Question about Garden
Alco 46br lawnmower snapped pull rope - Garden
3 Suggested Answers
  • 41 Answers
SOURCE: lawnmower rope pull start, has rewound back into
You will have to take the top off.It has 3 bolts on the sides of the motor.Pull top off,hopefull you just have pull rope out to fix.The rope on the pully has a spring in the bottom of the pully.Do not pull out pully,you will have a hard time gettig it back in.
Posted on Aug 29, 2009
97F350diesel
  • 1326 Answers
SOURCE: starter pull rope broke. how do i replace?
Should be 3-4 bolts right on top of the pull starterhousing, take them off to replace string
Posted on Nov 10, 2009
How to replace the pull rope?
Go to you tube On line on page type repair pull rope on lawnmower
Sep 22, 2014 | Garden
Lawnmower won't spark
check to make sure your safty switch is not engaging causing no spark other than that your coil would be bad but they hardly ever go bad i think your problem is with the safty switch
Apr 13, 2014 | Toro Lawnmower 20099 Mower Mowers Lawn
Have a 2-4 hp lawnmower where the rewind spring and rope was broke. Have put new spring and rope on-works great in housing. When attach it to lawnmower the rope pulls out but won't retract back in. As soon...
When you remove the recoil shroud ( housing ), the square shaft sticking out should move freely in a counter-clockwise direction and you should hear clicks when you twist. If you don't hear the little balls clicking or the square shaft doesn't move freely counterclockwise, then that square shaft is rusted onto the end of the crankshaft and must be freed before it can be removed. This is a common problem for mowers left out in the elements. Sounds like the shaft is frozen onto the crankshaft end. Procedure: First, disconnect the spark plug. Get a magnet ready because 5 little balls are gonna come rolling out on this upcoming move. Take a 1/4
Sep 27, 2013 | Briggs & Stratton Briggs Stratton...
Pull rope will not pull
Remove recoil rope assembly. Ensure rope is properly wrapped around. While recoil assembly is removed use ratchet and socket to rotate fly wheel, remove spark plug first, observe compression and exhaust at spark plug whole during rotation of fly wheel. Clean or replace spark plug. Ensure oil is full. 30w. Set spark plug gap. Always use Stabile in gas. Replace coil rope is required. Purchased by the foot at any mower repair store.
May 12, 2013 | Toro Super Recycler Super Bagger Lawn...
How do i fix the pull start and re tension it so cord retracts?
You take the top of the motor off with the starter, then rewind the spring,then is a good idea to replace the rope with a new one they sell rope at a lawnmower store, get 5 feet or more if the rope is up on the handle, take a piece of rope with you to get the correct size.
Aug 20, 2012 | Electric Earthwise Corded Lawn Mower...
I have a Briggs and Stratton motor on a lawnmower (about 4 hp) and find that when I try to start the lawnmower some time the pull snaps back at me really hard, other times the pull of the rope can be...
You will have to check the key between the flywheel and the crank shaft. If the timing is off it will kick back on you. One more thing to check is that the blade is not loose this will also cause it to kick back.
Jun 13, 2011 | Garden
How do I repair the pull cord on a masport 600 mower - the cord snapped when I was trying to start it.
Hi and welcome to FixYa, I am Kelly
- Remove the recoil assy. Depending on engine model you may hae to remove the air shroud with the recoil.
- Remove the broken rope assy from the spool by lifting the knot out of the hole and cut off the knot.
- Pull the remainder of the old rope out of the recoil spool
- Take the remainder of rope out of the pull handle
On the new rop burn the ends with a match. With wet fingers pinch the ends of the rope while hot/melted until it is the same size as the rope. Form a point on the ends
- Install the new rope in the handle by threading it into the handle and tie ONE small knot on the end of the trheaded through rope.
- Pull very hard on the rope until the new knot seats in the handle. Assemble handle.
- PREWIND the spool in the recoil until it stops winding. I.e. max out spring tension but do not over wind it or you will break the spring. Make sure NOT to wind it in the wrong direction or you will break the spring
- Back off the spool until the knot hole is aligned with the rope guide bushing on the outside of the recoil.
- Either use a C-clamp or a 2nd person to hold the pre-wound spool in place.
-Thread the new rope through the outer rope guide and into then through the knot hole in the spool.
-Tie ONE small knot in the rope and pull it HARD back into the knot hole until the knot seats in the knot hole.
-Release C-clamp or have 2nd person let go of the spool. The rope will rewind into the recoil assy.
-reinstall recoil/air shroud on the engine.
That should get you mowing again.
Thanks for choosing FixYa,
Kelly
Dec 06, 2010 | Briggs & Stratton Briggs Stratton...
Starter pull rope broke. how do i replace?
Nov 09, 2009 | Garden
How to replace the pull cord on a Scotts lawnmower SP6211 Roger
pull the starter housing off, take out the old rope, rotate the starter counter clock wise 5 to 6 times were the to holes line up stick a screw driver throw the holes to hold it in place. feed the same ty-ip rope from out side in throw then tie off. your going to need about 6 to 7 feet. let the pulley pull the rope in
Oct 13, 2009 | Garden
Lawnmower rope pull start, has rewound back into housing and locked? How can I get it to release so that I can reconnect it to the lawnmower handle?
Aug 29, 2009 | Craftsman Garden
Garden Logo
120 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
