Question about Samsung DV300F DualView 16MP Digital Camera
White screen and working
The camera still works but just appears a white screen, the front lcd works normally, it happened after i tried to update it's firmware Can anyone help me? thx
  • 11967 Answers
SOURCE: I've bought a new samsung pl121 camera & taken a
Your camera is obviously defective. It may have been a return and resold to you. In any case, you should return it immediately....this problem will only get worse.
Posted on Aug 20, 2011
  • 9 Answers
SOURCE: samsung s800 white screen problem
It sounds like you might have a faulty camera. I would use the warranty and get it fixed or even replaced. Might be some wrong with the LCD screen .
Posted on Jan 10, 2008
SOURCE: my samsung digimax 503 has a white screen!
Oh my gosh this really works! Our screen went white, we hadn't dropped it or anything. The camera still worked fine but we just couldn't see what we were taking a picture of. We tried this solution and now we can see the picture through the screen perfectly. THANKS for posting this!
Posted on Sep 13, 2008
SOURCE: LCD screen is totally white and absent of color
Sounds like a loose ribbon cable -- the one that connects the screen to the circuitry inside the camera.
Try squeezing the body of the camera near the bottom 'Samsung' logo, to try to snug-up the connection. Brace the front (under the lens) with your index fingers, and press firmly with your thumbs on the back over the logo just under the screen.
You might try squeezing around the other edges of the screen for good measure in case something else came loose.
-Fionn
Posted on Jan 03, 2009
t00nz
  • 4738 Answers
SOURCE: SAMSUNG S1070 - When I
How do outdoor pictures look when taken with the camera? If overexposed, first check that your camera is in automatic mode, and not some other manual exposure mode of the camera. Next, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Posted on May 29, 2011
White LCD Screen disolay.
Sadly it sounds like the screen has been broken, often times any white on an lcd screen mean that the liquid crystals have been damaged, most likely from dropping the camera or bumping it into something. I had the same thing happen to an old camera of mine. Sorry for the bad news, but it is probably just as or more expensive to fix the screen than it is to just buy a new camera unless it is a very expensive professional camera.
Dec 04, 2013 | Olympus FE-370 Digital Camera
White Screen
Normally there are two reasons for the given problem.
1). Bad or defective CCD. and/or
2). shutter not working.
in the first case the only solution is the replacement of the CCD.
Please click HERE
And in the later case sticking of shutter blade, non functioning of shutter blade will cause the problem. This can be rectified by sending it to some repairer.
Click HERE for the manual.
Main support number: 800-755-3854
I hope you are satisfied with my solution..
Goodluck..
Feb 21, 2008 | Fuji FinePix S5000 Digital Camera
White screen appear
If the problem started after changing your graphics driver, then reinstall the old driver. Acer should have the original drivers on their web site. If you don't want to go back, you could try updating the bios, that also should be on the web site.
Jan 17, 2010 | Acer Aspire 4315 Notebook
Blank screen
Usually it's an lcd burn out where the screen needs replacement. Check the display button if it's just blank then press it to see if it comes on. As far as your friends white screen it not feasible to repair. A good thing to get on any digital equipment is an extended warranty. It does save you in the end when something goes wrong. The limited manufacture warranties are a joke. You should never rely on them.
May 28, 2008 | Sony Cyber-shot DSC-T9 Digital Camera
LCD display works only in one particular angle and goes white in other angles
check the connections on the swivel arm. make sure all the wires / connectors are good
Dec 27, 2007 | Canon PowerShot S3 IS Digital Camera
When looking at the LCD screen..
This appears to be a component fault. Contact Seller[if still under warranty] or Polaroid for a replacement
Dec 25, 2007 | Polaroid T737 Digital Camera
My samsung digimax 503 has a white screen!
Nov 09, 2007 | Samsung Digimax A503 Digital Camera
Camera's LCD dosen't work
Hitting the Cyber Shot logo on the front really works - ye legends!!!
Apr 15, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
White Screen + Stuck Lens
Turn the camara off and lightly tap on the front about 10 times the white screen will go away just tried it on mine a couple of min ago and it worked. don;t know about lens
Feb 15, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
White Screen
I have Fuji FinePix 2650 Digital camera with same problem. I can almost guarantee this is not a firmware problem. I went mountain biking a few months ago and take pictures. I take out camera and turn on. I get lines then white screen. I banged on camera and fixed it. Later a few weeks ago I turn it on and white screen. i beat this thing and get bad menu selection screen for a moment then white again. It takes pictures well and talk to computer no problem but no LCD picture. I thinking it is loose connection for LCD. Send it for repair or if you seek adventure try to fix it yourself!
Nov 12, 2006 | Fuji FinePix S5000 Digital Camera
Samsung DV300F DualView 16MP Digital Camera Logo
175 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
