Question about Frigidaire FWS1339A Top Load Washer
MODEL FWS6973EWO REPLACE MOTOR BELT - Frigidaire FWS1339A Top Load Washer
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
Here is the belt.
All you do is put it around the transmission and then spin it on to the motor. Super simple!
Posted on Nov 05, 2012
I have a Kenmore 70 series dryer that is not spinning. When turned on u can here the Moter but it won't spin. Belt looks ok.
Is the motor pulley rotating? if it is , how tight is the belt, is the motor pulley turning and the belt slipping? Is the motor weak perhaps, if it is not turning, or has lost power it may need replacing. if it does rotate and the belt is slipping replace the belt and possibly the pulley if you have that option.
Jun 24, 2015 | Kenmore Washing Machines
Quinton treadmill E203 error VSD Lower Board
Quinton E203 Error, Motor Overcurrent (Overload) Probable Cause 1. Obstruction to motor pulleys or belt
2. Disconnected or loose motor lead
3. User outside the weight/speed envelope.
4. Excessive wear to deck/belt.
5. Motor.
6. Lower Electronics.
Corrective Action Quinton Treadmill Models: Club Track 3.0 and Hyperdrive
  1. Inspect for obstruction and remove if necessary.
  2. If the motor did not turn, inspect for loose or disconnected motor lead. Reconnect if necessary.
  3. Restrict users to weight capacity of unit. Restrict use to people that do not move slower or faster then speed setting.
  4. Inspect deck and belt condition. Deck should have a slick smooth surface, free of nicks, grooves, or rough areas. Deck should be flipped or replaced if necessary. Underside of belt should not have a hard glazed appearance. Belt should be replaced when deck is flipped or replaced.
  5. Club Track 3.0 models: Remove power and allow unit to cool for 15 minutes. If unit operates and then error appears again, replace drive motor.
    Hyperdrive models: Remove power and wait for high voltage indicator to go out. Check resistance between motor leads. If the reading is greater than 100 ohms, the motor needs replaced.
  6. Club Track 3.0 models: Remove power and allow unit to cool for 15 minutes. If error message appears immediately, replace the lower electronics.
    Hyperdrive models: Remove power and wait for high voltage indicator to go out. Check resistance between motor leads. If the reading is less than 100 ohms, replace the lower electronics.
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Quinton Treadmill E203 Error Code
Feb 20, 2013 | RTO Stairmaster Clubtrack 510 Treadmill
E203 error message when i press start button
5. Motor.
Jan 09, 2013 | Exercise & Fitness
Quinton treadmill error 203
5. Motor.
Jun 16, 2012 | Exercise & Fitness
Quinton clubtrack treadmill shows E203 code, says drawing more than specified current. Could it be a bad motor?
5. Motor.
Dec 06, 2011 | RTO Stairmaster Clubtrack 510 Treadmill
The belt on my Kenmore washer model no. 110.45091401 is shredded. How do I replace it?
REMOVE BACK PANEL ON FRONT LOAD WASHER PUT BELT ON LARGE PULLEY AND TAPE BELT TO LARGE PULLEY TAKE OTHER SIDE OF BELT AND STRETCH TO MOTOR PULLEY WHILE ROATING LARGE PULLEY WALKING BELT ONTO SMALL PULLEY OR LOSEN MOTOR BRACKET PAY ATTENTION TO LOCATION OF MOTOR BRACKET ALIGNMENT PUT BELT ON BOTH PULLEYS PUSH MOTOR TILL BELT IS TIGHT AND RETIGHTEN BELT
Jan 26, 2011 | Kenmore Washing Machines
How to replace a belt on a washer
On some washers, mostly older models, a belt is used to transfer power from the motor to the transmission and pump. If that belt breaks, the washer will not operate properly but it will make sounds like it is doing something. If the belt slips or is loose, the washer may operate sporadically or erratically. It may make loud squealing noises and there may be a burning smell. Some models use two belts, one for the transmission and one for the pump.
To replace the drive belt, you will need to open the access panel or in some cases tip the washer onto its side to expose the belt on the bottom. Start by removing the back cover, and look for a belt. If you do not see a belt (or a place for a belt - the belt itself may have broken and is hidden from view) and you can see the floor then your washer is a direct drive model that does not use a belt. If you cannot see the floor because there is a steel floor in the washer, locate the motor and determine if it extends through the bottom plate. If so, then the belt is accessed from beneath the washer.
If you have to tip the washer over, place a large piece of cardboard on the floor to protect the floor and the washer's finish. Because a washer is pretty heavy, you will need an able-bodied assistant to safely tip the washer onto its side. Also, there will be some water remaining in the washer, so have sponges and towels ready to clean up any spill.
To remove the old belt unscrew the clamps securing the pump coupling ( a leathery or rubber flexible part that connects the motor to the water pump). Remove the pump coupling to slip the old belt out. Some models instead require you to loosen the motor mounting bolts and shift it inward to relieve tension on the belt. Remove the old belt.
Place the new belt over the transmission pulley first then place it over the motor pulley. If it is too tight, place the belt over the motor pulley's nearest edge and then slowly turn the motor pulley to pull the belt around and into the pulley. Replace the pump coupling or tighten the motor mounting bolts. The belt should deflect no more than one half inch when you press on the longest straight run.
Replace the cover and test the washer for proper operation.
Thanks for using fixya
Regards
PCmania
Sep 27, 2009 | GE WBSR3140DW Top Load Washer
Belt replacement on GE top loader WJSE4150B2WW
Your post shows a model WJSR2070B and a model WJSE4150B2WW but in this case the procedure is the same. Use a putty knife to push in the clips at the top seam of the front panel, where the front meets the top, about two inches in from each side. Tilt front panel forward and lift off bottom pegs. Loosen the four nuts holding the motor with a 3/8 inch wrench so you can push the motor back a bit. Take old belt off. Install new belt (WH1X2026), putting belt around motor pulley, part way on big pulley, then turning big pulley by hand to ride it onto the big pulley. Use one hand to pull motor toward you to put a little tension on the belt as you tighten the four nuts under the motor.
Nov 30, 2008 | GE WJSR2070B Top Load Washer
Dryer belt replacement
To replace the belt, you have to take the front off the dryer and lift out the drum. With the new belt, place it around the drum and with the drum in place put the excess belt through the idler pulley or bracket (depending on your model), then around the motor pulley. You push the bracket or idler arm toward the motor to get the "loop" of the belt around the pulley on the motor. Hope this helps! Paul Hoffmanns
Jun 17, 2008 | Dryers
Frigidaire FWS1339A Top Load Washer Logo
50 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
