Question about Sony KDF-E50A12U 50" LCD HDTV
Sony kdf e50a12u New bulb but until tv has warmed up (10 min.) it intermittenly loses sound but not picture
    Top Expert:
  • Sony Master
  • 14,553 Answers
The lamp of course will or should not affect the sound---next time it is cold try it on a rear input---a DVD player etc to see if same issue--this could narrow down where the problem is.
Posted on Nov 04, 2012
  • Gary Miller Nov 26, 2012
    Problem now sorted,It was down to a faulty hdmi extender switcher.Thanks for all your suggestions guys. Gary
premtech
  • 934 Answers
SOURCE: sony grand wega KDF-E50A10
The looks of the bulb are no indication that it's okay. How many hours of operation do you have on that bulb? The bulbs are average rated for 5000 hours, but its been my experience that they usually last on average 3000 hours. Try replacing the bulb and then check and rest the buld hours counter.. Best place I've found for purchasing the bulbs is DLP lampsource. They'll sell you just the bulb without the housing at a dramatic savings. http://www.dlplampsource.com/
To display the lamp time press [ 2 ] nine times.
to reset press [ 3, mute, enter.] Or with the set in standby press [ display, 5, vol up, power ]
then press [ jump 3.]
Hope this helps!
Bill
Posted on Dec 01, 2007
  • 87 Answers
SOURCE: Sony grand wega kdf we655
Possibly dust in main fan. Blow out with duster
Posted on Dec 23, 2007
racer7x
  • 42 Answers
SOURCE: Sony KDF 60WF655 standby/power light blights 10 times then repeat
This is what I found
You may want to have a Tv repair shop look at this .
Standby light flashes 10X
Symptoms / Customer Description
[Primary Symptom Code: 2111 ]
Solution
G1 and G2 boards are ok.
Found Q box was causing loss of DTL MODULE 5v.
Replaced Q box to resolve.
Part #
A1058689A
Posted on Feb 10, 2009
  • 668 Answers
SOURCE: dull dark picture on kdf-e50a12u rear projection
Depending how long you have owned it and if a Lamp was ever replaced, it probably needs to be replaced. You can check with SONY at
1800-222-SONY and see if they could sell and send you one.
Hope this helps,
Skyassoc
Posted on Jul 21, 2009
  • 4 Answers
SOURCE: is it an easy fix to replace the bulb on a Sony
Indeed it is easy to replace the bulb, unplug the TV first, simply remove the outer cover door, then you need to remove the protective inner door, simply place your finger in the ring pull and lift gentley up and pull, when you have the replacement bulb you need to remove the 2x screws on each side holding the fixing brackets then remove the screw that is located at the bottom where the bulb wires are, once removed then you can remove the casing, undo the retainer bracket screws for the bulb and also disconnect the wires from the bulb, DO NOT touch the new bulb with bare hands you must use rubber inspection gloves as your skin oil will damage the lamp, fit new lamp and re assemble housing and re-fit making sure you rerplace the inner door correctly.
Posted on May 18, 2010
Hi i have a sony lcd projection kdf-e50a12u and as i turn it on the green light flashes for a few minutes untill it turns to red along with the light next to it and stays red?
Sir check the lamp of your projection if already damage, if damage replace the lamp and reset also the lamp hour meter. Remove the screws to open the panel labeled "lamp" on the back of the Sony TV. Remove the screws that hold the lamp in place inside the TV. Pull the lamp out. Let me know what is your observation to the lamp so I can guide you. Good day and best regards.
Sep 15, 2011 | Sony KDF-E50A12U 50" LCD HDTV
I have a sony kdf-e50a12u tv and the picture is dark. i have tried to adjust the settings but its still dark what could the problem be
Hello hmt86,
Welcome and thank you for using FixYa!
This is the backlight bulbs or the inverter board that powers them. Both will need tested, hopefully only the inverter board will need replaced.
Have a great evening!
Sep 09, 2011 | Sony KDF-E50A12U 50" LCD HDTV
LCD TV HAS THE PROBLEM, THE PICTURES ARE FAINT AND THE COLOURS UNCLEAR, SO PLEASE HELP ME TO SOLVE THE PROBLEM
you might have some dust inside the light engine you should dust out your TV set and if you clean the TV and still have the same problem then I would say you have a problem with your optical block
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!!
Oct 11, 2010 | Sony KDF-E50A12U 50" LCD HDTV
There is no picture on the screen the green light is flashing for it to come on then the sensor next to it turns red any help have changed the batteries in the remote and still no picture or sound thank...
It seems like the bulb needs to be replaced, the bulb you are looking for is a Phillips UHP 100w/120w 1.0 bulb, you can google the make and modle of the tv and you will find sites for the bulb or send details to info@soundandvisionav.co.uk
May 11, 2010 | Sony KDF-E50A12U 50" LCD HDTV
Is it an easy fix to replace the bulb on a Sony KDF-E50A12U HDTV LCD
yes just be careful not to pull off soddered wires close by
May 03, 2010 | Sony KDF-E50A12U 50" LCD HDTV
Sony bravia KDF-E50A12U rear projecion tv wont turn on
Hi it sounds like it could be an issue with board that powers the lamp ,it's called the ballast.When you put a new lamp in the ballast has to provide more power ,when it starts to go weak it will not light up.Sometimes you can put your old lamp in and will work fine.Try partstore.com they might have it right there.Hvae a blessed one!
Mar 02, 2010 | Televison & Video
Sony kdf-e50a12u my tv flashes the green power light only
How may flashes the LED does? This error code will tell you what is the problem.
Aug 02, 2017 | Sony KDF-E50A12U 50" LCD HDTV
Dull dark picture on kdf-e50a12u rear projection
Hope this helps,
Skyassoc
Jul 21, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
SONY BRAVIA 50IN KDF E50A12U
i have the same problem on mine, my tv is only just 12 months old, in the last 4 weeks it had 2 new blocks put in as the tv was blue, it costing £700 each (under guarante for 3 years thank god) then lastnight the tv made a big bang then switched it self off and the sand by botton is now flashing red then green, i have to leave it 30 mins before i switch it on again then only last 10 mins before it does the same thing again, got sony coming out again to day to fix it, had it with this tv now hate it !!!!!
Sep 01, 2008 | Sony BRAVIA KDL-40V3000 Television
Sony KDF-E50A12U 50" LCD HDTV Logo
129 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
