I need to no what you call the lead between the screen and the board on my laptop
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 137 Answers
It's called a ribbon cable. If that is what you are referring to?
Posted on Nov 04, 2012
Caps lock and power led blinking
Try removing the power supply lead, battery, RAM and hard drive. Insert the power lead and press power. If you get the bios screen, add the items removed one at a time until the culprit is found. If it doesn't, you have a mother board issue and require service at a Toshiba service centre.
Dec 03, 2013 | Toshiba Computers & Internet
Tip
Damage to internal leads from screen to keyboard
The internal leads inside any laptop or notebook which connect the keyboard to the screen board are made up of tiny strings of electric wires, constant bending of wire causes it to eventually snap. So if at all possible keep the opening and closing of your laptop or notebook to a minimum.
on Jan 28, 2010 | Computers & Internet
MY MINI ACER LAPTOP DOES NOT DISPLAY ANYTHING
Disconnect the power supply lead and battery. Plug an external monitor in and plug the power unit back in. When you press the power button, if you get display, the screen is faulty. If you get nothing the mother board has an issue.
Nov 15, 2013 | Acer Aspire One AOA150-1949 Laptop
Laptop wont reboot
suspected your mainboard is overheated, call the service center for replacement board if your laptop is still under warranty, or you need to send for the hardware repair
Nov 12, 2013 | Medion Computers & Internet
My screen is white
Sony Vaio is one of the most prominent brands of laptops on the market, and also one of the most expensive. The laptops, created by Sony, are known for their efficient processor functionality and sleek designs. While the Sony Vaio line of laptops are considered high-end, they are also prone to display problems.
Symptoms
Among the problems facing Sony Vaio laptop screens are blackouts. When these blackouts occur, the monitor turns solid black, and upon rebooting the laptop, light will briefly flash on only to blackout again. Additionally, there have been reports of an issue which causes the screen to flicker intermittently until it goes out all together. b> Troubleshooting b> Blackout displays and the continuous flickering of Sony Vaio screens can be caused by various issues taking place inside the laptop. It is not necessarily true that the problem lies within the LCD screen itself, with display issues often occurring as a result of problems with other parts of the laptop. You can test whether or not the screen is defective by connecting the laptop to an external monitor. If the display comes up normally, then the problem lies within the laptop's LCD screen. b> Parts b> If your Sony Vaio is connected to an external monitor and suddenly goes black, then the problem may have to do with the laptop's sleep button. The sleep button latch located inside the device may be jammed or broken, thus putting the screen in a permanent sleep mode until the latch is fixed. Encountering hissing sounds when the laptop is running indicates a faulty circuit board, usually damaged due to overheating. Display issues can also occur when certain parts of the laptop, such as the hard drive, have been replaced. b> Design b> Some owners have made complaints about Sony Vaio design flaws, specifically mentioning defects in the laptop's boards. Among the problems discovered after opening the laptop include burnt LCD fuses, as well as worn out circuits and internal latches. Some of these events may occur even in newly purchased units. Sony has not yet responded to various consumer complaints and has not yet issued any recalls in response to reported problems. b> Repair b> When repairing a defective Sony Vaio laptop screen, it is important that owners remain aware of the nine screws which hold the laptop cover and the board together. Not doing so can easily lead to further damage to the Vaio due to static electricity, and may even lead to a short circuit. For owners who are experienced in the area of laptop repair, parts are readily available for purchase, allowing for cost efficient repair. b> Extended desktop You will need to connect to another monitor or your television to your computer with the vga lead monitor connection. Click start control panel display change display settings adjust resolution this may vary depending on your operating system You should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes. or Click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes if you can get an extended desktop your monitor is faulty if you cant get an exended desktop
Jan 28, 2013 | Sony VAIO VGN-CS204J/W 14.1" Notebook...
Sony vaio laptop half screen black on the right
Symptoms
Among the problems facing Sony Vaio laptop screens are blackouts. When these blackouts occur, the monitor turns solid black, and upon rebooting the laptop, light will briefly flash on only to blackout again. Additionally, there have been reports of an issue which causes the screen to flicker intermittently until it goes out all together. b> Troubleshooting b> Blackout displays and the continuous flickering of Sony Vaio screens can be caused by various issues taking place inside the laptop. It is not necessarily true that the problem lies within the LCD screen itself, with display issues often occurring as a result of problems with other parts of the laptop. You can test whether or not the screen is defective by connecting the laptop to an external monitor. If the display comes up normally, then the problem lies within the laptop's LCD screen. b> Parts b> If your Sony Vaio is connected to an external monitor and suddenly goes black, then the problem may have to do with the laptop's sleep button. The sleep button latch located inside the device may be jammed or broken, thus putting the screen in a permanent sleep mode until the latch is fixed. Encountering hissing sounds when the laptop is running indicates a faulty circuit board, usually damaged due to overheating. Display issues can also occur when certain parts of the laptop, such as the hard drive, have been replaced. b> Design b> Some owners have made complaints about Sony Vaio design flaws, specifically mentioning defects in the laptop's boards. Among the problems discovered after opening the laptop include burnt LCD fuses, as well as worn out circuits and internal latches. Some of these events may occur even in newly purchased units. Sony has not yet responded to various consumer complaints and has not yet issued any recalls in response to reported problems. b> Repair b> When repairing a defective Sony Vaio laptop screen, it is important that owners remain aware of the nine screws which hold the laptop cover and the board together. Not doing so can easily lead to further damage to the Vaio due to static electricity, and may even lead to a short circuit. For owners who are experienced in the area of laptop repair, parts are readily available for purchase, allowing for cost efficient repair. b> Extended desktop You will need to connect to another monitor or your television to your computer with the vga lead monitor connection. Click start control panel display change display settings adjust resolution this may vary depending on your operating system You should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes. or Click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes if you can get an extended desktop your monitor is faulty if you cant get an exended desktop Hope this helps.
Dec 13, 2012 | Sony for Sony VAIO VGN-C2S/G VGN-C2S/H...
Hi, my samsung laptop has an intermittent charging problem i really need help with please. i changed the inside jack lead because there was a break in the wire, the new jack lead gives me power all...
this is a common problem with laptops as you are using a new ac adapter helps a great deal the problem lies in the dc jack on the mother board not an easy task it needs replacing
Mar 15, 2011 | Computers & Internet
My hp dv4000 has a black screen when i turn it on.. i can see a ghost image if i put a flash light on so it looks like its working
I'm afraid your backlight has failed. The screen will need to be repaired or replaced. Perhaps there is a wire between the mother board and the screen (usually a ribbon cable) that has broken. I hope this helps lead you to the problem.
Nov 12, 2009 | HP Pavilion dv4000 Notebook
Long beep followed by 2 short beeps. Then computer hangs. What is the issue?
I do not know what model laptop you have, but generally IBM beep code of 1L, 2S and a blank screen lead to sequential replacement of:
1.System Board
2. LCD Panel
3. DIMM
This is per their field service manual. In standard desktop PCs this code would indicate a bad or mis-seated video adapter. (hence a laptop system board).
Aug 05, 2009 | Computers & Internet
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
