Question about GE Ovens
Oven door will not stay closed
The model jt912s0k4ss
aborcass
  • 2651 Answers
SOURCE: Lower oven door
no adjustment at all you would need to replace oven door hinges,
Posted on Mar 03, 2008
aborcass
  • 2651 Answers
SOURCE: Oven Doors will not stay closed all the way
no real adjustment other then replacing the hinge assy's..
Posted on Apr 05, 2008
  • 145 Answers
SOURCE: Oven doors will not close properly
Most of these I have seen have to have the hinges and recievers replaced to get the doors to close properly and keep the light off.
Posted on Apr 18, 2008
SOURCE: kitchenaid oven door will not stay closed
I had the same problem on my parents Kitchenaid KEMS378GWH0 oven, the door would only close enough to keep the light on. They propped a chair against it to cook. My father replaced the hinges and it worked for about a week. He noticed that pulling outward on the door at the very bottom edge often allowed it to close enough to use.
After completely dismantling the oven to get access to the brackets that the hinges slide into, we found it was not broken. We decided to expand on the only near solution we had and find a way to make the bottom of the door 'push out'. Our solution was very simple. Remove the small metal plate that covers the door insulation. This revealed that the insulation is a braided hollow rope that is held in by small clips that push through holes in the front of the oven. We threaded some small metal rods about 3/8 inch in diameter into the hollow insulation pushed the clips back in to re-attach the insulation, replaced the metal cover plate.
It worked!
Posted on Nov 29, 2008
barkencoa
  • 3463 Answers
SOURCE: oven door not closing properly
If it is a drop down door with hinges on the bootom of the oven door, then it is likely to be weak door hinge springs, the usual solution is to replace both hinges.
If it is a swing open door, then the problem is related to a worn or broken door catch, or worn striker pin.
Posted on Apr 13, 2010
Does anyone know what the part numbers are for the baking elements in the oven upper and lower, model is an LG LST5651sw
Here is the link to LG appliances LG RANGES OVENS Support
I entered the number you provided and it couldn't find a match; you might want to re-check the number, or look at a model close to yours.
Mar 24, 2015 | LG Ovens
Unable to find model number for electric oven
Hello, Smlmyers -
Look at the image for the location of the sticker with the oven model on this web page:
http://www.stockportrepairs.co.uk/Lamona/Oven
Scroll down the page. The image is near the bottom.
Best wishes from a volunteer answerer in the USA.
Jan 18, 2018 | Ovens
Have an amana self clean gas oven burners work but oven wont heat up? acf3375ac model
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Nov 19, 2010 | Amana Ovens
Model number fgb24t3aba the ignitar glows but the gas dosent come on frigidaire. i t lights sometimes.
Sep 28, 2010 | Frigidaire Ovens
I JUST BOUGHT A FLOOR KENMORE GAS RANGE THAT WAS A FLOOR MODEL AND THEY SAID THEY DO NOT GIVE THE MANUEL WITH IT. WHERE CAN I GET A MANUEL. IT IS A MODEL 70402 ITEM #0220402000. i BOUGHT IT AT THE SEARS IN...
You can order the paper manual from Sears by calling 1-800-252-1698. They will need the entire model number though. Here is info on where to find the model number:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=70402&pathTaken=partSearch
You can download the manual here:
http://www.kenmore.com:80/shc/s/nb_10154_12604_NB_CCownersmanuals?adCell=WF
Again, you will need the entire model number. It should be located under the lid or on the back of the unit. It will start with three numbers followed by a dot, then many more numbers, such as:
102.24300
If you have any further questions or problem locating model number, let me know and I can help further.
Aug 02, 2010 | Ovens
My Kenmore stove Model 790.75761002 the bake ignitor only glows
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
May 03, 2010 | Kenmore Ovens
What model will relace my Stove Drop in Model
I will find out and contact you on Wednesday for this question. Ella
Aug 19, 2009 | Ovens
Kitchenaid oven model #KEBC207
this was taken from the installation guide
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=kebc207&siteCd=WHRCOM#installation_instructions
Oven must be connected to the proper electrical
voltage and frequency as specified on the
model/serial rating plate. (The model/serial rating
plate is located on the oven door or on the oven
frame.)
Models rated from 7.3 to 9.6 kW at 240 volts
(5.5 to 7.2 kW at 208 volts) require a separate
40-ampere circuit. Models rated at 7.2 kW and
below at 240 volts (5.4 kW and below at 208
volts) require a separate 30-ampere circuit
Nov 15, 2008 | KitchenAid KEBC207 Electric Double Oven
Need exact model No for JKP85 Double Oven
unfortunately there are hundereds of ge microwave/oven combs that start with jkp85. do you know what part hes looking for? some parts are more common than others. i have many sources for part number if i know what he needs i can try to give you the number
Nov 25, 2007 | GE JKP85 Electric Double Oven
Ovens Logo
37 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
