Question about Linksys Wireless-G WRT54G Router
Wireless Linksys router cease to broadcast and maintain connectio
I have a WRT 54GP2A-AT router with VOIP. This router is mostly used with the wireless connection. The other two routers are workding well using hardwire, but this one intermittently stops and is slow to get back online. I tried looking for an upgrade or update to the firmware but there is none yet. I had this problem with another of my linksys routers. I know the settings are correct, because it does work and has worked.
I am beginning to wonder if Linksys is as good as they have been in the past, even if they are also branded with cisco systems.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
The wall plug power supply is very likely your problem, it is made cheaply and of low quality with low quality capacitors inside. These fail over some time and the power supply becomes unstable and the Linksys will start to do funny stuff.
Find a better replacement power supply, I'd recommend one that has a higher current rating (2A or so)
and you will be fine.
Hope this helps
Posted on Jan 11, 2009
Linksys router not recognize internet
Make sure your router's WAN port is set to dynamic IP. If the light on the front doesn't glow/blink for the WAN port, try a different cable. If a different cable doesn't work it's probably toast. :( This problem appears to be directly linked to the relationship between the WAN port and the modem. Given that the devices can connect to the router, but not internet, it has to be the WAN. Sometimes if the modem goes out it will send too much voltage through to the router and fry the WAN. Had that happen to my parents router. If the above doesn't "fix ya" then try a different router.
Worst case, you might have to put a wireless card in your PC and bridge the modem (wired connection) to the wireless card and broadcast for your wireless devices. At least until you get a new router.
Aug 02, 2013 | Dell Computers & Internet
Client Mode or 2nd Wireless Router with new Subnet Mask?
The original firmware does not have this option, but you can get a custom firmware at http://www.dd-wrt.com/
DD-WRT is not supported by linksys, so a little caution there as this could ruin your router if it is not installed properly. Fortuately they have plenty of documentation on installation and troubleshooting if needed.
Also found this on how to setup Client Mode through DD-WRT - http://www.dd-wrt.com/wiki/index.php/Client_Mode_Wireless
May 20, 2012 | Linksys WRT54G Wireless-G Broadband Router...
Router does not show wireless light. I have reset it but can't access it with the setup wizard. Any suggestions?
* NOTE: If you tried to set-up the WRT-150N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
then do this :
1. Hook up the Linksys WRT-150N Router to the Modem via a LAN cable.
2. Hook up the Linksys WRT-150N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-150N Router.
3. Type http://192.168.1.1 in the address bar of your web browser.
4. Log-on to the Linksys WRT-150N Router with these log-on credentials:
Username: linksys (lower-case)
Password: admin (lower-case)
5. Click on the "Clone PC MAC Address" tab.
6. Click the "Clone PC MAC Address" button.
7. Click "Save", click "Continue".
8. Click the "Wireless Security" tab.
9. Choose "WPA2 Personal - TKIP/AES" for encrypted security.
10. Enter encryption password (passphrase).
11. Click "Save", click "Continue".
12. Exit the web browser.
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-150N Router.
In about 5 seconds, your wireless connection should be up and running.
Sep 15, 2010 | Linksys Wireless-N WRT150N Router
Hello, I have a Linksys Router model No. WRT 160N and have problems with the wireless signal. Doesn't appear the wireless symbol ON and I have connected already the modem cable. The modem is OK cuz I can...
* NOTE: If you tried to set-up the WRT-160N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
Then do this
1. Hook up the Linksys WRT-160N Router to the modem(cable, DSL or satelitte)
2. Hook up the Linksys WRT-160N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-160N Router.
4. Log-on to the Linksys WRT-160N Router with these log-on credentials:
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-160N Router.
Sep 15, 2010 | Linksys WRT160N Wireless Router
Hey guys could i use my router as a radio to pull the internet signal from a next router without using any cable
With the Linksys router it is not possible. You will need to connect the cable between the two routers. Linksys router will not pick up the wireless signal from the other wireless router.
May be it will work If you upgrade the DD-WRT Firmware. Not sure but it may. consult with the DD-WRT expert before upgrading the firmware.
Apr 22, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Lenovo laptop cannot seem to find the linksys wireless g. we have two WIFI at the office one is linksys VOIP (secure) and linksys wireless G (unsecure). why is it that lenovo laptop only sees the secure...
make sure that the linksys VOIP(secure) router is broadcasting it's SSID or signal, otherwise it will not reflect even if you refresh the wireless network. If the router is broadcasting SSID but the lenovo laptop is not detecting it, try to re-install the wireless software for the laptop using the software from lenovo.com, just click Support then Downloads and drivers.
May 13, 2009 | Linksys Wireless-G Broadband Router
Wrt 100 router no showing
If the router is not broadcasting teh best way to fix this problem is to reset the router by pressing the reset button of the router for 15 seconds then afetr that run again the setup cd of the router or manually reconfigure it back....
Nov 30, 2008 | Linksys RangePlus WRT100 Wireless Router
WRT54G
Make sure that the WRT54G has an internet signal coming in. Is the other DSL router have a wireless component to it? How are you wiring everything? How many ports does your DSL router have? If only one, go from the DSL router to the wireless router. Plug in your phones (VOIP) to the WRT
May 23, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
46 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
