Question about Dynex Televison & Video
My dynex tv won't turn. It worked last fine last night. This morning (first morning of daylight savings) neither the remote or power on the tv will work
I checked to make sure the cable connections are good and that it is plugged in.
  • momtwins25
    momtwins25 Nov 05, 2012
    mine is doing the same thing, worked fine last night, havent had it on all day cuz I was gone, and I get home and it would not power on, and the red standby light is off too, like there is no power to the TV at all.
  • Anonymous Mar 29, 2014
    I have unplugged tv all night, unplugged cable for hours, took batteries out of remote and left them out. Nothing seems to help to stop it from continuing to go through all the channels.
  • 127 Answers
Check the Ac power cord,Fuses or the power supply module.
Posted on Nov 04, 2012
ginko
  • 19396 Answers
SOURCE: Tv wont turn on worked fine last night
If there is no power at all, then the problem is likely the power supply unit.
The PSU must be tested, then eventually replaced.
Posted on May 30, 2009
rlamkin
  • 44 Answers
SOURCE: My LG-37" Flat-Panel LCD HDTV-37LC7D turns on automatically
The main board needs to be replaced.
Posted on Jul 03, 2008
  • 8 Answers
SOURCE: power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Posted on Aug 21, 2008
  • 5 Answers
SOURCE: Protron pltv3250 32 in. lcd, no power, no lights
You will have to have the set checked by someone to confirm this,
but most likely there is a problem with the TVs internal power supply.
Posted on Jan 25, 2009
gsalmen
  • 77 Answers
SOURCE: TV won't turn on
it might be the power supply failing . the caps are known to go bad,
Posted on Jul 09, 2009
Have a plug not firing.
Hi, Anonymous if you have a CKP sensor it needs compression to send the correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in the head. If still not getting spark the usual suspects are:
1. Fouled spark plugs.
2. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, or BAS sensor.
7. Faulty ignition switch.
8. Security alarm failing to disarm needs reset
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
TROUBLE SHOOTING
motorcycle no spark
How to diagnose no spark situation on motorcycle
Feb 09, 2016 | Motorcycles
Ignition, not spark
Hi, Samueljanocko if you have a CKP sensor it needs compression to send the correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in the head. If still not getting spark the usual suspects are:
Nov 24, 2015 | Motorcycles
Engine stopped running, has no spark.
Hi, Ron if you have a CKP sensor it needs compression to send the correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in the head. If still not getting spark the usual suspects are:
Nov 20, 2015 | Motorcycles
How do I get my scooter to fire at the spark plug so itmcan start
Hi, John if you have a CKP sensor it needs compression to send the correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in the head. If still not getting spark the usual suspects are:
Nov 15, 2015 | Motorcycles
No points type, not able to get a spark
Hi David, if you have a CKP sensor it needs compression to send correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in head. If still not getting spark the usual suspects are:
2. Battery voltage below 8.7 volts, loose or broken battery cables, check the "NEGATIVE" cable at both ends.
6. Failed CKP, CMP, MAP or BAS sensor.
8. Security alarm failing to disarm. Good luck and have a nice day.
Oct 05, 2015 | Motorcycles
Looks like no current to spark plug. Any ideas please
Jul 28, 2015 | Motorcycles
Will not turn on
Probably a spontaneous power supply failure.
Jan 07, 2014 | LG 42" 5400 Series LED HDTV - 42LN5400
My car won't turn on it was working fine last
Just because you charged the battery it doesn't mean it is any good. Modern sealed batteries fail; just as you described, fine one moment and then nothing, they go open internally.
Jul 19, 2013 | Cars & Trucks
Harley evo ignition
Hi Anonymous, the CKP sensor needs compression to send correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in head. If still not getting spark the usual suspects are:
2. Battery voltage below 8.7 volts, loose or broken battery cables especially ground cable to frame.
For a prime suspect please visit the website below and good luck.
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
May 27, 2013 | Harley Davidson FXST - FXSTI Softail...
Televison & Video Logo
349 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
