I have a soniq 42'' plasma it has power red light is on but nothing happens, there no response from buttons on the side or the remote. can it be fixed?? please help cheers
  • 127 Answers
Please check fuses, or the power supply module.
Posted on Nov 04, 2012
  • 2336 Answers
SOURCE: Red power indicator light is blinking
The flashing light indicates a short circuit inside the power supply circuitry. This type of repair is not a DIY without a multimeter, desoldering iron and hand soldering skills. I repair these power supplies, if you need further info write to jah2mil@hotmail.com
Posted on Jun 08, 2009
SOURCE: Magnavox 50" plasma Won't Power on/Shut's off/Blinking red LED
The above fix, listed by Tom saved us!! We did as instructed and took off the back of our 50 inch Magnavox plasma tv. We were not sure what we were looking for so we googled capacitator (image) & there was a photo of a fried capacitator! Sure enough we noticed ours were "fried", we took out the board and went to an electronic supply store, bought the 2 capacitators ($2.00 each!!) and then found someone who did tv repair to sauter the new capacitators onto the board. (It is important someone who know how to sauter and recognizes polarity do do this for you) All in all we fixed this following the above instructions for $34.00 and our time. For a month we were told to spend hundreds getting a new power board!
Kudos to you Tom & thanks so much!!
Posted on Feb 02, 2009
SOURCE: Red blinking light on a Magnavox Plasma TV
Here is the solution. For less that 100$ your Magnavox Plasma TV. Model # 50MF2310/37 will be running like a champ.
Issue:
Magnavox Plasma TV. Model # 50MF2310/37 screen has no picture. There is no sound, TV comes on and then after a few seconds clicks and screen remains blank.
Cause:
On the main power circuit board to Capacitors are prone to failure from over load. The caps are 3300uf 10v 105+c capacitors located to the left of the AC power input.
Service:
Magnavox will refer you to a service center. They will advise $$$ for an inspection. They will also want to charge upwards of 500$ to replace the entire board.
Solution:
1. Unplug your TV
2. Disconnect all connections from your TV
3. With assistance lay your TV on its face on a non-scratching service
4. Remove the back panel screws.
5. Lift back panel off
6. The central board is your main power board.
7. Remove all wire harnesses from the main board.
8. Remove all screws that are holding the main board in place.
9. Lift the main board out and carefully place it into a non electromagnetic pouch.
10. Take the board to a Circuit Board repair shop.
11. Have them replace the the above mentioned Caps.
12. Re-install the board in your TV.
NOTE: Replace the caps with 3300uf 16v 105+ high temp caps(preferrably Japanese caps)
This fix cost me 80$ and my time to search for other who had the same issue. Try searching for Magnavox Plasma TV. Model # 50MF2310/37 bad circuit board or Magnavox Plasma TV bad capacitors or Magnavox Plasma TV bad ciruit board.
Hope this all help, Magnavox is should take ownership for this problem and recall any tv's that have these caps in them. The worst part about this is that teh **** from the repair center that was paid 100$ to check the TV, stripped out the screw holes and damaged the case for the TV.
Portland Laptop Repair was awesome. They repaired the board and it looked like new. Check them out at http://www.laptopportland.com/
Jeff G
Portland, OR
Posted on Apr 28, 2009
dsacco86
  • 1077 Answers
SOURCE: Sharp Aquos 32GA5U red blinking light in front but no picture!!!
Right now your TV is in " Protection Mode " because of a failed part inside. The blinking red light is a error trouble code. Only someone with the actual Service Manual for the TV will know what the code means. Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. The most common board to go bad is the Backlight Inverter Board. It what supplies power to the screen. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 19, 2009
  • 5 Answers
SOURCE: Power to TV, cant power on, red light flashing
The repetitive blinking light is a trouble code which is used to determine which series of boards may need to be replaced. How many times does the red light blink?
Posted on Aug 30, 2009
Soniq PT42SH plasma TV power on. No back light and no pictures
SONIQ LCD TV REPAIR Blank flickering screen Energy ...
? 1:32
https://www.youtube.com/watch?v=FUqdi7lwmcE
May 29, 2013 - Uploaded by WastedOne2
Fix ya Soniq Tv once loaded up hit menu button then channel + then ... SONIQ LCD TV REPAIR Blank flickering screen Energy Saving Mode Issue ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't turn on] ... Common easy LCD TV fix: bad picture screen rainbow colors - Duration: 4:04.
No Image & Blank Black Screen Flashlight Test - YouTube
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to Fix LCD & LED TVs ... Most LED TVs will have a t-con board, a power supply board, a main board and an LED ..... SONIQ Australia 1,718 views.
Soniq PT42SH plasma TV power on. No back light and no ...
Jan 08, 2016 | Televison & Video
I have a 50 inch soniq plasma tv got a universal remote but it doesnt have the codes for qasa soniq in the manuel
You may have to try another universal remote. No individual remote stores all possible codes for all devices.
Feb 10, 2015 | Universal Televison & Video
I have samsung plasma tv hpp5071x/xaa when i push the power button with remote control, i can hear cliking sound and looks like turn on and see red led light at the bottom right corner and also saww flash...
Hey If you have tried Using remote and side pannels Have you tried another TV to see if its the Cable? Also The clicking sound is normal its the TV's Power-source starting. The fan light I am not sure of but if it happens every-time it should be normal. If the screen gets warm Instantly (Hotish) Then you TV is dead D:
Mar 14, 2014 | Samsung PN42A450 Plasma TV
Panasonic TC-P42S30 plasma power light on black screen no sound?
Main digital board should be troubleshooted. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact any experienced service technician, or the nearest service center
Mar 09, 2013 | Panasonic Viera Tc-p42s30 42" Plasma Tv -...
I HAVE A 50 INCH PLASMA TV THAT WAS GIVEN TO ME WITH NO POWER PLUG OR REMOTE . I WENT AND BOUGHT A POWER PLUG ,PLUG IT IN AND NOTHING HAPPENED . DO I NEED THE REMOTE TO OPERATE THE TV ON AND OFF/
Hi
If the set doesn't power ON, what is the use with a remote control? If it power ON properly, the power indicator light at its front panel will light up. Look for this. If it doesn't, make sure that you have got a set which has to be repaired. If it does power up, just get a remote control to operate it. OK.
Jul 11, 2011 | Hitachi P50H401 50 in. Plasma HDTV
Hi i have a magnavox 42" plasma TV (model
I'd look for the manual and see what it says about that red light. I can't find squat for "Magnavox KM42010P".
May 28, 2011 | Philips Magnavox MRD120 - home theater...
My Panasonic TH-50PZ7OOU will not turn on. The red light on the lower left is on, but the screen is completely dark. pressing power button on both TV and Remote control gets no response.
Try to power it up with the remote control. When you hear the relay's click, see how many times the red light flashes. This will tell us what the fault is.
Apr 22, 2011 | Panasonic TH-50PH9UK 50 in. Plasma...
Tv wont turn on, when i press power on the remote, the red power light flashes for a second but nothing happens, is there a reset button?
reset button is usually under setup>picture>other. however your problem may be because of the lamp. If your TV is 4-5 years old you may need to change your lamp.
May 10, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Soniq plasma will not power up
1.8 volt regulator on image pcb
Jan 08, 2009 | Televison & Video
Televison & Video Logo
1,582 people viewed this question
Top Televison & Video Experts
