Question about Kenmore 24032\24036 Top Load Washer
Kenmore series 80 12 years old
Hot water going in on normal speed cold water barely dripping in any water on any and all cycles can you help please
  • jgovernale Jan 05, 2009
    Thank you Tom and May God Bless you as well...We are following your instructions now and hoping it works. Happy New Year
    Tom We are so happy it worked and it was exactly what you said you saved us lots of $$$$ thanks again and God Bless John
    Sergeant:
  • 311 Answers
Hey thats eazy.your washer has a water fill valve.the two black hoses go to it in the back.inside the valve where the hoses attach their are screens that keep minerals from going into the water valve.also some have screens on the other side off hose too,and after cleaning run the water thru the hose into the drain/sink because minerals may be backed up in house line or hose.If dosent improve after this its in your water valve and theres nothing you can do but replace the water valve they dont come apart for cleaning,or could take apart but looking for trouble because wont then seal and will over flow on to floor.you can do it .God bless ,tom
Posted on Jan 04, 2009
I have a MAYTAG legacy Series manine. That i just bought from a retailer. My machine is connected to a cold water tap. can i still get a hot water wash if i select a warm or hot cycle? Secondly,...
hello bz... there can be no hot water wash or hot cycle without hooking up a hot water supply line. Also, you must plug that hot water inlet, the correct plug is available at most hardware stores. Finally, yes it is normal for the machine to stop before draining, as the transmission shifts. If the machine is very noisy, that is not normal. To reduce that noise you could put the machine on a piece of thick carpet to deaden the noise a bit. Joe
Thanks for choosing Fixya!
Feb 25, 2011 | Maytag Legacy Series Top Load Washer
I have a Kenmore Series 80 Super Capacity Plus Washer. It has 3 water temperature settings, Cold/Cold, Warm/Cold, and Hot/Cold. Warm is Cold and Hot is barely warm. I know I have very hot water as the...
Sorry to read about your problem, I hope this helps you out.
the inlet valves just open and close, if you have high cold water pressure, it will override the hot water. I suggest you turn down the cold water valve, until warm is kinda warm. your cold water fills will take longer, but you will have warmer water
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 30, 2010 | Kenmore 24032\24036 Top Load Washer
Hot water use on a cold /cold cycle
I bleive hot water in introducted @ begaining of cyle to disolve deterant call whirlpool 800 number .
Oct 26, 2009 | Kenmore 43142 Front Load Washer
Kenmore top load water temp switch problems and hot water rinse
Hi, Switch the hoses around going to the mixer/inlet valve. I am sure this will take care of the problem.
If not, please let me know so I can assist you further.
Vic
Jul 01, 2009 | Washing Machines
No cold rinse, only hot
Either the wires have come loose on the water valve or you have a defective water valve.Open the lid and look at the water valve. Are all wires connected?
If yes, replace the water valve.
Jun 24, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Cold water pours in during final spin
No - the timer is the likely suspect.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
Hot water goes into cold water washes
It is normal for the machine to cycle between hot and cold water when filling even if selecting a cold cycle. The reason for this is because even a cold cycle requires the water temperature to be 78F for the soap to break up efficiently.
During the cold months the water in your pipes is probably less than 78F so the machine will need to add some hot water to bring it up to this temperature. Basically, it is adding cold and then hot water to maintain a temperature in the tub of 78F for cold water cycles.
Hope this helps, please rate my solution.
Jan 12, 2009 | LG WM-1832C Front Load Washer
Kenmore 80 series washer make high pitched whining noise
cold water screen in hose was half plugged causing it to either shut off the spin cylce due to lack of water or increase the spinning speed.
Hope this solves the problem.
Dec 10, 2008 | Kenmore 24032\24036 Top Load Washer
Your transmission is not engaging thats why the speed changes your making will sometimes get it to work.Honestly any machine after the 10 year age mark is not worth the cost of replacing the transmission.
Apr 15, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
44 people viewed this question
Sal De
fordexpert
Robert Rankin
