Question about LG WM3431 Front Load Washer / Dryer
Drying time After the rinse and spin cycle is finished the dryer shows a time of approximately 2 hours or so. After about 2 minutes the time drops right down to 3 minutes runs and shuts off, and of course the clothes are soaking wet. The unit was purchaced 14 months ago and of course the warranty is expired, even though it was installed only 8 months ago. I am able to set the timer for 2hrs and 30 minutes and that works so I think it is the sensors. Any suggestions on how to fix it.
  • Manuel Gonzales May 21, 2007
    Thanks for your input. I did a Q.C. on the W/D and did not receive any error codes and the machine passed. I found the service manual online, and since the warranty was expired what did I have to lose. I took apart the dryer and condensing duct and found the problem. Since this is a ventless system the lint has nowhere to go. The condensing duct was clogged full of lint. After cleaning it out and putting it back together the machine is working like new. Unfortunately the engineers that built these ventless systems did not forsee the lint problem. I hope this helps anybody else that has this problem.
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
When my washer wasn't drying properly I had to do two things.
1. Clean out the plastic opaque tube thing that goes from the top to the back (its about a foot and a half long). It builds up with lint and doesn't allow the air to flow. take a flashlight and shine it through and you should see the build up.
2. Clean out the heater fan motor on top of the machine. (this one could also cause the dhe error code).
Cleaning the plastic Tube thing...
There are about 8-12 hex/phillips screw that hold this thing together. You will need to remove the fan housing on top (you don't have to disconnect any wires, just un-mount it and rest it out of the way) and start to look for all the connections for the plastic tubing.(there are many that were hard to reach. keep this in mind as we go along) There is a rubber hose connection (compression connection) and a heating sensor (looks like a wire going into a rubber gasket) with a metal rod(about an inch long that you can't see until you pull it out) that you need to disconnect. You don't have the remove the rubber gasket, just pull the metal plate at the back of the gasket. Once you disconnect everything,(hoses, screws etc.) you should have the big plastic tube thing released. Go and clean it out. Now put it back the same way you took it off. Remember how I said to keep in mind all the screws and stuff...... I left two or three maybe more hard to reach screws off because you will be having to do this again in 6 months. (at least thats what I had to do.) try to use as many screws as possible because this thing shakes so much, but don't kill yourself. Also me careful not to over tighten the screws where there is just the plastic as it will crack and break off. You do not want that to happen. Just screw them tightly just not too tight.
Cleaning the fan motor....
this is the pieces that sits on top, it should be black chamber with a circular portion at the end. this is where the fan motor is. unscrew it and open it up. you should see a heat sensor (kind of like the one in plastic tube I mentioned above) at the front, a bunch of heating coils and the fan motor at the end. You will not be able to remove the fan from the motor itself (at least I couldn't) so you will just have to clean it as best as possible. Make it to the circular fan move as freely as possible. then just put everything back as normal....
I hope this helps.
Posted on May 19, 2014
  • paicrag May 19, 2014
    Oh... to answer the actual question.... The dry stops because it thinks everything is dry, because the sensors are not sensing the moister.
Yes what you have to do is go to compact appliance.com. Then type in the model number.At the bottom of the page click the instalation tab and then click the service manual highlited area. Go to page 25 and it is in the condensing unit were the build of lint is located, this build up throws the sensors off. I did not have to replace any sensors, just had to clean it out and put it back together. Hope this helps if not let me know. Cheers
Posted on Apr 06, 2008
I have the same problem. Can you be more specific as to where the lint build up was?
Posted on Apr 05, 2008
  • KSDPDR Apr 05, 2008
    I currently have the same problem, can you be more specific as to what part of the condensing chamber the lint built up?
    Problem Solver:
  • 11 Answers
You need to find and replace the moisture sensor in the unit.
Posted on May 20, 2007
Have a WDL540 can you explain the symbols on the right hand side of the machine has mins and other symbols. Don't have an instruction book. A wash takes 2 hours at 40 degrees its too long.
