Question about Electrical Supplies
My primate generator won't restart after shutting
Most likely the fuel is flooding. Let it cool out, and then try a restart.
Posted on Nov 04, 2012
  • Maur Marsh Nov 04, 2012
    It cooled for over 8 hours. It won't even spark
    It has gas, oil and a clean filter. Is there anything else I can try. The unit is 1 wk old.
Generator will not stay running
The toggle switch automatically resets all faults when it is turned to the off position. I would turn the toggle switch off, turn off the breaker on the generator and then turn off all the loads in the house except a few lights. Turn the generator breaker back on, then turn the toggle switch back to automatic. If it starts and stays running, you were overloading the generator. Turn on other loads slowly and keep track of what is on so you don't overload it again. If it still does not stay on, you may have a problem with the panel. Let me know what happens.
Nov 20, 2013 | Briggs & Stratton 15,000 Watt Home Standby...
Husky air compressor
CHECK OIL LEVEL/MAKE SURE THE COMPRESSOR IS CONNECTED TO WALL PLUG NOT THRU EXTENSION CORD???CHECK FUSE BOX TO HOUSE ALSO..MOST COMPRESSORS MUST BE CONNECTED TO OUTLET WITH OUT EXTENSION CORDS
May 24, 2013 | Refrigerators
Low oil sensor
I would let it cool completely and see if it starts again. There are no specific timers that say after detecting a low oil shutdown don't start for X amount of time. It is more than likely a choke setting as it is hot, and you may now have flooded it.
May 11, 2013 | Powermate Portable Generator: 3250-Watt...
Natural gas generator shuts down after about 5 minutes and won't keep running.
How big a unit? Model number? Alarm codes? If it runs for 5 mins check the obvious, coolant level, oil pressure and sensor,
Nov 07, 2012 | Caterpillar Electrical Supplies
Powermax xp8500e will start and run about 5mins quites restart and run about 5mins quites and won't restart (no fire at sparkplug)
most of this generators have a shut off for low oil, so check your oil level to see if this is the problem
Sep 15, 2011 | Watts Onan Portable Generator - 4000 ,...
I have a Honda super quiet 6300i generator. It runs fine and then suddenly will stop. It restarts fine and there are no warning lights of any kind lit on the generator. What could be the cause and how...
Check the oil. Many of these units have a safety switch that will shut off the unit if the oil is low. It doesn't take much on some of these. Or, just add a little oil and give it a try, it certainly won't hurt it.
Jul 09, 2011 | Honda Electrical Supplies
Generator was running just fine. it's a bsv5500-w overloaded the unit by mistake. tested with meter and found 86 volts. shut unit down and now only puts out 5 volts on each leg
are you sure the breaker didnt trip when overloaded,as this is what the breaker is for and would explain the ghost voltage of only 5 volts at the outlet
May 30, 2011 | Porter Cable 5,500 Watt Portable Generator...
Honda eu 6500 gen overload indicator light will not shut off
Check the Ground Fault Indicator circuit breaker for triping, and look for the high limit on generator. Reset the main breaker by triping it full right and then back. Vitally
May 22, 2009 | Honda 6370C - Parallel Power Kit For ...
Electrical Supplies Logo
49 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
