Question about Refrigerators
I need to replace a 15 amp fuse in a KitchenAid refrigerator model KSCS25FKSS01
3 Suggested Answers
SOURCE: Ice and Water Dispenser not working on KSCS25FKSS01 KIT.AIDE MODEL
This is a known manufacturing defect. The problem is that the wire that some of the wires that run between the door and the rest of the refrigerator have broken and, believe it or not, the only solution is to replace the entire freezer door. Whirlpool is covering the cost under a hidden warranty...call them and describe the problem.
Posted on Jul 20, 2008
imufo2
  • 3773 Answers
SOURCE: We have a KitchenAid no-frost
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
Thanks
for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
NOTE: This
For
extra help go here:
Thanks
for using fixya
Leo Ponder
imufo2
Posted on Aug 18, 2011
What size fuse is needed for a 600b mixer?
I am guessing you have an older Peavey mixer amp. I believe these mostly used 8 amp fuses although older earlier ones may have used different. It should say on the back at the fuse holder. You can get these at Radio Shack, at better hardware store in either auto electrical or electric sections or on line.
Oct 05, 2014 | Food Mixers
Water and ice dispenser and panel light stopped working.
02227c0.jpg Look at above diagram. #18 needs to be replace. Trim pops off then there will be several screws. Goodluck...
May 30, 2007 | KitchenAid Superba Architect KSCS25INSS...
ICE AND WATER DISPENSER WILL NOT WORK ON KITCHEN AID MODEL # KSCS25FKSS01
if neither one works that usually is the water valve located on the back of the fridge. Try this manually fill the ice make with a glase of water and check the temp. in the freezer. you can reach in and touch to see if water is freezing in ice maker. see if it dumps the ice then surly the valve is bad
Apr 21, 2010 | KitchenAid KSCS25FKSS Side by Side...
Access
lok for two screws under the edge remove them and with a putty knife or a plastic type wedge it will move up and off . hope this helped . ****
Jan 19, 2010 | KitchenAid Superba 21.6 cu. ft. Top...
No power to ice water and light in door
check and see if the lock was accidently put on, it can happen. I don't think your dumb or anything, i've seen it happen to customers before. there is no fuse, and when it all stops at once its usually the lock was turned on, in rare cases there could be a broken wire.??? hope this helps.
May 02, 2009 | KitchenAid KSCS25FKSS Side by Side...
Not making ice
The oil from the compressor has pumped up to the top part because of it only the ice maker s not workind change the lead valve of the compressor which can rectify your problem
Jul 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
Displaying DOOR
there is two fuses a 15 amp and a 20 amp fuse on the left hand side of the microwave one or both have blown
Jul 08, 2008 | KitchenAid Architect Series KEMC308KSS...
May 06, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
