Question about Velodyne DLS-3750 Subwoofer
Power problem hi, i'm currently receiving a 'clicking' noise followed by an intermittent power loss and then gain on my subwoofer. a little new to home theatre and any info will help. thanks.
    Genius:
  • 1,074 Answers
Have the power supply check out you have an open connection on your regulayor.that clicking sound comes from the relay.good luck
Posted on Jun 04, 2007
  • Henry  Thomas
    Henry Thomas Jun 04, 2007
    sorry i mean regulator.
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
I have the following setup: AV Receiver: Pioneer
Very common problem with today's receivers. Receivers made today don't have a true preamp section in the amplifier and do not amplify the sound to the extent of an older receiver. I have large 15" front speakers on my system, and have stuck with my 15 year old receiver just because I know that a new receiver will not have the power to drive them well. Many of the newer receivers need to be turned up to 50-60% before you can even hear anything from the speakers.
Aug 08, 2013 | Pioneer Audio Players & Recorders
Hi. I have problems with my SWA1801. When I try to start the amp, the Thermal light goes on. Even if the amp is cold ! What can it be? I have turned down the gain on the back and have good cables to the...
Power it ON, without anything connected to the input.
If it powers On without the thermal light, then rejoice,
If it powers On with the thermal light it means something...
Oct 23, 2012 | Mackie SWA1801 Subwoofer
S8 makes a very loud vibrating buzzing noise with only the power lead plugged in
Check for ground loops. Also shut off any CFL or LED lamps inthe vicinity.
You may also have an intermittent connection on the input.
There is a lesser chance that there is an internal failure of a capacitor on the amp power supply, but it is a possibility to look at if all the wiring is in place and soundly connected. The S8 has a high gain amp. It will pick up interference from CCFL or LED ballasting supplies it will also be able to pick up other switch mode power supplies. in vicinity of the input cable.
Jan 07, 2012 | Celestion S8 Subwoofer
Subwoofers Creating Independent Noise
Sounds like your RCA's are near your power & ground wires. I would run your RCA''s on the other side or as far away from the power wire as possibly. Sounds like your getting the infamous alternator whine. If none of the above work you can get a in line noise filter to filter out that noise. RCA's can pick up noise when their around anything that has alot of current running through it....Hope this helps
Mar 28, 2010 | Boss AUDIO SYSTEMS D13002 Car Audio...
It wont run my subwoofers
See if a) the head unit has a separate subwoofer output control, and make sure it's activated; b) the amplifier you're using for the subs has the gain control properly turned up; c) if neither of these fixes the problem, make sure all of your amp fuses are intact; d) make sure the subwoofers are in a properly-sized enclosure (too much or too little airspace can affect the sound output).
Jul 04, 2008 | Sony CDX-CA400 CD Player
Subwoofer clicking noise
Hi I am afraid it sounds like exactly the same problem I had, Namely the PSU(power suplly unit) is failing, This is a common fault (by reading loads of forums) I contacted KEF today about mine and they say the probably wont be able to source any more spares(due to so many having thuis problem no doubt) So I would suggest contacting the people you bought it from,Under the consumer protection act you should expect an electrical item to "Last a reasonable amount of time" .Mine is 3 years old and I do not consider this to be a long period so kick up and you should be entitled to a repair or at worst a partial refund.Look here basically the same Sub.
http://www.avforums.com/forums/showthread.php?t=436234&highlight=kef
Mar 04, 2008 | KEF Audio PSW 3000 Subwoofer
Clicking noise from subwoofer
Malfunction in the amp or to high signal on the input protect relay is cliping
Nov 26, 2007 | JBL SCS125A System
Velodyne DLS-3750 Subwoofer Logo
291 people viewed this question
Top Velodyne Audio Players & Recorders Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Are you a Velodyne Audio Player and Recorder Expert? Answer questions, earn points and help others
