Question about Packard Bell Computers & Internet
Hdd not on boot list
My laptop will not boot up and when i go into my boot up list my hdd is not there but in bios it says it is supposed to be top of the list is my hdd knackered
  • Packard Bell Master
  • 7,627 Answers
Have you tried a cold start, unplug, remove battery, hold down on/off button for 10 seconds, replace battery, plug in try to start normally. If that fails open your laptop, remember to remove battery, and Re-Seat, remove and replace the HDD. If that fails take the HHD out and have it checked by a qualified Tech. You can get devices to connect your HHD to another computer via USB, mine is a ULTRA USB 2.0 to IDE/SATA Cable Adapter. Then you can verify if in is dead.
Posted on Nov 04, 2012
3 Suggested Answers
yngwei50
  • 134 Answers
SOURCE: AA1 will not boot- PXE-E63 error- help!
It happens when no boot device is selected, the default is network boot first, you must select CDROM/DVDROM or HD as your first startup device.
Posted on Oct 21, 2009
Testimonial: "This answer was very helpful in confirming what I suspected the problem was. Thanks a million for the quick response, and the offer of additional help"
  • 51 Answers
SOURCE: won't boot from hard drive
Check the boot settings. The bios may be trying to boot the old hard drive and doesn't even see the new one. If the old hard drive was removed, the BIOS will go to the next boot device. Also, is there something on the hard drive to boot to? If it is a blank hard drive you will need to install an operating system, otherwise it will not boot.
Posted on Feb 25, 2010
How do i get my HP Pavilion dv4 laptops hard drive to work
Start up and enter the bios. Check the hdd is listed as the first boot drive. Check the hdd is bootable.
Apr 18, 2016 | HP Pavilion Computers & Internet
How do I add Boot devices to Boot Menu on Acer V5-122P which only shows the internal HDD
Because this is one of the thin client laptops all you have in the laptop is a Hard drive. and other boot device is a USB device that you plug in. As such the bios will not show it until it is plugged in and then you can select it to boot from.
Feb 10, 2015 | Acer Aspire V5-122P-0864 11.6" Touch...
I have an Acer TravelMate 4500 512Mb Ram an 80GB HDD, which doesn't run the operating system boot after bios boot. when I swich on it comes up a bios boot and after that the laptop screen's becomes...
1. Remove or Unplug any recently added hardware.
2. Remove and replace the battery.
3. Press and hold the power button for 7-10 secs to power ON the computer.
4. Try booting to windows Operating System in Safe Mode. (Press F8 key as soon as you restart).
5. Check if the Hard Disk is detected and listed with its capacity of 80GB in BIOS. (Press F2 as soon as you restart).
6. Reset BIOS to default values.
7. If computer boots to windows in Safe Mode, then perform a system restore to an earlier date.
8. Install any updates available for BIOS.
9. If Hard disk is listed in BIOS, perform system recovery using the recovery partition or the recovery discs.
10. If Hard disk is not listed in BIOS, contact any nearest service center to get the computer serviced.
Jul 23, 2011 | Computers & Internet
Whenever I turn on my laptop the screen is blank with a white dash mark flashing in the top left corner of the screen. What do I do?
That is the signal that the BIOS no longer finds an operating system installed on the hdd. All you are left to do is to reinstall it. Use the recovery disk that came with it.
Jul 05, 2011 | Acer Aspire 6920 Notebook PC
I have an Eee PC1000HE Netbook in the BIOS (Boot) it shows 3 items - which are Removable device, HDD:PM-ST9160310AS and ATAPI CD-ROM (underneath the list is "Disabled" I understand that what...
hold the f2 key when you start your laptop.
it will bring you to the bios setup screen
from there you can go to advance tab i believe and look for the boot list or boot devices
there you can enable the boot for the hdd.
Mar 20, 2011 | ASUS Eee PC 1000H Laptop
Sir my laptop is does not start. error ir operating system not found.
If the laptop does not find the operating system on boot up it's ether the HDD has failed or the Operating system is corrupt the only answer is to reinstall the operating system or change the HDD.
You could try getting into the Bios on boot up normally by pressing F12 after pressing the power on button and checking if the laptop is seeing the HDD.
I say F12 but without knowing the laptop model it's a guess.
It should tell you on the boot up screen which function key to press to enter the Bios.
Once in the Bios check to see if the HDD is listed if it is the laptop is seeing it so it should be a simple matter of reinstalling the OS if its not then the HDD is faulty you will need to replace it and reload the OS.
Sep 12, 2010 | Computers & Internet
Oct 21, 2009 | Computers & Internet
Replaced hdd on emachine w3615,light on mobo but it wont come on.
Hi ipackrat21, that little green led you see is telling you the motherboard has standby power. (Its supposed to be green & on).
Make sure the hdd jumper is set to, master without a slave). In a one hdd system.
When you replaced the hdd you also need to enter the bios menu.
In the bios you'll need to make some changes. First you should see the new hdd listed in the bios. (Normally it list the hdd by model). If your hdd is shown than go to the title "BOOT". You need to set the boot order. A normal boot order would list like so;
First boot device, Floppy disk drive".
Second boot device, "CR-ROM" drive.
Third boot device, "Your new hdd".
If your bios does not see your hdd you'll need to re-check the data cable from the board to the drive. (Make sure it is fully connected).
If the drive is an IDE/PATA make sure it has power. A 4-pin molex.
010e000.jpg Good luck ipackrat21!
Still have trouble, post it here.
Mike
Jan 14, 2009 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Acer TravelMate 4200 Laptop
there are two posibility,
your hdd don't have operating system
or your hdd isnot detected.
check in bios, check if your hdd is there.
Jul 31, 2008 | Acer Aspire 5500 5570-2609 Laptop
Toshiba laptop
You don't have a USB thumb drive plugged in do you? Remove any discs ( CD, floppy etc ) & check the BIOS boot order to start with.
Apr 18, 2007 | Toshiba P25-S670 Notebook
Computers & Internet Logo
77 people viewed this question
Top Packard Bell Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Tony
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
