My philips 32pf 5531d/10 has no picture by sound?
Worked the night before but turning it on the next morning there was no picture but sound
  • 127 Answers
Check for the Ac power cord, the fuses and the power supply Module.
Posted on Nov 04, 2012
SOURCE: Television has sound but no picture
You can try unplugging the tv and wait for a couple minutes and then plug it back in... I just did this and now the television works again.
Posted on Jan 31, 2009
dsacco86
  • 1077 Answers
SOURCE: worked one night, next morning would flash on then automatically turn off
Yep, the inverter transformer on the Power Supply Board burned out. It's one of 5 inverters that powers up the screen.
If one is burned out, it will not have enough juice to power the screen and goes into protection mode like it's doing right now.
You'll have to replace the POWER SUPPLY/BACKLIGHT INVERTER BOARD. The cheapest place runs for about $90.
I'm not sure which one you have, there are 2 different boards for that TV. The board number should be in white on your board.
Here's for the BA8AF0F01031
http://www.shopjimmy.com/power-supply-backlight-inverter-ba8af0f01031-from-emerson-lc320em9-5.htm
And here's for the BA8AF0F01032
http://www.shopjimmy.com/power-supply-backlight-inverter-ba8af0f01032-from-emerson-lc320em93-8.htm
It's definitely cheaper than buyig a new TV. That what I did to fix mine. :)
If you throw your old board in the trash, I would like to keep it for research if possible. Here's my e-mail: dsacco86@hotmail.com
Posted on Apr 20, 2009
dsacco86
  • 1077 Answers
SOURCE: nothing but white screen. no picture, no sound
Well, it's hard to say what part needs replacing. It maybe the MAIN UNIT board, LCD CONTROLLER board, or the SIGNAL board.
The cheapest way to fix it is have a repair shop tell you which board is bad. Then replace the board yourself.
Here's the best place to get parts for it at a decent price:
http://www.shopjimmy.com/catalogsearch/result/?q=lc-46d62u
Just look through this site to get an idea of what parts a going to cost. I know the repairman would charge double for the same part plus labor to install it.
That's the best advice I can give you.
The TV is defiantly worth repairing than replacing it.
Posted on Apr 22, 2009
ginko
  • 19396 Answers
SOURCE: Red LED blinking after turn on the TV (Philips Plasma 42PF9631D
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 21, 2009
SOURCE: Hi, I have a Philips model 37PF7321d/37, 37 inch
The power board numbers you need to search for on eBay is 310432847531 or 310432838621 - they are compatible according to Philips.
Posted on Nov 05, 2009
Why does it have no picture but making a chirping noise?
Ouch this is most likely a colorwheel issue, The colorwheel is where the lamps white light picks up color. It is literally a wheel, therefore needs a bearing to spin on, this is very often the case please see the link below:
http://www.fixyourdlp.com/guides/samsung/bp96-01579a.php
Apr 24, 2014 | Philips 60PP9363 60" Rear Projection...
My Philips TV will not turn on
More than likely it's activating the protection circuitry. Most of the time televisions won't give you a sign of trouble until something actually breaks. One day they work and the next they might not. There could be a problem in the power supply or the scan section which are both internal that would inhibit operation to prevent your set from overheating and causing a problem external to the TV like a fire. If your set is over 10 years old, replace it. If it's quite new but out of warranty then get an estimate at a reliable electronics repair store.
Mar 30, 2010 | Philips Televison & Video
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
Set won't stay on, won't turn on
Sounds like a capacitor on the power supply is bad. Easy fix.
Sep 24, 2009 | Hitachi 50UX57B 50" Rear Projection...
I have a Philips Plasma tv 42pf5321d/37 with sound but no picture
Thats the great sound of Exploding capacitors on either the power supply board. or another one in there. Now the set is in fault protection. It tried to warn you with the RED blinking LED that there was something amiss by shutting itself down. When you unplugged you reset the error and allowed it to do it again.
Best Regards and Smper Fi
Jun 23, 2009 | Philips 42PF9630A 42 in. Plasma Television
Worked fine lastnight but this morning when I tried to turn it on there was no picture, but there is sound
TRY UNPLUGGING IT FOR FIFTEEN MINUTES THEN REPLUG IT IN,KNOW IT SOUNDS STUPID BUT WORKS SOMETIMES
May 21, 2009 | RCA L42WD250 42 in. LCD HDTV
No picture ... thumping sound from speaker1
Check the horizontal output transistor. If that is good you will most likely need a new flyback
May 26, 2008 | RCA P46810LV 46" Rear Projection...
Sound quits after game loads.
are you using original xbox games or 360 games
Dec 16, 2007 | Microsoft Xbox 360 Console
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
