Question about Samsung HT-D4500 Blu-Ray Home Theatre System - 5.1 Channel, 1000 Watts
Power on for 30 seconds then shows check fan on the player and power itself off
  • Samsung Master
  • 7,627 Answers
Drit/dust, poor ventilation, bad fan.
Posted on Nov 04, 2012
Toshiba 42TL515U -fan has stopped working
Check the fan. If found OK, check its voltage regulator circuit.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 26, 2014 | Toshiba 42TL515U 42 in. 3D TV
Why does my Viewsonic PJD5122 turn itself off after about 30 seconds of use?
Review your manual and check for a self-protecting power-off feature to prevent overheating. If it provides one, then you may have a fan that is out or became disconnected. Re-trace your steps when you replaced the lamp, you may find something that was not re-connected.
-GWOOD
Jul 15, 2014 | ViewSonic PJD5122 3D Projector
The unit turns itself on and off every 30 seconds. The screen displays hello and then 30 seconds says off and then a 30 second pause. What can I do?
This is a shut down due to an error in the system and is related to the malfunction of the main drives or the optical units.
You need to check the loading and drive sections, check the power to the main board/ processing section. Some times a fault in the mother board can result in such a shut down and will require a flow chart check up.
Take consensus without tampering.
Sep 08, 2011 | TruTech TT1620 DVD Recorder
It sounds like it's on but the screen is black, I can hear the fan start up etc, but nothing shows up on the monitor
Welcome to FixYa!
This may cause by an electrical charge in the motherboard itself,Im not really sure how it affects the display of the computer.There's also a possibility that the problem is with the LCD cable or the LCD itself. Please follow this method since it usually fix such problem like that,
1.Removed the battery then unplugged the AC adapter
2.Press and hold the power button or the ON/OFF button for at least 30 seconds
3.Connect the power supply back to your computer then turn it back on.
4. Check if you will see any difference.
5. If nothing happens, try to press and hold Fn and F2 on the keyboard.
If nothing happens, there is a possibility that the problem is with the LCD or monitor itself, maybe it will need a replacement...
I hope this information will be helpful. Thank you for using FixYa...
Jun 21, 2011 | Acer Computers & Internet
I am unable to play DVD from different region on my Samsung ht-c655w??
Hi!
Follow this:
1. Open tray and remove any disks in tray.
2. Close tray.
3. Switch Off Player and unplug from power. wait 30 seconds (this clears RAM)
4. Reconnect to power.
5. Turn on player with remote.
6. Press ENTER (middle button of the arrow keys) on remote. (ignore message on screen)
7. Press 8, 4, 2, 6, 9 using keys on remote.
8. Press ENTER on remote.
9. Wait until player finishes processing. (approx 15 seconds)
10. Player will turn itself off, otherwise turn off player with remote.
11. Turn power back on with remote.
Player is now Region Free.
Regards,
Pelu.
Mar 21, 2011 | Samsung Black DVD Player DVDC350
Cpu fan problem
If you plugged the replacement fan into the power supply instead of the "male plug on the mother board" you will get that error message. You need to find a fan that has the female plug for the mother board. It solved my problem.
Paul C.
Apr 22, 2010 | Nuvico NVDV3-16000N
Sanyo PLC SW20AR - Shuts itself down
check the follwoing :
check lamp physically for melted filament, white deposits on filament/ reflector, if so change lamp
if lamp looks perfect, the ballast needs to be replaced, also check for fans if they are running fine
Feb 08, 2009 | Sanyo PLC SW20A Multimedia Projector
My sansa e250R stopped working
try holding down the power button for 20 seconds
Feb 08, 2009 | SanDisk Sansa e250 MP3 Player
Powers on but turns it self off after 15 seconds.
CHECK FLYBACK TRANSFORMER LEADS FOR BAD SOLDER JOINTS, HAVE REPAIRED SEVERAL WITH SAME PROBLEM.
Dec 02, 2007 | Samsung TXN3071WHF 30" TV
Black screen
Sometimes the player crashes with a blank black screen. It looks like it's turned off, but it's actually hung. Try holding down the power button for about 30 seconds, or until the player reboots itself.
Nov 09, 2007 | SanDisk Sansa e260 MP3 Player
Samsung HT-D4500 Blu-Ray Home Theatre System - 5.1 Channel, 1000 Watts Logo
119 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
