Question about Weedeater 25cc 2-Cycle Gas Blower - FB25
How do you replace the choke lever on a weedeater fb25?
The choke lever broke, no way to use the choke.
My murray weedeater want run off choke why?
Carburetor needs to be rebuilt. I won't even think twice about. the diaphram is on it's way out.
Aug 29, 2017 | Weedeater Garden
Can a gas powered blower be repaired if it was drooped in pool.
it's hard to get it running again...probably it's not worth a try...
- you should open the carburetor, dry and clean it.
then the spark plug has to be removed and dried with a blow torch, also inside the cylinder opening.
then you better buy a can of starter spray to ease a start procedure.
Weed Eater FB25 Handheld Blower Parts 25311960-50ikml0pgld1svv5r0lj5py2-4-0.jpg 25311960-50ikml0pgld1svv5r0lj5py2-4-2.jpg
Dec 07, 2014 | Weedeater 25cc 2-Cycle Gas Blower - FB25
How do I start a weedeater fb25?
Press primer bulb 6 times
Move throttle lever to start position
Move choke lever to full choke position
Pull starter rope sharply until engine attempts to start, but no more than 5 pulls.
Move choke lever to half choke position. Pull starter rope sharply engine runs. If engine hasn't started after 5 pulls, repeat all steps above.
After warming up for 10 seconds, move choke lever to run position.
Manuallib.com has a manual for this model available for free download
Oct 20, 2014 | Weedeater Garden
What fuel do I put in the weed eater gas blower fb25?
Regular unleaded with whatever oil mix the fuel cap has on it.
Try to avoid gasoline with high ethanol content. You can look online and find alcohol-free gas in your area. You wont regret it!
Oct 05, 2014 | Weedeater Weed Eater Fb25 25cc 2 Stroke...
Weed eater fb25 25cc gas blower wont start
change the spark plug--put fresh fuel in gas tank 89 octane mix
Sep 04, 2014 | Weedeater Weed Eater Fb25 25cc 2 Stroke...
My fb25 starter rope won't recoil. how do I fix this please?
has to be taken apart for that, spring probably popped out of its groove
May 30, 2014 | Weedeater 25cc 2-Cycle Gas Blower - FB25
No spark new plug.
make sure the switch is to the on position first. if so you need to change the coil.
Sep 19, 2013 | Weedeater 25cc 2-Cycle Gas Blower - FB25
Weedeater FB25 5months old only used once and was hard to start right from the box. Can't get it to run now. What steps should I take on troubleshooting
This sounds much like poor car settings ( set too lean ) you need to richen up the L and H screw on the carb, unfortunatley there will be anti tamper sleeves on the carb or a special tool reqired to adjust them, turning the screws anti clockwise will richen the mixture if you manage to remove the caps or get hold of the apropriate tool.
Dec 14, 2012 | Weedeater 25cc Gas Blower ()
Choke lever . Can I fix this myself? broke off and
According to the model, maybe JB Weld the choke lever back together and fuel lines are completely replaceable....get 'um at a lawnmower parts/repair shop. They are Tygon lines.
Jun 05, 2010 | Garden
Weedeater 25cc 2-Cycle Gas Blower - FB25 Logo
228 people viewed this question
Top Weedeater Garden Experts
Matt Olenzek
Matt Olenzek
 steve
steve
Darrell
Are you a Weedeater Garden Expert? Answer questions, earn points and help others
