Question about IBM ThinkPad T42 Laptop
Error 0201 stuck key 1c - IBM ThinkPad T42 Laptop
3 Suggested Answers
geo_tech506
  • 35 Answers
SOURCE: stuck key 42
well all you have to do it run windows on it
Posted on Aug 28, 2009
  • 10406 Answers
SOURCE: how to fix an error
One of the keys on the keyboard is "stuck" in the "down" position, so that it keeps sending the same character. Quickly press/release each key, several times, to see if you can "unstuck" that key. Or, replace the keyboard.
Posted on Mar 08, 2011
How do dbf viewer do?
A linked server is basically just a pointer that lets the code within your database interact with external data sources as if they were also within your database/instance. There are some examples here for creating linked servers to DBF Viewer Tool:
http://www.dbf.viewertool.com/
So for example if you had a linked server to a FoxPro database called MyFoxProDB you could run a query within SQL Server like this:
UPDATE t
SET t.foo = x.bar
FROM dbo.LocalTable AS t
INNER JOIN MyFoxProDB...TableName AS x
ON t.key = x.key;
You could also consider using OPENROWSET as described in this question:
http://www.filerepairforum.com/forum/databases/databases-aa/dbase-iv-clipper-foxpro/964-how-to-restore-a-corrupted-file
Mar 29, 2015 | Microsoft Outlook Express
Cant Get fridge and freezer to cool to correct temp
According to the picture posted the freezer defrost is stuck on. Why it would not get cold enough. Contact a local appliance repairman and get professional help as this should require control board repair/replace.
Jan 02, 2014 | Refrigerators
Canon iRC5185i with the erro code E000007-0201 . i need the solution to clear this erro
Manual:
E007-0201 Belt push-off temporary escape mode error.
Occurs when the belt deviation is not eliminated within 1 minute in the belt push-off temporary escape mode.
I can't understand what it means.
Oct 25, 2013 | Canon irc5185i
Jenn-Air JDR8895AAS error 1c1c
1C1C Shorted Key - Check wire harness connector and ensure proper connection and wires show continuity to the control board. If ok, replace the control board. Here is the part to order.
All parts come with a 365 day, any part, any reason return policy.
Feb 04, 2013 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
How to fix an error # 0210: stuck key 1C
It seems the "enter" key is pressed down according to the system during startup. One way I found out is to reset BIOS to factory settings. my problem was a sticky shift key. used software to disable it once Im logged in. Donno if it will work for you too.
Mar 08, 2011 | IBM ThinkPad R32 2658 Notebook
Canon ir 7086 error code e00005-0010
give me the solusion of error code 225 of machine cannon 7086
reply plzzzzzzz
Apr 07, 2010 | Office Equipment & Supplies
Toshiba latop 0201 #ide problem
IDE #0 is your primary hard drive.
Toshiba's System Errors indicate that the error 0201 Failure IDE #0 may be caused by bad contact points where the drive plugs into the laptop chassis. Toshiba recommends pulling the hard drive in and out several times to clean up the male/female contact points.
Toshiba also said that if this doesn't work to contact one of their service centers for assistance.
The contact points solution rarely works, but is worth a try. Most likely, your hard drive failed and needs to be replaced.
Feb 08, 2009 | Toshiba Satellite M30X Notebook
Excel formulas
{=max(if(category column = category in query, price data column))}
Nov 18, 2008 | Microsoft Excel for PC
IBM ThinkPad T42 Laptop Logo
65 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
