HALFWAY THRU WASH CYCLE STOPPED AND SHOWED FAULT F05
SOURCE: machine fault code "f13"
Plug off the wall. There is a thin rubber tube going from the switch area to the exit near the outlet tube. Probably this is blocked. This tube should be free from any blockage; take out the top clip from this tube and blow into it - it should be free, clear the blockage if any and refit. This is the water level tube which tells the machine when to switch off water, etc.....
SOURCE: I have a F05 fault code on a Hoptoint AQxxf149. Washing machine
The pressure switch is located in the top of the washer. To locate it, look for a small diameter plastic or rubber tube about 5mm in diameter.This is connected to the preesure switch.
Please rate my solution.
Thanks.
SOURCE: f11 fault code
Please find the steps that needs to be taken for trouble shooting F11 fault code specially if there was a power cut.
1, Power off at the machine. Do the next 4 steps within 3 seconds.
2, Press Temperature Button in.
3, Power on
4, Release temperature button
5, press Soil Type button
You will now hear the door lock release so you can get to your pants.
Diagnostic code is now displayed. You can switch the washer off and back on and the error code is clear. If you do this it will work.
I am sure it would help you to resolve the issue.
God Bless.
SOURCE: fault with my fisher & paykel GW708
i found with mine i had the same fault and it only happened on cold ( i only wash with cold and have hot tap turned off) when on spin it would continue to fill and if i turned the tap off and back on it would stop. this means it is a sticky solonoid valve. remover the controle panel. leaver the solonoid coil off the valve. use needle nose pliers in the little slots to unscrew the valve counter clockwise. check rubber isnt split. if it is replace. clean out and re assemble. if the problem persists and you only use cold like i do swap the hot and cold solonoid over. hope this helps
