Question about Candy Washing Machines
Candy GO F426 fills then keeps washing but does not go to the next stage.Just keeps clicking
  • 7,627 Answers
Control Switch.
Posted on Nov 04, 2012
5 Suggested Answers
IFIXALL
  • 868 Answers
SOURCE: Magic Chef Washing Machine
You have a air leak in either the pressure hose or the pressure switch itself.
Posted on Jun 12, 2008
barkencoa
  • 3463 Answers
SOURCE: WFC 2260 - Machine Fills and empties, but drum doesn't rotate
You probably need to replace the brushes in the motor.
Remove rear panel, remove belt from drum, undo 2 screws securing motor, unplug lead to motor, lever motor back with a screw driver, keeping hold of it, and remove motor.
You will find the brushes located at the opposite end to the motor pulley.
Please leave a fixya rating for my proposed solution.
Thankyou.
Posted on Feb 04, 2009
SOURCE: washing machine not going onto next cycle after it fills up..making a click sound
DOES NOT MAKE A CLICKING SOUND.
Posted on May 20, 2009
richroth
  • 9472 Answers
SOURCE: Washing machine filled with water
If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Posted on Nov 26, 2010
My idesit IWB5113 just keeps filling after starting the wash cycle, normal it inject some water then starts washing, my machine just keeps filling and doesn't seem to start the wash cycle, please help
It is possible that the water level sensor has failed and so does not detect to stop the inlet valve from filling.You can remove and check this level sensor normally it can be a damaged diaphragm and replace the same so that the program proceeds to the next stage to start the machinetips to see working of the machine;http://www.espares.co.uk/advice/washing-machines/a/7/1392/how-a-washing-machine-works.html
Mar 14, 2012 | Washing Machines
My washing machine keeps filling up with water even though it is empty and not being used
You need to replace your washer fill valve. It is stuck open enough that it fills even when off.
Dec 17, 2010 | Candy Washing Machines
Candy cs455m programe stops at about 3oclock on the dial
Yes heatr should be submerged in the water. Not expose to free air.Check the water level float switch or the pressure switch.
The replace timer should be identical in design. If there is a mismatch it will not function as designed.
If it is elctronic micro controller type the same part no and soft ware version should be used.
May 25, 2010 | Candy 17 in. CS455 Built-in Dishwasher
I have a candy AQ 1200, it fills with water then drum turns and s
sounds like m/c is waiting to heat up water but heating element is not working or timer switch not going on to next cycle.
Aug 21, 2009 | Candy Washing Machines
Thankyou.
Feb 03, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Jun 12, 2008 | Washing Machines
Washing Machines Logo
41 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
