Question about Thermador SC302T Electric Double Oven
Thermador SEC302 with error F51
Tried to self clean the oven today but the error code F51 came up and it looks like it has to deal with the oven not locking. Is there a quick fix or reset that can be done? I already tried turning off the circuit breaker.
5 Suggested Answers
plnolte
  • 62 Answers
SOURCE: My thermador oven tells me error code 14
Sometimes you can unplug the unit for at least 30 minutes and reset the unit and it wont do it again.Try that first. An error code on a thermador of 14 means latch switch problems.
Posted on May 12, 2009
EllaWatson25
  • 725 Answers
SOURCE: Thermador Oven SMW272 will not self clean
You need a new control board on this unit. Once the self clean goes out, your oven will soon go out and you will not be able to cook. We have parts for Thermador ovens so please give us a call at 972-859-0929 and we will ship the part out to you right away. It's so much less expensive if you repair it yourself rather than calling a service company out. AND you will be ready for all your winter meals to be hot and delicious! We look forward to working with you and hope to hear from you soon.
Posted on Oct 05, 2009
heatman101
  • 43501 Answers
SOURCE: oven door remains locked after self-cleaning
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Posted on Apr 28, 2010
SOURCE: Fan works, but Oven stays at 100 degrees. Tried
On my C301 U, I found the brown connector on the right side of the oven control board P3-2 loose. It looked connected but while doing a shake test- Whoop, there it is. It is the sensor for the temp probe. If it's loose all the fans run all the time.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=C301U&productCategoryId=0124100&brandId=1085&brandDescription=THERMADOR&modelName=BUILT-IN-OVENS&diagramPageId=00014&componentDescription=WIRING%20DIAGRAM&documentId=U2500861&blt=06
Posted on May 23, 2010
What causes error messages f50 and f51 during oven cleaning?
Door is not locking as part of cleaning cycle.
Feb 11, 2016 | Thermador Ovens
THERMADOR MODEL SEC302BP installed in 2006. I am getting a infrequent error code of F-64. This double oven has already been recalled due to the self cleaning mode starting a fire. do I need to pay a...
You may have to pay a service technician out to fix this issue, if the update insulation kit was already added this could be causing the issue depending on if it was installed correctly.
This error code has to do with the air flow the fan is could have failed as well, the hall sensor that is built into the fan motor will often fail creating this issue.
http://www.appliancerepairlesson.com/
Mar 06, 2011 | Thermador SEC302 Electric Double Oven
I am getting an F64 on my thermador electric double wall oven after a few minutes of preheating my upper oven, and the oven turns off. What des this mean?
Hi, i found out from Thermador customer service that error code F64 means that the lower fan switch (located inside the bottom trim on the right side) is not being detected as closed. In my case, this was because the header (P4) on the Display panel had broken loose from the PC board and was no longer making contact. P4 is where the lower fan switch wires connect to the control boards (actually the display panel).
Jan 05, 2011 | Thermador SEC302 Electric Double Oven
THERMADOR OVEN FALSHING SELF CLEAN PROBLEM-CODE E126 - HOW DO I SOLVE
Sorry to read about your problem, I hope this helps you out.
you have a latch switch error code,
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 25, 2010 | Thermador Ovens
Describe your Thermador CT 130 C problem. Not heating up properly after we used self-cleaning feature. We have noticed that it is only heating up to half the temperature that it was set to.
Welcome to FixYa.
You have not mentioned if the oven has displayed any error code so I will take that for what it is...there was none shown.
With that, the post heading has conflicting info about your model so I'll go with the most common based on the SEC302 ovens.
I`d start by looking for an over-temp cut-out tripped. Since this problem started following a self clean cycle, it leads me to believe it is just that.
Here`s what and where to look for for this,
Fortunately if it is tripped, they are the manual reset type and are accessible behind the black grill/vent just above the door and just below the control panel next to the lock latch assembly.
**Turn off the 40amp breaker at your service panel or sub-panel in the home before attempting any service...safety first**
With the power off, you should be able to remove the grill and push the red button in the center of the thermostat and that should fix your problem...as shown here,
macmarkus_108.jpg If indeed the hi-limit is tripped you`ll know immediately because you`ll feel it click as you push it down. It will look like the image below...
Ultimately it could be a faulty relay board or related to the timer, but I`d start with the hi-limit cut-out tripped first.
If the images I attached are not clear or you just want more info, I can send you a complete service manual in a "pdf" attachment, however you`d need to provide an email address to where I could send it to you.
Other than that if you call in a pro just be sure they are an authorized B/S/H/ service provider ( B/S/H/ is the parent company for Bosch, Thermador, Gaggenau, Siemens products ).
Let me know and I`ll watch for your reply and respond as soon as I can. Good luck.
Regards,
Macmarkus :)
Dec 20, 2010 | Thermador SEC302 Electric Double Oven
How do i self clean
WASHINGTON, D.C. - The U.S. Consumer Product Safety Commission, in cooperation with the firm named below, today announced a voluntary recall of the following products. Consumers should stop using recalled products immediately unless otherwise instructed.
Name of Product: Thermador� Built-In Ovens
Units: About 37,000 (42,000 built-in ovens were previously recalled in June 2007)
Manufacturer: BSH Home Appliances Corp., of Huntington Beach, Calif.
Hazard: The ovens can have gaps in the insulation where overheating can occur and when used in the self-cleaning mode it can cause nearby cabinets to catch fire. This poses a fire hazard to consumers.
Incidents/Injuries: BSH Home Appliances has received three additional reports of incidents, including two that resulted in fires that damaged surrounding cabinets. No injuries have been reported.
Description: The recall involves Thermador Brand built-in double ovens with model numbers C272B, C302B, SEC272,C301U, SEC302, SECD272 and SECD302 and serial numbers between FD8403 through FD8701. Model and serial numbers are located on the underside of the control panel.
Sold at: Appliance and specialty stores nationwide from June 2004 through July 2007 for between $3,000 and $4,400.
Manufactured in: United States
Remedy: Consumers should immediately stop using the oven�s self-cleaning mode and contact the firm to schedule an inspection and free repair, if necessary.
Consumer Contact: For additional information, contact Thermador at (800) 701-5230 24 hours/day, 7 days/week, or visit the firm�s Web site at www.thermador.com
Dec 05, 2010 | Thermador C301U Electric Single Oven
Self-clean turns off after 5 minutes with F2 error message
Hi MaryB,
F2 error code means that the oven temperature is too hot. You will have to replace relay board if faulty. Check and replace oven temperature sensor (RTD). If failure repeats, replace ERC (electronic range control or clock).For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Apr 15, 2009 | Thermador C272 Electric Double Oven
Open Questions:
See all Thermador SC302T Electric Double Oven Questions
Thermador SC302T Electric Double Oven Logo
259 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Thermador Oven Expert? Answer questions, earn points and help others
