Question about White Sewing Superlock 2000 ATS Mechanical Sewing Machine
I need instructions to Thread a White Super Lock 534 Serger
I am starting to teach a clothing class next week. The class has several sergers/overlock machines. I don't even know the brand of the 5 spool ones. Is there any pictures /videos anything to show me how to thread the machines.
    New Friend:
  • 3 Answers
Yeah,it is complex to explain the qustion.You know,the different modesl have the different ways and order to do the job.I can't tell you answer before I know the serger that you use..You can actually thread your serger all the way through the needles, if you tie the two needle threads as square knots and very slowly sew and gently pulling the serged thread until all the colors have changed to your new color. Once in a while the needle threads will break if the knot is not tight enough or you are trying to sew too quickly.
Posted on Nov 14, 2013
I need a manual for a WHITE SERGER MODEL 523 SUPER LOCK
Posted on Jun 22, 2012
  • 109 Answers
If you get the brands and model numbers of the machine to be used in the class, you can go on line and just search each serger for their threading picture or email any site that sells manuals, tell them your needs and they usually will send you a picture. Or just tell the ladies to bring their books and if it's one you don't know, tell them to take out their books and you can show and highlight the differences for them. They don't know you didn't always know this!
Posted on Aug 22, 2010
    Scholar:
  • 192 Answers
I hope this helps. there a lot of other vidios you can try as well. DFD
Posted on Apr 22, 2009
4 Suggested Answers
  • 47 Answers
SOURCE: White Speedylock 1500 Serger Manual needed
Visit us at www.ifixmachine.com
Posted on Jul 24, 2009
  • 9 Answers
SOURCE: thread keeps breaking
Your machine isn't threaded properly. Check to make sure #1, you have it threaded right and #2 the thread on all 4 spools is in between the tension dials. Good Luck and Hope this helps.
Posted on Feb 02, 2009
  • 5 Answers
SOURCE: need belt for white super lock serger model 534 a
Try Ron over at http://www.a1sewingmachine.com I have tried calling their parts number over at White and it just rings. Good Luck!
Posted on Sep 09, 2009
HOW DO I THREAD THE ELNA L1 overlocker
Your owner's manual should have instructions:
Instruction Manual Elna L1 Serger
If you need help, the local Elna dealer may be able to offer some assistance.
Overview Elna Serger Overlock Sewing Machine FREE SAMPLE
Feb 05, 2018 | Elna Sewing Machines
I am trying to teach myself to sew.... what is a serge stitch an how do I set my brother sewing machine to do it?
A serger (overlocker) is not a sewing machine. If you look at the inside seams of a purchased t-shirt, you will usually find a serge stitch that was created using a serger (overlocker). A serger/overlocker usually uses 3 or 4 threads to create that stitch. It also trims the fabric at the same time it finishes the fabric edge. The serge stitch is a chain stitch that, if you pull a particular thread, the entire stitch will come undone.
Your sewing machine is not able to create that same stitch. Your sewing machine may have what is called an "overlock" stitch, but it will use only 2 threads (the top and bobbin) to create that stitch. You would have to consult your owner's manual to see if it can make an overlock stitch.
Different Serger Stitches and How to Use Them
The BERNINA Serger Overlocker line BERNINA
May 05, 2017 | Brother Sewing Machines
How do I get a balanced tension with my Elna 624 overlocker?
The best way is to thread with 4 separate colors of thread and then studying the stitch result. With the 4 colors, you can easily tell which thread tension is "off" and whether it should be tightened or loosened. However, a serger is not like a sewing machine where you can set the tension and use that setting for most projects. With a serger, a change in one or a couple of thread tensions will create a totally different stitch.
For most machines, there is a mark at the midway point on each tension control that is the "optimal" tension for a 4-thread overlock. HOWEVER, every machine differs, so these settings may need to be tweaked.
Make It Handmade Perfecting Serger Overlocker Tension
The Anatomy of The Best Serger Tension My Tips Bonus Unpick it Serger...
How to Adjust Thread Tension on an Overlocker Singer Australia
You may want to download the serger workbooks at this site (Bernina), and work through each of the stitches. Make notes in the workbook as to how you have set up your machine to get the best of each stitch. This will be a great reference manual for many years.
