Question about Water Heaters
Can I wire my atwood GC10A-4E to the original switches in my Rv
Can I use my original switches in mr Rv for my new atwood GC10A-4E if so how doi wire it
  • 234 Answers
SOURCE: i need a service manual for Atwood 2001 series RV LP gas detect
Call one of the motor home supplier and you will be able to get it.
Posted on Apr 01, 2009
c7121
  • 160 Answers
SOURCE: Atwood GCH10A-4E won't heat in electric mode. 12v
CHECK THE FUSES AND CIRCUIT BREAKERS IN THE CONVERTER BOX. MAKE SURE THE 110V SWITCH BEHIND THE WATER HEATER IS TURNED ON. IF THERE IS POWER AND "ALL" THE 110V SWITCHES ARE ON, TIME TO OHM OUT THE HEATING ELEMENT, LOCATED UNDER THE BOX BEHIND THE WATER HEATER.
IN ORDER TO HAVE 12V AT THE CIRCUIT BOARD, 112V POWER HAS TO GO THRU THE RELAY. SOUNDS LIKE U HAVE A WIRING PROBLEM SOMWHERE, EITHER AT THE SWITCH OR AT THE WATER HEATER SOMEWHERE.
Posted on Dec 15, 2009
  • 332 Answers
SOURCE: I have an Atwood Direct Ignition Model G6A-4E 6 Water Heater
I am a RV service tech and that is an old unit. Your control board is bad but with the age of that unit I would strongly suggest replacing the whole water heater, you can shove a pile of money at it and still have an old water heater when for 3 to 500 bucks you can have a new one with a 2 year warranty
Posted on Mar 05, 2010
motor1258
  • 6674 Answers
SOURCE: The water heater on my motorhome guit working on
Obviously breakers are marked wrong, and good thing you checked. I always double check as well, seeing how I've found many mislabeled right from factory, or perhaps previous owners switched them and never changed original labeling. I need to ask though, are you sure the light is not just for the electronic ignition for the propane? Most have a red light to indicate propane side did not light when tried, and no light for hydro side. Have you also checked for another switch on side of cover at back of water heater where you see hydro cable going in to it? I guess I should ask as well, if you've owned this motorhome for a while, or is it new to you? I'm not trying to be sarcastic, but sometimes I forget to ask that and then find out they're new at this.
Posted on Jun 08, 2010
motor1258
  • 6674 Answers
SOURCE: Switch left on now Atwood
If no water in it when switch left on for hydro use, you probably burned out the element. They burn out pretty quick when no water. You have to shut off breaker to it for safety, and remove back cover where you see hydro cable going in to access it.
Posted on Dec 27, 2010
How do i replace the power cord in an rv that has been cut off
3 wire cord or 4 wire cord?
3 wire would be normally 120 volts
4 wires would be 240 volts
don't know if that would be common in an RV? If 120, is it 15 amp or 20 amp?
Again, would not know if 20 A would be found in an RV? If 20 A you would have one position in the cord - Sideways.
Any with the presumption 120 Volt - Same for either 15A or 20 A , Black wire onto Gold lug.
White wire onto Silver lug.
Green wire onto Green lug
if 220, comment back
May 30, 2015 | Atwood GCH10A-4E GCH10A4E Gas and Electric...
My Atwood GC10A-3E will come on the first time I flip the switch. After that it will not relight until I turn it off and back on. When it relights it sounds like an explosion in the tube. I feel it is...
Sounds like some adjustments are needed. Air shutter for one, and ignitor/electrode. Have you by chance observed outside with cover open when it tries to re-light? My guess is that it is sparking/trying to ignite, but adjustments are needed for proper ignition. A good cleaning of burner tube, electrode, and proper adjustment of electrode & air mixture should cure your problem.
Sep 10, 2013 | RTO Atwood DSI-RV Water Heater-6 Gallon
Where can I get a selinoid for a Atwood G6A-4E gas velve?
Open following link for Atwood water heater resources including parts list for different models:
http://waterheatertimer.org/Atwood-water-heater-resources.html
Following link shows ATWOOD Solenoid Gas Valve Type B - 93870
http://www.rvpartsoutlet.com/product_info.php?products_id=6268
Jun 04, 2011 | RTO Atwood Water Heater - 6 Gal LP
I have a Atwood GC10A-3E and the gas is working fine but the electric is not. i checked the element and went ahead and replaced it since i had it out anyways. i then relized that one of the wires had been...
Sounds like the new thermostat and ECO you installed, You may have got them mixed up. The ECO will have a small reset push button in between the 2 spade connectors. The ECO should be second in line, as in power to it comes from the thermostat. Hot (black) line from switch goes to thermostat first, then from opposite spade on thermostat to spade on ECO, then out from ECO to element. Double check wiring or positioning of thermostat and ECO, and correct as needed, and make sure to push reset in center of ECO, then try again. Be sure both are touching up against tank well too.
The thermostat has a little lower temperature setting, and if it fails, ECO takes over and cuts out at a little higher temperature. That's why I suspect they got mixed up, otherwise thermostat (without reset) should have cut power at proper temperature, unless it's faulty, or not touching against tank properly.
Let me know how you make out and what you found.
Feb 10, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
Jun 07, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Mar 03, 2010 | Water Heaters
Atwood GCH10A-4E won't heat in electric mode. 12v power to circuit board no 12v power to relay. Is new circuit board only solution?
Dec 07, 2009 | RTO Atwood Water Heater - 6 Gal LP
I have an Atwood water heater# GC10A-3E. I have
Have we met? Getting some Deja vue here.
Make sure you have propane to the heater by lightly loosening the line at the heater. If so, turn the heater off for 30 minutes make sure the gas line is tight. then attempt ipilot light again
Jun 11, 2009 | Water Heaters
Water Heaters Logo
59 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
