I have a whirlpool 6th sense front loading washing machine model awo/D 7508 CLEAN PUMP KEEPS showing opened cap to let out water under front door nothing stuck also layed it on its front disconnected black hose from bottom of drum and hose from pump to outlet fiddeled around and nothing maybe i have to take out pump for better inspection how do i check it it stops at 17 mins before end sometimes and 6mins am i barking up the wrong tree and maybe its not the pump that it maybe electronic prob how do check
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
Get a wet-dry vac and **** it clear from the end of the drain hose.
Posted on Nov 05, 2012
3 Suggested Answers
  • 82 Answers
SOURCE: hotpoint aquarius 1200 washing machine leaking
this could be
1 door seal
2 heater ellement
3 front plate
4 front plate seal
5 outer container split
try looking at these first
Posted on Jun 28, 2009
mnwarfield10
  • 452 Answers
SOURCE: Whirlpool 6th sense washing machine doesn't go into high spin
sounds like you have a blocked hose/pump vent hole.......if its holding water in the bottom of the tub it wont spin it will try but the pcb wont let it do the spin .due to pressure switch telling its got water left... pull pipe off pressure switch check holes not blocked check all hoses......
Posted on Dec 30, 2009
Can't open pump
Dear Sir :
See the diagrams and proceed accordign with common sense.
God bless you
May 13, 2012 | Whirlpool AWM8143 Front Load Washer
Whirlpool AWOE 9559B 1200rpm 6th Sense Washing Machine, 9 kg instruction book lost; can you provide me with a copy please
Morning, Your model number does not come up. It is located on a front loader behind the door, top loader under the lid. GE right side at front bottom of case. Will await your answer. Thanks
Jan 23, 2011 | Washing Machines
Whirlpool AWO/D 4605 Clean Pump light on, how do I
Remove bottom plastic panel across the front of machine- it just clips off (use a small screwdriver or bread knife to prise off). You will now see a round filter behind this panel- unscrew anticlockwise to remove- this is the filter. Sometimes filter can be hard to remove if you have things jammed in it- give it bit of a jiggle and it should come out without forcing it. Remember- if there is still water in the machine, this water will come out on the floor once you remove the filter- put down some towels!! Happy fixing!!
May 11, 2010 | Whirlpool AWOE8748 Front Load Washer
I have philips whirlpool awo/d 4605 model and its showing a light clean pump where do i find the pump???
The unit front portion either right side or left side you will find the small door you just open the door and remove the filter in anticlockwise direction it will come out just clean the filter and then close it safely
If you want to clean the pump you are suppose to open the back door of the unit and trace the outlet valve it will be connected to the pump after finding the pump just remove the hose from bothe side of the pump and clean the drain pump neatly and refix it
Jan 05, 2010 | Whirlpool Washing Machines
Dec 30, 2009 | Washing Machines
WHIRLPOOL WASHING MACHINE AWO/D 5716 - CANNOT LOCATE PUMP
Remove the bottom casing covering the front of the machine just above the floor. Unscrew the circular cap SLOWLY- beware of vast amounts of water escaping though!
I had to use a low height roasting pan to catch water, and just unscrew the cap enough so as to control the flow of water, and enable to empty water away until its all gone. Incidentally, an old hairgrip was found to be the cause of my problem.
Confusingly, "clean pump" meant clean filter!
May 19, 2009 | Whirlpool AWM8163 Front Load Washer
Clean pump light is flashing where is the pump so i can clean it
The pump is located in that bottom compartment under the door. There are two screws that you need to take out located in that tiny little opening and the panel will come right off. The pump is right there in front. Let me know if you have any other questions and let me know if this was helpful for you. Good luck and I am glad I could help.
Jan 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool 6th sense front loader awm 8121
my whirlpool 6th sense will not start all lights and power i think that it is the door sensor at fault? The green light door locked light is not on.
Jul 18, 2008 | Whirlpool AWM6100 Front Load Washer
Clean pump!
remove bottom panel torx or 7 mm nut driver needed.pump has "knob" turn counter clock wise ..have plenty of towels handy to unlock door first reach up to bottom of door lock tear shaped plastic tab pull down door will open
Apr 26, 2008 | Whirlpool AWM8143 Front Load Washer
Washing Machines Logo
174 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
