I need to what you call the lead between the screen and the board
    Top Expert:
  • Televison & ... Master
  • 75,822 Answers
Connector harness.
Posted on Nov 04, 2012
What does E 78 mean in mit1020/2 test mode
Unit produced E78 on start-up. Transformer lead broken / not connected Connect lead or replace transformer
Incompatible measurement board software Change measurement board
Unit produced E78 at the end of a test IrDA screen missing from one board Change board with missing screen.
May 25, 2014 | Megger MIT1020/2 Megohmmeter, Battery
Backlight inverters, or power supply issue?
T'Con board fault. Check and replace it. If you wish to get some details; visit the site linked here. Pull up older posts.
May 14, 2017 | Westinghouse TX-47F430S 47 in. LCD TV
Toshiba NB200-11M, display not working. Replaced screen and lead but no different. External monitor displays fine.
Is the display slightly visible? As in seeing shadows on the screen? You may need to replace the inverter board.
If you have replaced the LCM cable (the cable that connects the screen to the motherboard) and the screen and replacing the inverter board doesn't work then you have motherboard fault.
Jul 23, 2011 | Computers & Internet
I updated my Intel desktop board drivers after formatting with xp pro and when i reboot the screen was blank i think there was a bios update in the drives i down loaded.I have tried reset the bios with the...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 20, 2011 | Intel Desktop Board D845GERG2 Motherboard
MY PS2 does not start. The green light lits up, but the TV screen is blank (black screen). If I tilt my PS2 in Vertical position then sometime it might start. Please let me know the reason and how to...
Hi it sounds like the video lead needs replacing give that a try first and if that dont work then it could be that the part you plug the lead into in the back of the ps2 has come loose and is not connecting with the circuit board properly.
see if you have a friend who has a ps2 with a lead you can just borrow to try on yours then that way you will know if it needs a new lead or the board needs some soldering doing the re-connect the video lead socket.
let me know how you get on or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Sep 20, 2010 | Sony PlayStation 2 (PS2) Console
Black Horizontal Line in Screen
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Jun 07, 2010 | LG 42LC2D 42 in. LCD HDTV
Appears a black line vertically on the screen
Dec 06, 2009 | Toshiba 32AV502R LCD TV
Plasma TV screen dull
yep, do u have a digital multimeter? if so, measure all the voltages from the power board located top middle. if u look at the top right of the panel, there is a sticker with va, ve, vset, vsc settings. ground the black lead, and use the red lead to read each of the settings on the pow bd. if there are more than 2 mismatches, its your power board and needs replaced.
Jan 03, 2009 | Samsung PPM42S3 42 in. Plasma Television
Black line in middle of panasonic plasma screen
Oct 13, 2008 | Panasonic TH-50PV30 50 in. Plasma...
Transformer 271996
IHVT or flyback transformer has 3 leads = high voltage to CRT,
focus and screen leads to small circuit board on end of CRT.
.................T.
May 26, 2008 | RCA 32V420T 32" TV
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
