Question about Garden
Throttle/ govern linkage placement
Took apart carbureutor for cleaning but now forgot how throttle and govern linkage go onto carb. Don't have a manual for diagram. Could you please help?
  • jennis114 Mar 09, 2009
    I have the same problem. Perhaps for future reference it would be helpful for me to take a picture before taking things apart.
    Can you submit a diagram on the throttle cable linkage to the carburator.
    Each time I place the linkage into the hole it pops out.
    Craftman Blower - Model NO. 358.779923.
    Thank you,
    JIm
  • Jim Giesen May 11, 2010
    What type of unit is it?
I would recommend that you go to a store -- with a digital camera and notepad -- that sells this product and has a display of it fully assembled, and take pictures and note on the throttle assembly.
As to the gentleman who did not receive a response on his rating -- I'd like you to know that I certainly appreciate your expertise and time taken to help others out.  People like you inspire people like me to try to help others.  A lot of people go through life never leaving behind anything of good or value to others -- but you can know that you have.  Personally I feel a reward in that.
Posted on May 10, 2009
Carbarator linkage placement
well model number or what we are working on or something rellevent
Aug 19, 2014 | Briggs AND Stratton Intek 331977-0001-G1...
My B&S engine suddenly runs at full throttle and the throttle lever has no effect ?
Sounds like you have a governor problem it governs the speed of the engine..it " governs " calls for more engine speed for hills,heavy grass etc. then back it off when not needed. Sounds like.it is calling for speed but isn't backing off,, most likely dirty..try using carb and linkage cleaner spray and spray the entire throttle and governor area thoroughly. Them some lubricant like WD40 or such ..and operate the handle back and forth to get the the linkage loosened...if this doesn't clear it up professional service is needed..good luck.
Jun 01, 2014 | Briggs & Stratton Garden
Need a diagram or pic of how to attach carb linkage
Just put some baling wire on it, it is a lawn mower...
Apr 27, 2013 | Garden
My 17.5 Briggs & Stratton engine runs fine at idle
replace air filter, check throttle linkage position, take to a pro shop and have governer adjustment checked
Sep 04, 2011 | Briggs & Stratton Garden
I have a poulan push mower that when it starts the throttle goes up and down at any speed can this be adjusted out with the govenor spring?
This problem is usually caused by the diaphragm unit needing replaced underneath the carburetor. I'm guessing you have the Briggs engine with the (plastic) carb directly on top of the gas tank and no float bowl on the carb. You remove the tank and carb as one unit (being careful to note the spring/linkage hookups). Then remove the 5 screws that hold the carb to the tank. Then remove the gasket and diaphragm that is between the two. The replacement kit will cost you about $4 USD. Be careful! there is also a spring under there. Don't lose it and make a note of it's placement. A pinhole or a weak diaphragm is usually what makes these engines 'surge'. Hope this helps and best of luck to you.If you decide to do this repair yourself, be sure to clean all the little holes and indents and the carb itself with carb cleaner too, but don't spray it on the gaskets.
James
Aug 20, 2011 | Poulan "Poulan" Push Mower
My boyfriend took his carb off of his 18hp Husqvarna lawn mower. For the life of him he can't remember how to attach the choke linkage back to the carboutator. please please help us
Look at the wear marks on the plates they attach to. As air flow through the carb, the throttle will attach to the engine end and the choke is the one at the air intake end.
I always take a picture of the linkage now before taking apart, after messing it up before.
I hope this helps.
Aug 12, 2011 | Garden
Pressure washer with Honda GX160 5.5 HP OHV-Starts easily but...
what about the linkage between the governer and the carb. Is that working and not binding?
Dec 20, 2009 | Honda Pressure Washer PSI 3000
Crafstman chainsaw at full power when started
If you had this apart, a few things may have happened. First the linkage from carb to throttle trigger maybe jammed between plastic housing or linkage may have come apart and throttle is in the full open position. You'll have to take this apart again and follow the linkage between carb and throttle trigger to ensure all is connected and moving freely and properly. Use care when putting housing back together.
May 10, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Hi, I took out my carb on kawasaki el250 forgot how throttle cables were connected. a picture of both sides would help out alot!
if you move the throttle linkage on the carb you will see which of the mounting holes rises and which goes the oppisite way. normally the front 1 is the pull and the rear is the push. do the same on the cables by twisting the throttle on and off so you can see which 1 goes which way. hope this helps
May 08, 2009 | 2001 kawasaki EL 250 Eliminator V
Garden Logo
414 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
