Question about Dryers
My dryer will not start, it says door open when it is closed. I also had the clean filter flash on every time I started it, when it would start. is there anything I can try before I call in the repair man?
    Top Expert:
  • Dryers Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 05, 2012
  • 489 Answers
SOURCE: not heating
The reset button needs to be replaced.  Once it has tripped, it loses it's setting and will trip at a much lower temperature.  This is a standard procedure that LG is telling all their techs to do.
Posted on May 02, 2008
  • 1028 Answers
SOURCE: Dryer door pops open after
door strike is bad also door may be warped make sure door is not warped if it is just twist in opposite direction if strike needed part #279570
Posted on Jun 14, 2008
SOURCE: Kenmore Dryer will not start
For anyone else with this problem, I have two replacement boards. One came with my dryer and has been used, the other is brand new. I bought the brand new board to fix the dryer myself and as it turns out, that wasn't the problem. Replacement boards are usually close to $100 a piece ... I will sell for much less.
Posted on Sep 24, 2008
SOURCE: LG dlg5988W Gas Dryer - flashing "clean filter" light
i got the same problem and no repair man could help . i think i just got mine fixed 6-15-09 .what you do is go behind the dryer , remove the air duct and then remove the pipe that is inside the machine by removing one screw . this will give you access inside the machine .first clean as much as you can of the lint inside by vacuuming it . if you look to the left you will see 2 wires with a black button in the middle this is the ignitor ,clean it good because i think the dirt is not allowing it to light up . i did that and mine is working but the cooling light is still on .
Posted on Jun 16, 2009
SOURCE: Dryer not working, indicates "lint
This is a common complaint with this dryer.The probe generating this problem,is at fault.It likely has a film on it,from the dryer sheets.Remove the lint screen,and wipe down the probe that sticks into the air box.Should fix the problem,if not ,replace the probe.
Posted on Oct 09, 2009
I own a Bosch Nexxt Series Electric Dryer, the clothes come out with a petrolium smell, grease or something. I have cleaned the trap, duct work, bearing shield to no avial. It is not the washer, the
Instructions
Dryer Does Not Turn On
Ensure that the dryer's power supply cord is firmly plugged into an electrical outlet.
Inspect the structure's fuse box for a tripped fuse. Each fuse is assigned a single "On/Off" switch. If any fuse switch is in the "Off" position, flip that switch to the "On" position. If the problem persists, contact a professional electrician.
Press the "Start/Stop" button on the left side of the dryer's control panel.
Close the dryer door firmly so that the door clicks into place. The dryer will not operate if the door is not shut.
Lint Filter
5
Clean the lint filter. Twist the program selector knob on the control panel to the "Off" position, then open the dryer door. Pull the lint filter out of the dryer. The lint filter is located at the front of the dryer's tumbler, and is inserted vertically into the dryer. Gently stroke your hand over the filter to clear the lint, then reinsert the filter and close the door.
6
Turn the dryer off and allow at least 30 minutes for the dryer to cool, as excessive heat can cause a drying program malfunction.
7
Increase the ventilation of the room the dryer is located in, such as by opening a door or window. Excessive heat will cause the dryer to automatically turn off until it cools as a safety measure. Increasing the ventilation will help keep the dryer cool.
Clothing Not Fully Dry
8
Clean the moisture sensor. Open the dryer door to access the moisture sensor. The black-colored sensor consists of two bars, and is located at the front of the dryer's tumbler, to the left of the lint filter. The sensor should be cleaned with a clean cloth and white vinegar once per month.
9
Clean the lint filter. Twist the program selector knob on the control panel to the "Off" position, then open the dryer door. Pull out the lint filter. The lint filter is located at the front of the dryer's tumbler, and is inserted vertically into the dryer. Gently stroke your hand over the filter to clear the lint, then insert the filter back into the dryer and close the door.
10
Spin the laundry at a higher spin speed in the washing machine before placing the laundry into the dryer to reduce the moisture content.
11
Turn the dryer off and allow at least 30 minutes to pass for the dryer to cool, as excessive heat can cause a drying program malfunction.
Jan 09, 2013 | Bosch Nexxt WTMC 3300 Electric Dryer
My dryer does not start and the lint filter light comes on. I cleaned out the link and it still does not start
Sounds like a problem with the door switch. Open the door and look at the front of the dryer. In the center of the dryer, just under the controll panel, you should see a hole in the machine. On the door it self you should see a stud that will line up with the hole. If the stud is broken off the switch can't be activated and the door must be replaced. If the stud is O.K. then insert a PLASTIC ink pen in the hole while you press start. If the dryer starts either the door is not closing properly or the mount for the door switch is craked inside
Sep 27, 2011 | Bosch Nexxt 500 Dryer
My LG dryer DLG2526W flaskes the CK FILTER light, but will not start. The filter is clean. Whats up?
The check filter light will always flash whenever you turn it on. It's just a reminder feature. Starting problem can be many things. Possible broken belt, door not closed properly or control board issue. You will require a professional LG technician to diagnose the problem.
Good luck
Oct 01, 2010 | LG D2526 Gas Dryer
Power is on, lights are on, put it to a setting and hit start and nothing happens no water(water is on) no spinning and no drying. Have checked all the hoses and cleaned the filter.
I sometimes get this happeing if the door doesn't close and seal. If you can open the door then this is the issue. THe door should seal and won't open when you hit start. Try opening and closing the door tightly
Feb 28, 2010 | EuroTech EWC177 Front Load Washer / Dryer
Start/stop light flashing Dryer will not start
the flashing light indicates that the door is not closing
it may be closed by the door switch is not operating properly telling the control it is closed
Oct 13, 2009 | Miele T8005 Tumble Dryer
My fisher and paykel dryer ( mod# ED56 ) wont start, power is on
I had this same problem with my Dryer. It is making the few quick beeps because it thinks the door is still open. Near the bottom of the opening to the dryer there is a sensor switch that gets pushed in when you shut the door. Try holding the switch in with a knife or something and then start the dryer with the door open to check if that is the problem.
After i did this, i closed the door and my dryer started as normal.
Aug 11, 2009 | Fisher and Paykel DEGX1 Electric Dryer
3 beeps and lights flash when I push the start button
The door is not compltely closing. Make sure to push it in hard around the clasp areas. If yours has a light, the light should turn off and on as you open and close the door.
Sep 10, 2008 | Frigidaire FEQ1442ES Electric Dryer
LG DLG5988W
check your door interlocks and connections
Mar 15, 2008 | LG DLG5988 Gas Dryer
Bosch Dryer lint filer warning
The Bosch Dryer has a temperature probe in the heater exit and in the exhaust area visible when you open the door. If the temperature difference between the two gets to high, the lint filter is assumed to be plugged and the alarm goes off.
It seems that the temperature probe at the heater, can end up with a faulty connection to the control panel over time due to corroded contacts or lint build up. When this happens the control panel thinks the filter is clogged and it may also not turn on the heating elements properly. Remove the back cover over the heating element (12 screws) and then remove the one screw holding the red wiring connection to the dryer body. You can then wiggle out the wiring connection and clean / unplug and replug in the connector for the sensor. (plug with two small wires only). A little hard feeding the connector back through the hole so take your time and don't damage the wires). Should all work again. May want to inspect inside the heater at same time and make sure the overheating switch is not tripped. ( press in the red button).
May 21, 2007 | Bosch WTMC3510UC Gas Dryer
Dryers Logo
27 people viewed this question
Top Dryers Experts
