Won't come on at the minute as the end light is just staying on
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
Unplug it for 30 mins and then try it.
Posted on Nov 04, 2012
2000 Ford Expedition, Lights won't time out
You either have a windshield leak & water in the
delayed relay & or the GEM Module failed
If only the lights are effected & not the radio,
blower,interior lights- the the GEM is most likely
okey
Then you trouble shoot the main problem
Try Google There is an overwhelming amount of ford
problems you can read
Feb 13, 2013 | 2000 Ford Expedition
How do you clear codes for 2004 saturn ion
Clear the codes AFTER a repair was made & the light
stayed on ?
I would purchase an inexpensive $60.00 code reader &
use that.
If you start disconnecting batteries on every vehicle you
do or will own,then bad things happen.
The radio won't work,the car won't start,etc
If you have service manuals to learn your vehicles systems,
then you can eventually know what the results will be
Again,if you fixed nothing,then the light is going to stay on
or come back
Sep 18, 2012 | 2002 Dodge Dakota Club Cab
My security light stays on & won't let my 99 gmc 6.5 diesel sierra start any solutions
Yes, the system is called Passlock, and malfunctions regularly. Go to this link for an explanation of how it works, plus some tricks and tips on how to reset it, or bypass it.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Mar 27, 2012 | 1999 GMC Sierra 3500
I changed the fuse as the turn lights and hazard lights were not working but all other light including brake and interior worked. Now the hazard light stays on and I cannot turn it off. can you Help p
if your hazard lights stay on, you may have a problem with the hazard switch on your stearing collum. try moving it back & forth several times, eg. on, off, on, off always ending @ off & see if that works. they do get sticky @ times. your brake lights will work but your turn signals won't work properly with the hazard switch turned on. let me know if problem persists & will see if i can help you more. good luck.
Nov 24, 2011 | 1999 Saab 9-5
How do I find the security code for my Matsui VP 9606 VHS Player
Try this
Unplug from wall for 30 minutes, then plug it in again. Power it on, and then PRESS CH UP & REC/QTR BUTTONS TOGETHER on your machine ~ (haven't tried it via the remote) Should then come up as "Pin OK" on the blue screen
I don't think it will give problems after that. Should stay unless you unplug for 30 minutes, the buttons won't reset the video.
Nov 17, 2011 | Video Cameras
Pilot light on the gas boiler won't stay lit it's
The pilot flame must touch (burn) the tip oqef the t-couple to hold the magnet in the gas value open.make sure the pilot orifice (hole) is clear.the pilot pressure (in the tube) is factory set full open & can only be adjusted down (less). Also check the gas **** didn't get closed or turned half way.? Assuming its not the t-couple. If all is good & it still won't stay on. Replace the gas value.!
Sep 20, 2011 | Heating & Cooling
Abs light stays on and goes off occassionally. What is the best way to get to the source of the problem?
I don't understand these questions
Any dash light you get is a Vehicle System
Malfunction ( no owners manual)
They have been with us for 30 years now,
still hundreds of questions a night
Study OBD2 Systems on the internet
All check lights need immediate attention
Check for Codes
Diagnose
Repair
Do so in a few days of any light on dash,they
won't go away & won't pass inspection & eventually
will end in costly repairs
Jun 08, 2011 | Chevrolet Blazer Cars & Trucks
My car's battery works but when it trys to stay on it won't it looks like theres a frayed connection of wires the copper is showing how to fix
disconnect frayed cable from battery,cut frayed part of cable off,strip insulation off end of cable attach ring connector to end of cable &reconnect to battery.
May 12, 2011 | Volkswagen Passat Cars & Trucks
2006 ford escape.. #1. abs light on & stays on. #2. 4wd light comes on,flashes 8 times then gos off
Changing the sensors &/or tone ring may work temporarily but it won't last. I have a 2005 and have had it done and it kept happening. Had it serviced at dealer, asked dealer how to fix it or make light go out and on and on....after I think 5 yrs. it is still on. It hasn't affected my vehicle as far as I can tell. Comes on blinks 8 times, goes off....drive another 8/10ths of a mile and it comes back on, flashes eight times...and so it goes tidily bomMust be an Escape kinda thing.
Jan 30, 2011 | 2006 Ford Escape
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
