Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
It wont extract water
What am I not doing right the machine doesn't seem to be pulling the water back up
  • 350 Answers
Something is probably clogging up the suction.
Try to snake it out with a coat hanger or similar tool.
Often, especially with shedding pets hair will clog the suction pipes.
Hope this is helpful.
Good Luck!
Posted on Jan 24, 2009
The dirty water tank will not fill up
Make sure it's putting the right amount of water down. Many machines brought in to my store for repairs are putting down just a small amount but people think its not extracting any when the real problem is not putting out enough water.
If that's not the case make sure there are no clogs or suction leaks anywhere which will greatly reduce water extraction.
Mar 15, 2017 | Vacuums
My Hoover max extract Spin scrub FH50220 is leakiing bad what can I do
You'll have to find out where it's leaking! Its not real hard. I will help you!
1. Fill the clean water tank. Check that the valve on this tank doesn't let water through when not on the machine. If it does this the tank is the problem.
2. Take off the 4-6 phillips screws holding the hood on to the machine. They will be on each corner underneath. Be Gentle! Do not break any of the plastic parts.
3. Check where the clean water comes to a L valve. This valve is a very common problem. Place the water tank on the machine. DO NOT hold the handle down. Use paper towel to check for wet spots if you can't see where it is leaking. It should be fairly obvious.
4. If the water is coming from the "back" of the machine or the handle pry the cover off the inside of the handle revealing the hoses. The water release valves may be leaking. Be sure to check all hoses for cracks or breaks. Simply find the water.. and trace it back.
90% of the time it is the L valve which looks like this:
http://www.vacuummedic.com/product.php?id=231
Carefully put the machine back together not forgetting anything and test!
Good Luck!!
Aug 10, 2012 | Hoover SteamVac Carpet/Upholstery Deep...
Hard to push wont pick up
Hi David,
I'm sorry to hear you're having difficulties with your DC07. If the machine doesn't seem to be picking up as well as usual, there may be a blockage in the machine - the filter may also need a wash.
To locate and remove any blockages, please follow the steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=4&product=DC07-ANIMAL_US
In normal use, the filter should be washed at least once every 3-6 months, as shown in the video below. Use cold water without detergent, and allow at least 12 hours for the filter to dry completely before replacing it.
If the machine seems hard to push, the internal hose may have become twisted - to resolve this, please remove and refit the internal hose, taking care not to overtighten it.
If you'd like any further help or advice, please call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
Feb 18, 2012 | Dyson DC07 Animal Bagless Upright Cyclonic...
I am at my daughters trying to clean her carpets and i want to know if i set it up right to shampoo her carpets . i only put water and solution in the small container in the back,but i didn't add it...
The smaller container in the back under the release handle it the cleaning solution resevoir. The larger one in the front is for the hot water. It has an internal bladder that holds clean water in this larger container, while returning the dirty to the outer bladder chamber. Both need to be filled with water at the very least in order for the machine to work. If either goes empty, the machine will stop working.
Sep 01, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
What setting do I need to have the machine on to **** up the excess water? I want to download the manual but can't seem to find a link to do so, how would I do that?
You should have the vacuum set to Wash/Rinse for all steps in cleaning. Press the trigger to release the cleaning solution and push the vacuum forward. With the trigger still pressed, bring the vacuum back towards you). Then release the trigger and again move the vacuum forward and then back. Repeat the "dry" strokes until the dirty water enters the dirty water tank. Watch the water going through the dirty water tank lid. Empty the dirty water tank if the suction fails or the tone changes. Do more dry strokes after cleaning the entire surface until you do not see more water entering the dirty water tank.
The manual is available from Hoover at the product site: http://hoover.com/products/details/f7411900/max-extract-dual-v-widepath-carpet-cleaner/ . The direct link is here: http://hoover.com/file/592/ .
I hope this helps.
Aug 08, 2011 | Hoover SteamVac F7411-900 Upright Vacuum
My Hoover SteamVac Max Extract 77's dirty water tank won't fill. The water seems to just filter right back to the floor. What do i do???
There are several possibilities for low pick up. The most common problem is that the lid is not correctly seated on the recovery (lower) tank. It is also possible that the rubber seal on the motor standpipe is out of place. The round tube on the bottom of the tank sits against the seal. Remove the tank and look for a large rubber ring on top of a plastic pipe. A less common issue is damage to the rug nozzle because the screws holding it against the carpet have been broken loose by dropping the shampooer on it's nose.
Jan 22, 2011 | Hoover F6055-900 SteamVac Maxextract LS...
Steamvac drips when tilt to pull back
May have a problem with the seal at the bottom of the tank, the valve and seal sometimes go back and need to be replaced(#43513026).
Feb 22, 2008 | Hoover F7431-900 SteamVac Vacuum
Won't extract water from carpet.
Seems the 1950W is now obsolete, cna't even bring up a drawing of it. Usually when the vac. motor is running, then there has to be suction. But if a seal or gaske is missing, then the suction will be lost. So you might check the dirty water tank to make sure there isn't a part missing or out of place. Check this out, it is for a 1950-3:
http://bissell.com/images/schematics/1950.pdf
Jan 29, 2008 | Bissell Powersteamer 1694 Upright Vacuum
Unable to Extract Water
1/ Is the diverta flap in the correct position.
2/ red lint filter in tank clean.
Sep 03, 2007 | Vacuums
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
135 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
