Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Machin is spinning and do washing cycle in 1 and keep on breaking the motor coupling can you help
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
This is often a worn clutch or broken t-bearing support. If the t-bearing support or ball cracks and breaks or comes out of place the clutch will drop and the brake pad will not be able to engage. The other common problem is the clutch may be adjusted at the clutch This is often a worn clutch or broken t-bearing support. If the t-bearing support or ball cracks and breaks or comes out of place the clutch will drop and the brake pad will not be able to engage. The other common problem is the clutch may be adjusted at the clutch support shaft. Some of the support shafts have a nut on them and some just have washers. You will have to raise the nut a little or add 1 washer to help push the clutch up and engage the brake pad to stop the spinning and agitating at the same time. Sometimes a new clutch and brake pad is the only repair or a new t-bearing and ball.
Posted on Nov 05, 2012
  • 67 Answers
SOURCE: duet Washing Machine spin cycle is spinning slow
make sure u are not under loading the washer with just one or two items and that the load is fairly balanced or else the machine will not go into high speed spin as to not go completely off balance and walk across your floor if that doesnt fix it you might need a new ccu or motor control board probably the second one and make sure u are using HE detergent and not too much because suds will lock the pump up which will not spin with water in the unit
Posted on Mar 20, 2007
  • 4 Answers
SOURCE: Whirlpool gold washing machine
It is either a timer issue or a motor issue. I know, that you knew. But if you have a motor with like circuitry and size, you can try that or to put it into the spin cycle and see if it is a mechanical obstruction or with a voltmeter see if the timer is working.
Posted on May 18, 2007
SOURCE: WASHING MACHINE
Yes it agitates, but not spin
Posted on Apr 17, 2008
  • 1073 Answers
SOURCE: washing machine not draining and spinning
check the lid switch
Posted on May 01, 2008
SOURCE: washing machine will not advance through the wash cycle
Hi, Your timer motor burnt out, or timer faulty, remove top back panel (back of timer) and check timer motor, if timer motor are built-in (electronic type) you'll have to replace timer, or if timer motor can be remove, replace it, check back of timer, (knob you turn to change cycles or programs) locate timer motor, you can check appliance store to purchase timer motor, or let mechanic check, surely it's your timer motor or timer, check let me know,
Posted on Aug 12, 2009
Frigidaire model fex831fso
can you hear motor trying to run if so . there are 2 things to check agitator has a mechanical device that when it spins it grips the agitator and starts to spin . its like a coupling . also the motor two ha a direct coupling attached to gear box both items are made of plastic in time they do break down . but if you motor runs on a belt and does not run then does it work in wash cycle if so motor ok but selector switch not working properly. if both cycles don't work motor start winding has burnt out can you smell burnt insulation around motor if so need new motor . if thi does not help you google you washer machine on line and you might get a break down on what other possible cause that could effect you washing cycle . but google brand and model number of washer.
May 14, 2014 | Frigidaire Washing Machines
I have Kenmore washer,model #110.28882790. grinding noise when in spin cycle. not spinning! What is possible defects?
Sounds like the washers drive coupling is broken. Part number 285753A. The coupling connects the motor to the transmission and when it breaks it can make a grinding noise. Since it is not turning the transmission anymore it cannot spin. Hope this helps
Aug 30, 2011 | Kenmore Washing Machines
My washing machine does not spin at the last cycle to wring out the clothes. hence, the clothes stay wet, and then stops and 3 beeps. I do not understand why i am having so much problems with this machine....
on some washing machines, there is a coupling that goes between motor and the transmission. if the coupling is bad tub will not spin, get access to motor and check it out. the coupling is made of hard rubber so as to not break anything if the motor or transmission jams up, only the coupling will go. its less than 20.00 at most appliance stores. if the coupling is ok, then remove switch from washer lid, tape the two switch wires together. if it spins fine now then the switch is bad and needs a new one.
Feb 17, 2010 | Washing Machines
Washer will fill up with water and that's it. Will not go into agitate or spin cycle. Did some loads this morning. Was going to do one more and found machine in middle of spin cycle not working. Tried...
If Kenmore and direct drive with no belt
then motor coupling needs to be replaced
The coupling is what is inbetween the motor and the transmission. It consists of 2 plastic pcs and a middle rubber. The purpose of the coupling is to not only interconnect the motor to the transmission therefore eliminating the BELT BUT if the washer is OVERLOADED, this inexpecnsive coupling breaks before other damage to motor or transmiossion occur.
Nov 20, 2009 | Kenmore Washing Machines
Washer wont run spin cycle model 417
The reason for your washing machine not to spin would be of a faulty motor coupling.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Thank you for contacting Fixya.com
Aug 11, 2009 | Kenmore 43042 Front Load Washer
Machine will not spin on the spin cycle
Hello there.
You most likely have a problem with the motor coupling. (please look that up).
You have a direct-drive system, meaning it does not use a belt but rather what's called a "motor coupling".
I probably replace 5 a week because these little guys break because of 2 reasons
that i've found.
1) The break mechanism is too dry and causing the basket to stop at a holt,
which puts a lot of strain on the coupler.
2) They break because of over-loading.
Good luck to you. The repair is kind of hard to do on your own for the first time,
so I would call an authorized technician. It will run you anywhere between $90 to $120
at most, including parts.
Best of luck!
Ned
Jul 11, 2009 | Whirlpool Inglis IP4400 Washer
Why did clutch hardware and motor coupling break at the same time on my kenmore washing machine? wash cycle works but spin cyle does not.
if the basket drive clutch and brake assembly is broken this will automatically break the coupler assy.
Jul 08, 2009 | Kenmore Washing Machines
Washer will not spin
Hi there :)
You most likely have a problem with the motor coupling. Top-load washers use what's called a direct-drive system, meaning it does not use a belt but what's called a "motor coupling".
If the washer has a clicking sound when in spin cycle, it's probably the coupling.
that i've discovered.
2) They break because of over-loading. I don't think you're over-loading though because it's lasted you for this long.
at most.
Best of luck!
May 26, 2009 | Kenmore Elite 20972
Whirlpool LSR9434PQ1 tub won't spin
The problem you have is a broken motor coupling. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
Apr 30, 2009 | Whirlpool LSR9434PQ Top Load Washer
Motor clicking sound from kenmore washer
You most likely have a bad drive coupling between the motor and gearcase.
Set the machine on a spin cycle and turn it on.
If the motor is running and the washer is not spinning, bad drive coupling.
Feb 25, 2009 | Kenmore Washing Machines
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
46 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
