Tv gets red vertical line when on for a few minutes
    Genius:
  • Televison & ... Master
  • 2,432 Answers
If the vertical line goes out after warm up, it was an indication of t-con board malfunction. but before you come up with replacement with a new t-con board you must check first a loose connection. usually at the LVDS cable going to the t-con board. tried to re seat those cable connectors. turn off then unplug the tv while doing this to avoid damage with other parts and for safety reason. the t-con board is mounted under cover with metal shield. hope this can help good luck.
Posted on Nov 04, 2012
  • 50 Answers
SOURCE: thin red vertical line on sanyo lcd-37xr1
Sounds like your display panel is going out. Has the tv been droped, or hit by anything? You should call your customer service number to confirm.
Posted on Feb 27, 2008
  • 3 Answers
SOURCE: vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Posted on Jan 13, 2009
  • 10 Answers
SOURCE: red vertical line down right side of the screen
hi
I think your TV have a trouble inside lcd panel
the controller board contains driver IC. Deffective driver IC can cause of line display.
Three reasons why one vertical line accross screen can happen in LCD;
1.The missing signal from the controller IC to
LCD driver.
2. LCD driver IC itself defective
3. Dry contact in the tape carrier package.
Use masking or electrical tape to mark it where the line was located. press it if the line back to normal but when release your hand came back i think it was intermittent. Open the LCD panel
Use robber
Place the rubber on the top of TCP
Gently close back the top casing
Good luck...
Posted on Aug 21, 2009
SOURCE: Vertical red line on Toshiba REGZA 52HL167 tv.
I have this same problem with my 52 inch toshiba regza , The repair shop has said the cost of repair is as much as it is to replace the TV. I am past the one year warranty, but less than 2 year ownership, so Toshiba won't fix the known issue. Solution is don't buy a Toshiba
Posted on Feb 05, 2010
  • 3 Answers
SOURCE: Regza 52 inch LCD has a green and red line running
I have the same problem which started at about 10 months and became full blown after 14 months and now the warranty is up. TOSHIT BA 52u645
Posted on May 25, 2010
Red and green vertical lines
Your problem appearing after the TV has 'warmed' up indicates a faulty electronic circuit board/power supply: if not under guarantee, it may not be cost effective to get it repaired.
Apr 06, 2014 | Panasonic Viera TX-L42D25B 107 cm 42" LCD...
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Upon turning tv on after it's been off for a while i get two lines going from top to bottom of the screen. theres a line on the left side about 2 inches in from the left thats red and about 3 mm wide and...
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
HOPE THIS HELP...
Jun 19, 2010 | Toshiba REGZA 47HL167 TV
Old sony tv gets a bright line in the middle of the screen
Well if this is a tube type, it can be attributed to vertical section. Cold solder on vertical IC, the vertical gone bad or some components on the vertical is at fault.
If your not on electronics better to have it check by a repairer.
Hope this helps.
Jan 18, 2010 | RCA F32650 32" TV
I have a Sony KDFE50A10 50 inch HDTV When I turn it on for it has the lines verticle on it it takes a few minutes and then clears...tv or cable?
Hi,if its a an LCD RPTV it sounds like a light engine problem.Basically your tv uses 3 LCD chips that create the image .Each chip is like a tiny screen that blend together to get the colors and picture right.They are green,red and blue.When they start to fail you will start to get color discoloration or vertical lines.You will need to replace the light engine.God bless you!
Oct 20, 2009 | Sony KDFE50A10 50" HDTV
Vertical red lines on screen
LCD correct?
There are 2 types of lines they may be showing, both requiring the replacement of the LCD Panel.
1. Delamination Lines- they are usually multiple vertical lines that do NOT flow from the top to bottom of the screen. Looks look water dripped down or something similar
2. Single/Multiple Vertical lines - This is normally 1 or maybe a few solid vertical lines that travel from Top to bottom. I belive in some cases they may only travel to the screen center.
In both cases, this will always show when the TV is ON. Even if there is no signal being input to the TV. There are other possibilities but these can be the most common. Both require a new panel.
Apr 29, 2009 | Sony KDL-46XBR4 46 in. LCD Television
Red in picture
Have you tried with a new scart or htm lead?
Sep 23, 2008 | LG 50PX4DR 50 in. Plasma TV
Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
Sep 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Toshiba 42wh36p problem
you tv problem intermittent the problem is in the color circuit, vertical circuit.have a tech check your tv for repairs.good luck.
May 18, 2007 | Toshiba 42H83 42" Rear Projection...
Horizontal White Line
Sounds like something is getting hot causing voltage loss or drive pulse loss to the vertical IC. Maybe you have a bad solder joint. Try tapping the circuit board around the vertical section. A capacitor could be heating and opening up. Stargazer Also you might try using circuit cooler spray and make the problem show up.
Apr 19, 2007 | Sansui TVS2750 27"
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Electro Med Services...
