Question about HP Computers & Internet
I press start on laptop, windows 7 will not load up, i have to press F8 a few times to load ,windows 7
I press start on laptop, windows will not loadup, i have to turn laptop off, and press start again, as soon as screen lights up, i press F8, i then go to load windows 7 normally, after a times doing this , windows finally loads up, Thank you for your time and effort tony
  • anthony hart Nov 05, 2012
    Thank you foryour answer to my problem
  • max carson
    max carson Nov 05, 2012
    Did it Work?
  • HP Master
  • 7,627 Answers
Try a cold start, unplug, remove battery, hold down on/off button for 10 seconds, replace battery, plugin, push on/off button, try to start normally. If that fails do a system resotre/ recovery.
Posted on Nov 04, 2012
lolita
  • 385 Answers
SOURCE: Toshiba Satellite P105-S6084 Laptop Boot Problems.
This happens sometimes due to faulty memory or faulty software that causes errors in filesystem. You need to obtain a Windows XP with the correct edition that is installed and boot into it. Then go into Recovery Console and wait for the c: prompt asking which windows you want to log into. Select 1 for C: windows. Then it will ask you for the administrator password. Enter it or press enter if there is no password. Type chkdsk c: /r at the c:\windows prompt and leave to run. It will take about 15 -30 mins. When finished, type exit and press enter. Press ctrl+alt+del to restart computer.
If problem is fixed, computer should start up fine now.
If you still have the problem, let me know so we can try something else.
Thanks,
Lolita
Posted on Jun 18, 2008
SOURCE: Blank Laptop Screen
sorry about posting for trouble.
similar blank screen problem with Toshiba satlite notebook but I can see the desktop with no light from lcd. so if you just see the screen it's black untill you see very close to the monitor. When it boots i can see the normal screen and it goes away blank. Any suggestion?
Posted on Mar 31, 2008
SOURCE: My Toshiba L300 satellite pro wont load up
USE A BOOT CD AND RECOVER THE FILE AND MAKE SCAN VIRUS
rapidshare.com/files/51117041/ERD-2007.rar
IF YOU HAVE SATA DISK DISABILITATE SATA IN BIOS... TRY....
Posted on May 08, 2009
  • 489 Answers
SOURCE: Blue screen on my laptop
go to bios with F2 button. and you will see harddisk mode.  IDE/AHCI   change their situation.
Posted on May 27, 2009
issken
  • 1472 Answers
SOURCE: Dell Latitude D630 screen flahes then it lockup
swartj864
The first thing I would do is run the onboard diagnostics for the computer. You do this by hitting f12 on your keyboard at startup. Then you will see the boot menu. The last option should be the diagnostics. After you run this if you get any errors I would call Dell support about them as you have a hardware problem.
If you do not get any errors then most likely you have a Windows problem. The first thing I would do is boot the computer into safemode. You do this by hitting f8 on the keyboard when you first turn on your computer. Once in safemode then open of the properties on your C: drive and go to the Tools tab. Next click the Check Now button. Make sure both check boxes are check and click start. Note you may need to restart your computer.
After this runs you need to boot your computer into Windows. Note if you still have trouble you may need to go to safemode again. Once you are in Windows put in your Windows CD and exit out of the installer if it pops up. Next go to Start and Run, then type "SFC /scannow". This will run a repair on the system files. If you still have trouble after this you may need to look at reinstalling Windows.
Hope this helps
Issken
Posted on Jan 10, 2010
I have lost the password for the administrator. How do I reset it?
There is a way to get through administrator password in window 7.
Step 1: Start or restart your Windows 7computer. Step 2: Press F8 to enter Advanced Boot Options before the Windows 7 loading screen appears. Step 3: Choose Safe Mode with Command Prompt in the coming screen, and then press Enter. Step 4: Wait forWindows 7 files loading until Windows login screen comes up
May 02, 2016 | Computers & Internet
Windows 7 on my laptop
Try to Start PC in The Safe Mode by Pressing F8 Continuously,Before the Windows 7 Boot Up Screen Appears,
then Select Last Known Good Configuration and press Enter,
that should Save ur laptop,
if the Problem Persists,Try to Boot on Safe Mode,if that also Fails,try to repair ur OS files using Windows 7 DVD.
May 12, 2013 | Computers & Internet
This is what happens when you turn the computer on . Nothing else can someone help to get it back to how it should be...
2 Solutions
Boot to Safe Mode, by pressing F8 during boot. Then try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Remove all USB attached devices like drives.
You may need to roll back system with System Restore. Under Safe Mode (press F8 during boot and choose Safe Mode).
Win 7 - Start > Search type System Restore.
XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates.
Uninstall last program(s) that was installed, again in safe mode.
Nov 12, 2012 | Computers & Internet
Wont boot in safe mode
start your laptop before booting windows press f8 button continuously
ndows 2000 / XP users
bulb.gif If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
Microsoft Windows Vista and Windows 7 users
To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Sep 27, 2011 | Lenovo G460 Laptop Computer - 06779XU...
Window 7 every 20 minutes hang
Many things could be causing this, the first thing I would do is boot into safe mode and see if the issue continues.
Safe Mode
Just before the Windows 7 splash screen (black with windows logo) appears, press the F8 key to enterAdvanced Boot Options.
You should now see the Advanced Boot Options screen. If not, you may have missed the short window of opportunity to press F8 in the previous step and Windows 7 is probably now continuing to boot normally assuming it's able to. If this is the case, just restart your computer and try pressing F8 again.
Here you are presented with three variations of Windows 7 Safe Mode you may enter:
  • Safe Mode - This is the default option and is usually the best choice. This mode will load only the absolute minimum processes necessary to start Windows 7.
Mar 15, 2011 | Toshiba Satellite L305D-S5935 15.4-Inch...
I have an acer one 8.9" laptop. I down loaded a torrent that stopped and started a few times and said I had a bad hard disk. Now I cant get past the acer start up screen. Ive with the external disk drive...
Try re-starting in safe mode, press F8 as its booting, assuming all goes well choose safe mode, this loads a windows shell. Using Accessories - System tools - System restore - Restore to a point prior to your problemsn.
Sep 21, 2010 | Acer Computers & Internet
Laptop won't reboot
are you trying to put win 10 on as it can do this some time, can take upto 10 15 min to load, when the like is flashing its dos, when the screen is black its windows it takes some time for windows to find a driver and load it so the screen comes up. i've had this on a200's before. if you keep rebooting you will need to wipe the hard drive and start again. this also does this on win 7 and 8. win xp it does not do this as its full dos setup .
Jun 30, 2017 | Toshiba Satellite Pro A200-EZ2204X...
Problem restarting, "press r"
  1. Start the laptop
  2. when the logo screen turns black start pressing F8 a few times.
  3. A Windows Boot Options screen should show on the screen
  4. If you see the Windows Logo (the normal thing when Windows loads, then press reset and try again
  5. At the Windows Boot Options screen select "Last known good configuration" and press Enter twice
It "should" now load normally, if not then..
  1. Replace step 5 above with "Safe Mode" and see if that loads all the way through. If so, then restart and see if its OK now.
If not, then post back with any error messages and we can look at something else.
Apr 13, 2008 | Toshiba Satellite A105 Notebook
Windows error
Turn the laptop on.
Just after the laptop logo's have vanished start to press F8 repeatedly until you see an option page pop up.
If the Windows loading screen shows up then you will have to do it again.
Select "Last known good configuration"
Press Enter 2 times.
Apr 08, 2008 | Computers & Internet
Computers & Internet Logo
234 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
