Question about Whirlpool Duet Steam WFW9700V Front Load Washer / Dryer
Duet steam dryer soaking my clothes - Whirlpool Duet Steam WFW9700V Front Load Washer / Dryer
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
You will need to replace the "water valve" on the unit. The solenoid is letting to much water thru. Here is a link to the part to order.
Posted on Nov 05, 2012
4 Suggested Answers
  • 662 Answers
SOURCE: the clothes in my duet washer come out soaking
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
On some models the filter is located ‘inside’ the big hose from the bottom of the tub. This takes more time to clean.
Pl rate me ‘very helpful’ for the free help!
Posted on Jun 13, 2010
SOURCE: duet steam dryer soaked clothes and had alot of
Turn off the water or disconnect the water hose to your dryer.
Call your serviceman and tell him to order a new water solonoid for your dryer.
You can dry without the water hooked up to the dryer.
The steam cycles, however, will not have steam due to the absence of water.
Posted on Apr 01, 2011
SOURCE: My dryer is making my clothes soaking wet every
Same problem here....I have had my brand new Whirlpool Duet Steam front load washer for a whole 4 days... It has worked perfectly until now. I checked on the clothes because it seemed like they just kept going and going... they were soaking wet!! When I took the clothes out the dryer had a huge puddle of water in it..Can anyone offer any help?
Posted on Jan 02, 2011
My Whirlpool Duet DRYER--the clothes are wetter than when I put them in & there is now water sitting in the bottom. It does have a steam setting, but I'm not using that one. It's 4 years old.
Check your exhaust vent! If you have an obstruction, the steamy air will have no where to go, then your air-conditioning temps inside can cause the water to condense in the vent tube... Even if the vent is just open to the hot summer air and the clothes sit in the machine the difference in temps between inside and outside can cause these symptoms...
Jul 25, 2016 | Whirlpool Duet High Efficiency Gas Dryer...
Whirlpool gas dryer doesn't dry
Make sure vent hose in back of dryer is not blocked or stopped up.
Mar 16, 2014 | Whirlpool WGD94HEXR Duet Steam Dryer gas
My whirlpool duet dryer works but it appears that the air is not evacuating from the baril. The heat and humidity built up and the clothes don't dry. Do I need to replace the fan and if so, how
YOU NEED TO CLEAN THE VENT ON YOUR HOUSE IF THE BLOWER WHEEL IS BAD ON THE DRYER YOU WOULD HERE THE NOISE AFTER THE DRY STOPS THE BLOWER WHEEL WILL STILL TURN AND MAKE A NOISE
Oct 29, 2012 | Whirlpool Duet Steam WFW9700V Front Load...
Dryer leaves mark on clothes
Clean dryer soak a towel in water and bleach , put towel in dryer and dry it it will claen the inside of dryer worked when we had pen marks in ours made the clothes blue has to do it twice
Mar 22, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My whirlpool duet steam dryer appears to be stuck on the steam cycle. I put in a load of clothes that were barely wet and now they are soaking wet. The heating element is working but they are still...
Hello, Thank You for using FixYa. I will be helping you today.It can be a stuck relay to the water valve or a water valve that is not closing all the way. Put a towel across the bottom of the drum a few hours and see if it gets wet when the unit is not in use if so the valve is stuck open and needs to be replaced.
Thank You and please rate my answer if it was helpful..
Jun 27, 2011 | Dryers
Duet steam dryer soaked clothes and had alot of water setting in drumclothes were dry and wrinkled when i put them in the dryer 5 minutes later they were soaked.
Mar 23, 2011 | Whirlpool Duet Steam WFW9700V Front Load...
My dryer is making my clothes soaking wet every time I put clothes in. How do I turn the warer off on the steam mode (I guess)
Sep 30, 2010 | Whirlpool Duet Steam WFW9700V Front Load...
Whirlpool Duet Dryer WED9600 Beeping during drying
Dear Customer
Please perform the following
please rate this,thank u
Dec 16, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet Steam WFW9700V Front Load Washer / Dryer Logo
449 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
