Question about Cell Phones
Antenna missing the top cover came off my nokia 6102i cell phone. then the piece that i think is the antenna popped off and cant be found. i cant make calls. how can i make sure i am identifying the missing piece correctly and get it replaced?
    Problem Solver:
  • 4 Answers
Mine came off several times along with the plastic housing. I glued it back in place with 5 minute epoxy. Make sure the metal contacts engage properly and that your signal strength is at it's highest level before you apply the glue. Mines been going 3 years since glued
Posted on Feb 10, 2010
How do i fix from offline to online
Hi Ameyaw, I think you're asking for the link below, I hope it helps mate.......CHEERS..
How To fix any Android Phone Tablet that won turn on
Apr 17, 2016 | Nokia 1661 1680 2135 2600 2680 2760 2865I...
Unlocking a 6102i
#pw+138144454613345+1#
#pw+404347723205042+7#
> remove your sim and type the code 1 above then if code error try code 7... you only have 5 tries if code error still appears it means you need to unlock it by cable...
> to type "p", "w" and "+" try to type * several times...
Jun 19, 2009 | Nokia 6102 Cellular Phone
How would i fix my nokia 6103?
Get a T6 screwdriver, remove the battery cover, battery, and sim. Next, gently pop off the antenna cover at the top of the phone exposing 2 of the 4 screws in the back of the phone. The other two screws are already visible near the bottom of the battery compartment.
After the 4 screws are removed, carefully use your fingernail or small flat tool to seperate the back of the phone (D housing) from the keypad housing (C housing). Once this is seperated, you will see the back of the main motherboard. Lift up on the board gently from the bottom. You will notice that at the top, the main cable plugs into the board. GENTLY unplug this cable. Be very careful not to damage the plug or the channel.
Once the cable is free, the board will pretty much fall out of the phone. On the back of the phone (the one with all the heat shields) - you can pop off the heat shields with a small screwdriver or knive CAREFULLY!!!! Remove them all. Look for any signs of corrosion, especially at the top and top right. This should be right above the battery contact terminals. This is where your RF modulator is.
Brush the entire back of the board with 91% rubbing alcohol and a soft to medium bristled toothbrush.
Also, make sure your phone still has an antenna. Sometimes, if this model phone gets dropped, the antenna cover will pop off and the antenna will go flying (just snaps into the back housing). Many people pick up the cover and snap it back on, not realizing they are missing an antenna. To see what the antenna looks like, go to ebay and search for a Nokia 6102i, or 6103 antenna. If your phone does not have this part, order it, snap it in place so that the little metal contact will touch the main board and you're good.
If you do have this part in place, then continue with the alcohol bath. Also, on the front side of the board, you will notice a white sticker which retains all the surface switches of the phone. You can very carefully peal this off exposing all of the contact surfaces for the switches. Make sure this is clean as well.
Dry the phone with a hairdryer. (Rubbing Alcohol evaporates fast, but it lingers longer under the chipsets so it is good to bring the temperature of the board up to speed up the process). A hair dryer won't get it hot enough to do damage.
Once you are sure all the alcohol in the phone is dry, reassemble the phone in reverse order of the way you took it apart.
Let me know what you find out after performing the above steps. If you find severe corrosion, email me. daelmyth@yahoo.com
Sep 08, 2008 | Nokia 6103 Cellular Phone
Need a restiction code for a nokia 6102i
hi,
To unlock your Nokia 6102i, fill in the fields in this website http://www.deblocage-nokia.com/debloquer-nokia-6102i.php and confirm your order. You will then be directed to the official site Paypal to proceed to settlement under secure environment.
You will receive an email indicating the availability of your code immediately after receipt of payment!
Sep 04, 2008 | Lands Phones
Need unlock code for nokia 6102i locked by att
Need unlock code for NOKIA 6102i
IMEI:359373/00/680497/3
mail me the code to  spandan_babu@yahoo.com
Feb 27, 2008 | Nokia N-Gage Console
Handset settings for nkia 6103
I posted this solution for someone with the same phone with service issues. Follow the same steps to disassemble and clean. The phone has corrosion from the moisture on the backside of the plug on the bottom. This is fooling the phone into thinking that there is a headset plugged in when there is not. Let me know if this helps. And please don't forget to rate. Feel free to contact me via email if you need additional help. Solution #1 posted on Sep 11, 2008 0%20stars.png
noavatar_s.gif Daelmyth
Rank:guru_s.gif Guru
Rating: 87%, 19 votes
Jan 30, 2008 | Nokia 6103 Cellular Phone
Cover change for nokia 7373
Download the Serice manual, google it.
Dec 17, 2007 | Nokia 7373 Cellular Phone
Help setting up bluetooth
Do you have a 6102 or a 6102i ? If you have a 6102 then your phone isn't Bluetooth enabled, that means that you cant use your wireless headset. Take it back to the retailer, kick his ass, and get your money back .. :) If you have the 6102i, the consult your manual or download it here : http://nds2.nokia.com/files/support/nam/phones/guides/6102i_US_en.PDF
Aug 05, 2007 | Nokia 6102 Cellular Phone
6102i
Dear check the signal status if there are no signal then may be the antina tips are not touching with the board on antina pad for this reassemble the phone tight the screws. if signal come and go no come agian then its prob from hardware take is to technician.
Feb 13, 2007 | Nokia 6100
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
