Question about Intel DG41RQ Motherboard & Core 2 Duo E7500 Processor Bundle (INTEL DG41RQ MB & CORE 2 DUO ...)
How to connect power switch to mother board - Intel DG41RQ Motherboard & Core 2 Duo E7500 Processor Bundle (INTEL DG41RQ MB & CORE 2 DUO ...)
  • Intel Master
  • 5,660 Answers
Http://www.intel.com/support/motherboards/desktop/dg41rq/sb/CS-029925.htm
Click on -
Intel Desktop Board DG41RQ Product Guide - English (PDF)
Bookmarks menu to the left -
1) Click on the + sign to the left of -
1 Desktop Board Features
Click right on - Desktop Board Components
Or go to Page 11. (Adobe Reader page number box at top)
Front Panel header location marked by P, in the figure.
2) Click on the + sign to the left of -
Connecting to the Internal Headers and Connectors,
in the Bookmarks menu.
Click on - Front Panel header
Motherboard mounted in computer case, the Front Panel header is in the bottom/right corner, above the top black SATA connector.
Two rows of contact pins.
The Top row is numbered EVEN.
Starting at the Left side going across to the Right, Top row;
Pins 2, 4, 6, and 8. There is NO pin 10.
The Bottom row is numbered ODD.
Starting at the Left side going across to the Right, Bottom row;
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
Pin 1 is for the Positive wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. Probably 5 Volts DC for factory testing.
D) Pins 2 and 4 are for the Power On LED. (Light)
This IS for a -> 2 wire LED. (Light)
Pin 2 is for the Positive wire.
If the PWR LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
To the left of the Front Panel header is a 3-pin header.
This is the Alternate Front Panel LED header.
If you have a -> 3-wire LED, it connects here.
Also wanted you to have the motherboard manual.
Regards,
joecoolvette
Posted on Nov 05, 2012
4 Suggested Answers
map9966
  • 2351 Answers
SOURCE: Mother Board connection
Go to the site below. Its a manual for the 800/i65GV group. Go to page 67 and zoom in. You'll get a nice look where everything goes. Two rows of pins. Upper row and bottom row. Real close to each other. Do not place connectors up to down. Connect only left to right.
The reset connector has two pins. One will be white or black. These are - grounds. So connect it to the bottom row onto the most right two pins. Moving to your left. Skip one pin. Take the Power Switch a two pin connector. Remember Black & White is ground & ground goes to your right for both rows of Mb pins.
http://dlsvr03.asus.com/pub/ASUS/mb/sock478/p4p800/e1324_p4p800.pdf
Go to IDE_LED next. Its the last two pins towards your most left of the bottom row of pins. Move to the upper row & the power LED. Same as the bottom row keping the grounds to your right. Lastly is the speaker. Its connector holds four pins but you only use two. One in each end.
Good luck & please vote....
Posted on Dec 22, 2007
djnick989
  • 1067 Answers
SOURCE: motherboard
do u have pw switch on right pins power p start with red on that oen go over one to conect the black try both ways never up down on pins tho side to side only ok
Posted on Jan 25, 2008
tazwegion
  • 21 Answers
SOURCE: Connecting
Marked on the motherboard are abbreviations for those connections ie. PWR SW, additionally your included user manual should specifically detail the installation process... if this still seems to much for you, perhaps you should not risk damaging the system further and seek assistance from a (bricks and mortar) PC store and/or technician.
Posted on Jan 25, 2009
Computer power supply does not work
Need to know how old a computer it is as over the years the power supplies' use different methods of starting.
On newer computers the power supply is connected to the mother board by a 20 or 22 pin connector. The power button on the computer is just a momentary switch to start the computer. Make sure the large connector is firmly seated in the mother board. If you are comfortable with doing that have someone else check it. You do not want to damage the connector or mother board. You need to have some sort of anti static device conntected to your body to avoid any static discharge that could damage the mother board.
Feb 09, 2014 | Antec TruePower Quattro 850-Watt Power...
I cant find where do i connect power switch there no slot indecated on the board help me pls.
Hello Friends,
If you are ask mother board power option. There are two power option every mother board, one option is SMPS power and sec option is Power Jumper. SMPS two power socket indicate 24 Pin and 4 pin also same option 24 pin and 4 pin socket available in mother board. Second option is 9 pin jumper socket hear connect to HDD power, reset power, cabinet power, power LED, and +5v DC. So you open PC and see all section and solved you problem.
Thanks.
Aug 22, 2013 | Gateway Computers & Internet
HP G61 no power
open *********** board battery some time or " mother board battery
inside 3pin jumper switch. open this jumper middle pin to other pin connect some time 1 minute & jumper set previous position.
or" see mother board battery
inside reset switch
May 28, 2012 | HEWLETT-PACKARD G61-306NR Notebook
When switch on printer error appears on the screen and ask to switch off the printer
Possible that the mother board has errors and hence when the power is applied it tends to load with a wrong data so that the processor senses the error to shut down.
Remove the power supply to the the main board and then remove all connectors and connections. Replug the connections making sure there is no loose connection. if the error still come up on the screen on swithch on the mother board is faulty. If there is any visible damage seen on the power supply replace the capacitors.
Sep 14, 2011 | Office Equipment & Supplies
When i press power switch, mother boards power became off.
mother board problem.. u have to change ur mother board or u can do 1 thing just open the restart connection.form the mother board.
Mar 29, 2011 | Intel D845GVSR Motherboard
My s88m g/gl motherboard is not switching on ,but the power supply is working
Power supply is other thing, means she ( Power Supply ) supply the power to *********** board. When mother get the power than she supply all the device. If, *********** board have problem, means not connect properly or burn ( any device ) than she not run. Better you check your all connect device with processor also.
Aug 12, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Not able to switch on the mothere board. Green led on the board glows but the system is not powering on.
1. Check the mother board user manual 1st. To see how to properly install this mother boar to your PC cabinet or tower.
2. Check to see if you have the power from the power supply correctly connected
3. You may not have the proper watts or power from the power supply to power said mother board.
4. check the mother board battery it may not have proper voltage it should be 3.9 volts or more with a voltage meter check.
usually a 2025 button battery on the board
Feb 02, 2010 | Intel Computers & Internet
Can't connect power switch reset switch hdd led to front panel of the mother board can you help me please
If your power is correct, then the reset leads comes to the 2 pins imm. after the power connection...................sodeep
May 16, 2009 | Computers & Internet
Motherboard
Jan 25, 2008 | Intel Desktop Board D845WN Motherboard
New installation of mother board
Hi check the cables from the case to the mother board. They should be marked and the book that came with the board will tell you where to connect them. The std markings are HDD [red led] PWR S [powerswitch] RSW [reset switch] PWR LED [case power light] To test if there is no fault in the board or power pack. first visualy check the board to see if you have a red led light on when the power is turned on, if not the problem is in the power pack or the wall outlet. second if the light is on, the bridge the pins marked pwr switch on the board with a screw driver and this should start the computer, if not you have a faulty board. Regards mistyman
Oct 05, 2007 | Select Brands System on board CPU / VIDEO/...
Intel DG41RQ Motherboard &  Core 2 Duo E7500 Processor Bundle (INTEL DG41RQ MB & CORE 2 DUO ...) Logo
399 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