Bernina Mastery Workbooks
Feb 23, 2017 | Elna Sewing Machines
I have a white speedy lock serger model 7340. I completely pulled all threads out and now trying to re-thread new thread. I have tried around 15 times. It will not loop. Threads don't interlock at all
Be sure that you are threading each thread in the correct order. The manual should have those instructions.
ALWAYS RAISE the presser foot when threading the machine!!!! For most machines, the upper looper is threaded first, the lower looper second (the lower looper thread finishes by draping OVER the top of the upper looper and then pulled toward the back of the machine), then thread the needles. Give each thread an extra little tug when threading the tension disk to make sure it is seated completely.
Even if you are unable to locate a tutorial for your particular machine, most models from the same era will thread the same.
Don't be surprised if it doesn't work the first, second, or even the third try. It took me most of a day to get mine threaded correctly the first time!!! Patience!
How to Thread the White Superlock 534 Serger Serger Machine Series Ep 2
How to thread White Superlock serger
Sewing Machine Instructions White Speedylock Differential 1800
You can search YouTube for other videos.
Jan 06, 2017 | Sewing Machines
Help plse, after threading it dont make the overlocking stitches. New machine, help with right way to thread machine and the smaller detail of threading.
Your machine is either not threaded correctly, or the individual threads have not been threaded in order. Be sure to ALWAYS RAISE the presser foot when threading the machine. You must follow the instructions exactly or the machine will most likely never work properly. Can you at least get a training class on your machine? A class is indispensable, especially when it comes to using a serger.
Even if it is not the same model, these instructions may be helpful.
Tutorial for threading overlocker
Make It Handmade Threading Your Serger or Overlocker
Need manual for an empisal 754D overlocker can get the tension right and...
Dec 14, 2016 | Sewing Machines
Need the manual for model 534?
SINGER 534 MANUAL Pdf Download. - ManualsLib
www.manualslib.com > Brands > Singer Manuals > Sewing Machine > 534
View and Download Singer 534 manual online. Stylist Sewing Machine. 534 Sewing Machine pdf manual download.
[PDF]White Sewing Manual Model 534
www.masepmadit.com/white-sewing-manual-model-534.pdf
vw instruction manual, white 534 serger: sewing parts online understandable ... techmanual white superlock serger model 534 repair manual compiled pdf.
Jan 07, 2016 | Sewing Machines
I have a new home janome model number 534 how do I
The Janome 534 that I know is an overlocker (or serger). If this is so, then when you open the front flap / door there should be a diagram showing the thread path. It is important though to first thread the inner (upper) looper, then secondly the outer (lower) looper, thirdly the inner (right) needle, and lastly the outer (left) needle.
Oct 09, 2014 | Sewing Machines
Need belt for white super lock serger model 534 a serial number 87351382
Jun 28, 2009 | White Sewing Superlock 1934D Mechanical...
Treading my serger
When you thread the serger, your suppose to start threading the 3rd spool (left to right) first, then the 4th spool, then thread the 2nd spool which ends up in the second needle (left to right), There is a lever or bottom looper that the thread must go through before placing thread through the 2nd needle. Finally, the last spool to thread is the 1st spool (left to right). Follow the threading pattern and once you put the thread through the two loops that look like springs, turn the wheel at the right toward you until you can see like a lever with a ****, thread that **** from the back then put the thread through the machine to the right. Turn the knob to toward you again until the upper looper is showing, then you have the put your thread through the hole in that looper then through the first needle. You should now have 4 thread toward the back of your machine which you need to place under the presser foot and to the left side of the machine. There is also a VHS video that goes with the machine to help explain how to thread your serger. Also be sure that each spool of thread is in the tension of the upper colored tension wheels. If it is not, then your stitiches will be loose. Good luck and I hope this helps. I had to watch the video several times before I got it. If you don't have the video, try ebay for and perhaps you can obtain one. The video is Speedylock 1600, instructional video, USA Part #136000016, Perhaps you can contact White and see if they have one you could purchase.
Good Luck Serging!!!!
Feb 16, 2008 | White Sewing Speedylock 1600 Mechanical...
White Sewing Superlock 2000 ATS Mechanical Sewing Machine Logo
1,621 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
