Electric furnace blows cool air - Heating & Cooling
SOURCE: We have a coleman evcon
It sounds as if your furnace is exceeding the limit tempperature of the manual reset switch. The coleman is designed for the fan to continually run when this limit switch is tripped in order to keep the heat exchanger cool.( it is a safety feature) afew things may be happening.
1. the manual limit switch( the one you have to push) may be defective.
2. The fan may be running at too low of a speed. Turn power off at circuit breaker. locate circuit board on the board there will be one terminal that says heat if the red wire from the blower is on it tthen you may need to up the speed. follow the wires from the blower to the board if it has multiple speeds then you can isolate the red and put the blue or orange on the heat terminal.
3. the board may have an adjustable fan on and fan off pin selector if it is set up to come on to long or go off to soon it may not be controlling the temp of the heat exchanger properly.
4. I would also suggest checking to see if the orifices and gas valve are set up for your sytem correctly.
these are just simple ideas let me know how things go.
Posted on Oct 15, 2008
Accurate Joe
  • 61 Answers
SOURCE: Electric furnace blows cold air before and after warm air.
It is normal. Your house has to go down a couple more degrees because the heat pump is not working. You can solve this by rewirng you thermostat. Take off the wire that goes to Y and tape off. Then take the wires that are marked w and e or w1 and put the wires to yellow. Do not run ac with it wired like this. If you need more information please post me back
Posted on Nov 29, 2008
diths_kri
  • 67 Answers
SOURCE: furnace blowing cold air
THERMO
Posted on Jan 07, 2009
philbran
  • 242 Answers
SOURCE: Furnace runs constantly since blower motor was replaced
Sounds like they wired it direct to line voltage , it should run through a sequencer or fan relay to cycle on and off , your seq./relay could be stuck closed to but unlikely being it was just repaired , call the service company back before you do anything they are responsible.
Posted on Apr 11, 2009
TheMobilian
  • 8220 Answers
SOURCE: AC is set on cool & furnace comes on blowing hat air
My first thought is a bad thermostat or control board or maybe something is wired wrong. If all that seems to be working I would look at the outside unit. if that condenser fan motor is not operating then you wont get any cooling. look for a swollen capacitor. Read more
Posted on Jun 06, 2009
Stopped heating yesterday...fan runs, but no heat... any parts available? Pretty sure is 120v ac.
Furnace Troubleshooting & Repairs ' HomeTips
www.hometips.com/repair-fix/furnace-problems.html
Nov 25, 2015 - If your heater doesn't heat or works poorly, this furnace repair guide will help you troubleshoot and fix typical furnace problems with step-by-step advice. ... If your furnace's motor runs but the blower doesn't move air, the belt that ..... a tune upbut couldn't really find any thing wrong . last night and today when ...
Furnace Not Blowing Air? A Furnace Troubleshooting Guide
asm-air.com/heating/furnace-not-blowing-air-troubleshooting/
Dec 1, 2014 - A furnace works by a very simple principle, it uses some type of fuel ...This series of heated coils (called a heat exchanger) has a fan ... Today we will address the most common causes of a furnace not blowing air, and what you can do tofix it. ... It seems like this would be a no-brainer, but I can't tell you how ...
Simple Furnace Fixes ' The Family Handyman
Jan 01, 2016 | Heating & Cooling
Brand new furnace wont start its a aruf 14 electric air handler with a 10 amp heater coil
the 3 amp fuse protects low voltage side of transformer. if it's blowing on a call for cooling wire pair going to outside unit bad or contactor in outside unit.
Nov 18, 2013 | Goodman Heating & Cooling
My coleman central electric furnace only blows cool air
The AC unit outdoors must be running and rejecting heat by its air flowing through it the 2 copper lines are the refrigerant lines, the fatter one should be "beer can cold" if not its low on refrigerant or not running.
Jan 01, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
Coleman furnace running, won't shut off, blowing cold only
Hello, the blower will run continues if 1) the limit switch has tripped 2) the relay on the intergrated control board is stuck Try tapping on the control board and let me know if it shuts down.
Nov 04, 2012 | Heating & Cooling
Intertherm electric furnace modular home
Will be to clean each contact-switch and scrape the contacts and use wd40 and spray of air and remove all rust, its possible that exist another options of failure.
Jun 17, 2012 | Heating & Cooling
Furnace will not blow hot or shut off
The furnace has a fault check the furnace compartment for a flash code and check it with the code chart on the furnace door. Turning the power off to the furnace and turning it back on will reset the fault but it may happen again till you verify the fault and fix it.
Feb 22, 2010 | Heating & Cooling
Why would the furnave be blowing air if the gas is
Sometimes the fan stays on a little longer to cool the motor down before turning completely off.
Feb 20, 2010 | Dometic Rooftop RV Air Conditioner
Heating unit blows warm air then turns to cold air
it sounds like unit could be kicking out the low pressure switch or if it is a electric furnace it could be the sequincers
Jan 11, 2010 | Ruud UBHC Air Conditioner
Central air conditoner unit doesnt blow cool air into home has some ice on the inlet heat and cooling lines going into the central air unit
Change the furnace filter. Make sure you use a cheap one when air conditioning, as the better ones restrict airflow when they filter out so much stuff and then plug up, not allowing enough air to pass over the cooling coil in the furnace's air plenum. Turn the A/C off for a few hours (with only the furnace fan on if possible) to melt the ice off the cooling unit inside the furnace.
Sep 01, 2008 | Carrier Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
