on a kenmore washing machine
you have to remove the case off the unit , remove the pump retaining clips, the motor, and IF THE MOTOR HAS A CAPASITOR ON THE RIGHT SIDE WITH 2 RED WIRES CONNECTED TO IT USE AN INSULATED SCREWDRIVER TO SHORT OUT THE 2 THERMINALS ON THE CAPASITOR TO DISCHARGE IT IF YOU DONT SHORT OUT THE CAPASITOR IT COULD IN SOME CASES BE A DEADLY SHOCK, REMOVE THE WIRING CONNECTOR FROM THE MOTOR remove the motor retaining clips and the coupling is right in frount of where you removed the motor just be safe at all costs
Posted on May 09, 2008
  • 147 Answers
SOURCE: Simpson 36P450 Washing Machine continuously
It cant drain if you oulet hose is higher than the water level. Raise your drain hose up above your water level. I was pmel (calibration) in the air force..Love it.Went to school at port huneme (navy) school
Posted on Oct 25, 2008
SOURCE: Kenmore Oasis Washing machine makes noise during Spin cycle
with the machine empty see if you can lift up only the tub and see if it drops down.check to make sure there is nothing between the tub and outer tub have you gotten an f-51 error?
Posted on Nov 11, 2008
mgprice
  • 744 Answers
SOURCE: My Kenmore 80 series topload machine is leaking water
This machine has a direct drive pump, in all likelyhood the pump is leaking...unplug machine...pull it out...tip machine on its back so you can access the bottom, if it is the pump there should be water around where the pump connects to the motor, if it is the pump it is a simple process of releasing 2 clips and taking the inlet and outlet pipes off the pump..install new pump the way you took old one off. you can obtain the part from www.repairclinic.com If you would like to give me more details on your dryer i may be able to work out what is wrong with it.
Posted on Jun 23, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite Oasis Wash Machine Error Code F54
The F54 fault code indicates that the control board senses high motor current.
This can be caused by excessive friction in the spin basket.
With the washer off, open the lid and see if the basket spins freely.
If not, you may need to remove the basket and check for an item stuck between the spin basket and the outer washer tub.
The second and third images show procedures for removing the basket on the Oasis washer depending on whether you have an impeller or agitator in your model.
If the basket spins okay, then you can follow the technical troubleshooting described in the first image.
This may help you determine the cause of your washer problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Removing Tub, Basket, lint filter: http://media.fotki.com/1_p,srfssgbktsdgrrqxgtqsskgwtqkq,vi/rstsfdwbbxwwdskwfgkxrrdqddwqb/1/1303472/5961857/image5139789143943268173img-or.jpg
Removing basket & Hub: http://media.fotki.com/1_p,sqgwstkfwtfwsqwxgtqsskgwtqkq,vi/kbkbfbkgwxbfdtwrdxkrkggrdrw/1/1303472/5961857/image27197img-or.gif
Wiring Diagram: http://media.fotki.com/1_p,srfssgbdfbbkfwsxgtqsskgwtqkq,vi/rstkrrqkkxwrtdkbbrbxbqdswfffs/1/1303472/5961857/image3973684248966800668img-or.jpg
http://media.fotki.com/1_p,wktkgtrtsbsgwfrxgtqsskgwtqkq,vi/wrskkfsfrxwwqgrkddg/1/1303472/5961857/image35809img-or.jpg
Posted on Sep 25, 2010
Kenmore Elite Oasis topload washer overfills. I have replace the pressure switch hose but it did not solve the problem.
If you have gotten that far, you've done good.! I'd say to look at the painted screw on the pressure switch.. Needs to be turned. In clockwise direction to make sure diapham closes.. Or it's possible the circuit board is gone out..
Dec 02, 2016 | Kenmore Washing Machines
Enter diagnostic mode in mod 11028002010 toploader he washer
Washer topload diagnostic mode. - YouTube
? 5:00
https://www.youtube.com/watch?v=jipYd_qeCqs
Jun 17, 2014 - Uploaded by Al Fixit
How to put kenmore washer into diagnostic mode. ... How to Use HE Top Load Washing Machine: Informational Tips From Sears Home ...
Entering Diagnostic Mode in a Whirlpool Vertical Modular ...
? 1:02
https://www.youtube.com/watch?v=7kWrIPaWLUM
May 8, 2012 - Uploaded by SamuraiRepairman
Shows how to enter diagnostic mode in the Whirlpool VMwasher. Created on May ... The first was no error codes. the second said that we had an unbalanced load. I'm not sure ... I had a repair person out to my house he reset the computer panel and it worked. Now its ... washer. Raise the top panel to get it.
Diagnostic mode for Kenmore Elite Oasis HE Top Load ...
Dec 12, 2015 | Washing Machines
Toploader kenmore elite oasis is showing F1 code for error. I do not have an owners manual. What does F1 mean?
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
Gene
Aug 21, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore TopLoading Oasis shreds my towels. What can I do to prevent this from happening?
Tighten the agitator. It has loosened up - allowing material to fit underneath.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 07, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
How to remove the agitator & the basket on a kenmore elite oasis
See the following Whirlpool Service Manual for their Cabrio washer. It's the same machine as the Kenmore Oasis,
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
May 11, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Error F51 for Kenmore Elite Oasis Toploading washer??
bad main board or motor possitioner sensor.. most likely motor sensor.
China made junk parts with a million problems
Nov 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
LF error code
I had the same problem this weekend. Sears said they would have to send someone to fix it. Now I have to wait til Wednesday. It better be fixed then! It's only a month old machine, and I'm livid.
Jan 11, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
76 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
