Question about Dremel 6000 Contour Sander
I need spares for my Dremel 6000 sander
Where can I buy spares and sandpaper in the UK for my sander please?
    Top Expert:
  • 14,553 Answers
Most likely you will find them on EBAY---search there for Dremel.
Posted on Nov 04, 2012
74-674 sandpaper black & decker sandpaper
Have you tried the hardware store where the sanders are sold?
Jan 01, 2016 | Sander Tools & Hardware - Others
Why has my dremel 6000 just stopped working could it be the brushes
Although Supergrit Abrasives in Gettysburg, PA sells the sleeves and the Hook & Loop diamonds for use with the Dremel 6000, we do not repair tools. The 6000 is discontinued, but you can probably buy a used one that works on Ebay.
Jun 14, 2014 | Dremel 6000 Contour Sander
Car Headlights. How do I remove the film. I assume it is with sandpaper,but I need more details. HELP
they make a kit that you can buy from an auto parts store to do this, I have used it in the past and depending on how bad the lenses are it works pretty well. BUY the best kit with the grinding/buffing wheel for best results and follow the manual. Let me know if you need more assistance.
Jan 01, 2012 | Red Devil Devil 289022 220 Grit Sandpaper...
Could you please tell me what sandpaper goes on the Mouse sander/polisher model # MS500
ok this easy go to the hardware store and ask for the sandpaper to fit your sander, black & decker make sandpaper specifically for that sander. now depending what job you want to do will determin what grade you want sand paper works like this the higher the number on the paper the finer it is so for example 80 is very coarse you would use that for eg stripping thick paint on a door but 2000 is very fine and is used for eg sanding varnish between coats. ok hope that helps let me know how you go.
Mar 11, 2011 | Black & Decker Mouse Sander/Polisher
Sandpaper keeps coming off while sanding. Why and how can I remedy situation. I was thinking about replacing rubber cover on clamp.
I switched it to a new pad and the sandpaper is still flying off :( I just don't get it the paper is not even half used up. my sander is the hook and loop velcro one ugh its driving me nuts I have to keep buying more sandpaper when the sandpaper is not even worn out! BTW Mines a dewalt hook and loop random orbit sander
Jan 03, 2011 | Bosch 1297DK 14 Sheet Palm Sander Kit
DW411 Can I put a velcro pad on this sander so I don't have to fumble around trying to get sand paper on it
Dewalt is not going to make an accessory for you to do so, since that sander was designed to use 1/4 sheet sandpaper, and therefore takes standard paper clamped in place. You could make your own base for the sander out of thin plywood or some other suitable material, covered perhaps with a laminate or rubber surface, that would accept PSA (pressure sensitive adhesive) sandpaper, which you can buy in rolls appropriately sized for your sander. Or you can try some kind of after-market conversion kit such as this one (See also here, etc.)
If you really want a hook and loop base on your sander, I recommend you bite the bullet and simply purchase a random orbital sander with a H&L pad. Then you'll of course have to buy the perforated paper discs to go with it....
But you'll easily be able to change grits, and the performance and quality of your sanding will improve.
You might check the reviews in various woodworking magazines before you make a purchase, just so you know what you're likely to get for your money. There's a vast array of machines made, and the quality varies accordingly, and depends to some extent on your budget and intended use.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Dec 20, 2010 | Dewalt DW411 quarter - sheet palm grip...
Change sandpaper head on dremel motor tool
if your talking about the barrel sander there is a screw on top that you loosen and the barrel will slide off put the new one on tighten screw and your good to go
Jan 09, 2010 | Hand Tools
Black & Decker Cyclone won't power on
If the sander was on for a long period of time maybe 20 mins or so then the switch has probably stuck in the off position when you turned off. Try a new switch or test the old one. Try Solent Tools on 023 80578057 for spares or further advice.
Dec 10, 2009 | Black & Decker Black And Decker Cyclone 4...
Spare Tips for Black & Decker KA161 Mouse Sander Polisher
Don't know if you had any joy finding the heads, I'm in the UK and managed to get all the spares I need for my mouse.
You can get them from here: http://www.mtmc.co.uk/Black--And--Decker-KA161K-Type-1-Sander-Spare-Parts/p-20239/
I believe the part your looking for is par 105 on the diagram, they're like less than £1 each (I just ordered 3).
Hope this helps.
Kev
Feb 22, 2009 | Black & Decker Mouse Sander/Polisher
Dremel 6000 Contour Sander Logo
285 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