Do you mean a Hotpoint Aquarius WDL 540 washer? The wash cycle timing is available in the manual on page 8 of the manual (see link below). A normal-sized cottons wash at 40 degrees C takes about 150 minutes (2 1/5 hours) if you have good water pressure and do not use too much detergent. The coloreds cycle is shorter (just under 90 minutes). The indicator lights on the very right hand side (in a downward slash pattern) give the cycle status information. The top light is wash, and the next one down is rinse. The rest are Spin, Dry and End of Cycle. See page 7 of the manual. The function buttons, below the wash temperature and drying time/humidity selection knobs, are from left to right: Super Wash, Extra Rinse, Mini Load, Slow Spin. These are given on page 9. The dryer dial gives you the choice of selecting a dry time from 40-180 minutes or by humidity. The humidity options are Iron (leaves clothes slightly damp), Hanger (ready to put away) and Cupboard (to dry heavy items like towels to a very dry stage). Note the dryer can't manage as large a load as the washer function does. You may need to split the load after doing the wash.
The manual for the WDL 540 is available on the product page: https://www.hotpoint.co.uk/appliances-1/washer-dryers-3/hotpoint-aquarius-wdl-540-p-.c-washer-dryer-white/F064656/ . The picture of the washer shows the function buttons when you zoom in on the control panel. The direct link to the manual is http://docs.hotpoint.eu/_doc/19512781900_GB.pdf .
I hope this helps.
Feb 02, 2018 | Washing Machines
Our whirlpool wfs1285aw doesn't seem to be spinning and drying out clothes enough when Finished. The clothes are still drenched. Any ideas how to rectify this? Is there a filter that needs cleaning?
the rinse section spins slow while the rinsing is in process as this does 2 things
spreads the water through the clothes for a proper rinse
spins slow to equalize the cloths around the bowl
when the rinse cycle is finished and the tap is shut off it goes into a high speed spin
Your problem sounds like the program is not going to the high speed spin cycle and that would indicate a problem board
call a technician for a proper diagnosis and quote
Sep 15, 2016 | Whirlpool Washing Machines
My Zanussi WJD 1257 washer/dryer's drying cycle has started finishing early. No error codes. The wash cycle works fine but the drying cycle is simply stopping prematurely. You can set it to dry for 45...
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 01, 2013 | Zanussi Washing Machines
Hobart LXIH stuck in Wash mode after running multiple loads. Shutting off breaker for several hours fixes problem until multiple loads have been run again and then it is once more stuck in Wash mode.
How long does it stay in the wash cycle? Indefinitely? Does the display continuously show "WASH"?. If it stays in the wash cycle indefinitely (i.e. continuously shows "WASH" for significantly beyond approx. 3 minutes), it's probably a control board malfunction. If it continues to wash after the "WASH" indicator goes out, it could be a shorted wash motor relay on the relay board or a fauly control board.
If the internal rinse water booster heater doesn't reach it's programmed setpoint temperature in time, the dishwasher will run an extended wash cycle to give the booster heater more time to finish heating the rinse water. If this is what's happening, the wash cycle would last approximately 3 minutes, then it would rinse regardless of whether the booster heater has finished heating or not.
The booster temperature thermistor may be bad, giving a false booster temperature reading, causing an extended wash cycle as described above. The booster heater elements or contactor may be bad, preventing the booster heater from heating and reaching proper temperature, also causing the same extended wash cycle to give the booster more time to heat.
Jan 06, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
On a 40 minute drying cycle, it will have to be restarted two or three times to finish the drying cycle.
take the exsaust off the back of the dryer and dry a load
what happens does it dry better?
Aug 24, 2010 | Kenmore 700 6972 Dryer
Washing cycle stops before finishing
Hello, i have exactly the same problem. Did you find the solution?
