SOURCE: motor kills when put into gear
u have no spark in #2 cyl check for spark with plug if its week regap it
SOURCE: i have a johnson outboard motor that drips oil
Yes the prop shaft seal needs to be replaced.Do this sooner than later as water will get into the lower g/box.Sometimes they wear out or fishing line is a bad culprit.Its not a big job but it really needs to be done.The oil will also need replacing.Hope this helps
SOURCE: how to adjust timing on johnson 6hp outboard motor
look at a manuel i think it is automatic in the switch no manuei adjustment get it timming through the cd like some of the mercks