Thanks
May 24, 2010 | Zanussi ZWD12270 Front Load Washer / Dryer
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Clothes still wet aftre drying cycle over
It sounds as if the wash cycle isn't terminated by pumping the rinse water out and spinning to rid the clothing of most of the water.
Most dryers sense moisture but I think they all will have a maximum run-time to prevent possible fires if the programmer fails to shut them down at the end of the drying cycle.
I would watch the machine and when it started the drying cycle, I would shut it off and check for surplus water that hadn't been pumped out as it should have been.
Feb 03, 2009 | Bosch Logixx WFT 2806 Front Load...
Open Questions:
How to resolve "PF" power failure on an lg WM3431HW Hello, I have an LG WM3431HW which is a combo washer/dryer. It is around 4-5 years old. It was working fine, then recently after completing the washing cycle and after a few minutes after the start of the dryer cycle. The dryer cycle shuts off without error (power to unit still on). We opened up the top and cleaned out all the lint caked on within the dryer duct and made sure lint trap off drain pump in front was cleaned. We started again and received a DHE error. We confirmed the dryer element was heating up fine. We also tested continuity to through the dryer thermostats and it had continuity. Also confirmed appropriate voltage over dryer element. We then took dryer duct fan off, turned it upside down and re-connected to make sure it was turning properly. It seemed to start and stop and it was also very hot so we thought there was a problem with the fan so we replaced the fan, and to be safe, also replaced the thermostat. Once that was done, a few seconds after the unit goes into the dry cycle, the cycle stops and shows a "PF" power failure error. We checked all connections we can find but everything looks connected correctly. We eye-balled the power board to see if there was any burn spots or anything else noticeable but nothing. We also eyeballed the power filter for the same but nothing looked out of the ordinary. The heating element was hot and confirmed the dryer fan duct was revolving, albeit for a short time. It seems that there is something tested after the heating element is started and the fan revolving, that is not working and which is telling the unit to shut off or "power failure". We had also unhooked the dryer thermistor to see if anything looked unusual but looked fine and re-connected. What else can I check and what part is likely to be at fault ? Since the wash cycle runs fine, I am hoping the power board is fine. Thanks
Jul 16, 2014 | LG WM3431 Front Load Washer / Dryer
Additional details: Questions with more than 25 words are more likely to be answered well. 0 chars Your Question Preview No product selected LG WM3431 Front Load Washer / Dryer How to resolve "PF" power failure on an lg WM3431HW Hello, I have an LG WM3431HW which is a combo washer/dryer. It is around 4-5 years old. It was working fine, then recently after completing the washing cycle and after a few minutes after the start of the dryer cycle. The dryer cycle shuts off without error (power to unit still on). We opened up the top and cleaned out all the lint caked on within the dryer duct and made sure lint trap off drain pump in front was cleaned. We started again and received a DHE error. We confirmed the dryer element was heating up fine. We also tested continuity to through the dryer thermostats and it had continuity. Also confirmed appropriate voltage over dryer element. We then took dryer duct fan off, turned it upside down and re-connected to make sure it was turning properly. It seemed to start and stop and it was also very hot so we thought there was a problem with the fan so we replaced the fan, and to be safe, also replaced the thermostat. Once that was done, a few seconds after the unit goes into the dry cycle, the cycle stops and shows a "PF" power failure error. We checked all connections we can find but everything looks connected correctly. We eye-balled the power board to see if there was any burn spots or anything else noticeable but nothing. We also eyeballed the power filter for the same but nothing looked out of the ordinary. The heating element was hot and confirmed the dryer fan duct was revolving, albeit for a short time. It seems that there is something tested after the heating element is started and the fan revolving, that is not working and which is telling the unit to shut off or "power failure". We had also unhooked the dryer thermistor to see if anything looked unusual but looked fine and re-connected. What else can I check and what part is likely to be at fault ? Since the wash cycle runs fine, I am hoping the power board is fine. Thanks
See all LG WM3431 Front Load Washer / Dryer Questions
LG WM3431 Front Load Washer / Dryer Logo
370 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
