Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Crackling noise The machine drum is stationary and about to fill/empty and makes a cracking noise. We thought there was a coin in the drum but this doesn't make sense if the drum is stationary
    Top Expert:
  • Hotpoint Master
  • 9,472 Answers
Sounds like you may have a short in a wire. I would open the unit and take a look. You may want to also open it and run it to see if you can track it down.
Posted on Nov 04, 2012
  • 1462 Answers
SOURCE: Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Posted on Apr 01, 2007
  • 249 Answers
SOURCE: drum wont turn
check for worn carbon brushs in the motor.good luck!
Posted on Dec 01, 2007
barkencoa
  • 3463 Answers
SOURCE: i have a hotpoint aquarius
The bra wire bears no relation to your present problem.
Remove top cover, screws at rear, and push top cover back.
See if the belt is still on, if it is, then select final spin and see if the motor and drum go round, if it does not, then the brushes in the motor probably need replacing.
Unplug washer, and disconnect the motor. you will find the brushes at the motor plug end, depress plastic lugs, and slide brushes out, if they are less than 5mm long, then replace them
If it is the belt that has come off, you will have to remove the rear panel to refit it.
Plz rate my solution.
Thanks.
Posted on Jan 29, 2009
  • 47 Answers
SOURCE: drum not going around
Bad belt or transmission.
Posted on Jun 25, 2009
  • 6 Answers
SOURCE: noise in drum sound like its gonna blow up
hello, unfortunately the wf321 drum does not split the bearings and drum come as one complete unit and so you need to order a drum unit complete with new bearings and replace the lot
Posted on Jul 23, 2010
Not draining
With front loading machines this is VERY common. My teenage Daughters wear underwear that are so tiny that they get past the drum lip and get wound up in the pump impeller. Same thing happens with stuff left in the pockets specifically coins.
At the bottom usually the front of the machine there is a bailing tube next to the pump. Take the plug out and put it in a shallow basin to drain the water out of the drum. Then remove the pump access cover, it usually twists out. Then remove what ever treasure is jamming up the pump. Put the cover back on, put the plug back in the drain tube and if you like add a quart of water into the front of the machine to prime the pump again. Then test the machine.
To keep this from happening they make laundry mesh bags - if you use them then nothing will clog the pumps ever again. I tell my Daughters to get underwear that actually covers their butts. For some reason my plea falls on deaf ears. Go figure.
Mar 23, 2014 | Washing Machines
Bosch classicxx
could be the engine check if the motor in not dirty the coper motor next to the brushes has got gold ish colour if not just clean with sand paper
the noise could be the bering ( if the noise is cracking ) ( if the noise is metal could be somthing in iner drum )
Jan 17, 2013 | Bosch Classixx WFL 2066 Front Load Washer
Washing Machine making a loud whirring noise when water is filling and when the machine is spinning out
Check the motor bearings If your washing machine is making a high-pitched whine or squealing noise while running, the main culprit is usually worn motor bearings. To check the motor bearings, remove the belt and run the motor by itself, listening for the noise. If it makes the noise, than the problem is most likely the result of worn motor bearings and has nothing to do with issues in the rest of the washer. Check for Obstructions Sometimes coins, bra underwires and other metal objects come loose in the wash and become stuck between the tub and the drum. Using a flashlight, take a good look inside the washing machine. If you see dents, scratches or dings, that's a sign that there either are or have been items bouncing around in there that can make a horrible racket. Check for Grease Spatter A high-pitched squealing can be caused when the grease thins around the bearing that's located under the tub. Open up the washing machine and check the interior for grease spatters or spots. That could mean that the grease has thinned out around the bearing and it's making the noise because of rubbing. Check the Drum for Irregularities Spin the drum by hand, listening for the noise. If it makes the noise in the same spot with each rotation, the problem could be with the washing machine drum itself. Parts of the drum can corrode over time, leaving it vulnerable to cracks or rust.
Aug 06, 2012 | Washing Machines
Noisy on spin cycle
It's very difficult to advise on a noisy washing machine because you can't describe noises accurately enough. People often describe the same noises quite differently.
Generally though, if a washing machine is rumbling, and noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on washing machines due to water getting into them if the drum bearing seal fails. To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings have probably gone.
Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure is a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust.
Other causes of a noisy washing machine are coins and other obstructions inside the water pump. This will cause noise when the washing machine is emptying the water. Coins or other obstructions can get trapped between the outer tub and the inner drum. This would produce a lot of noise on spin as they coins get tossed around inside. Usually, spinning the drum by hand will not reproduce the noise in the case of coins as the coins drop to the bottom of the tub when the washing machine isn't spinning.
A light scraping noise when the drum is turned by hand is usually a bra wire trapped between the tub and drum.
A high pitched squealing or harsh noise can be motor bearing wear. This can also be checked for by taking the belt off and running the motor alone.
A knocking noise can be a loose tub weight. This would be worse with heavy loads and would not be present on spin with no washing in. This is because the knocking noise is caused when the tub (or outer drum) shakes about on spin. Without washing inside the drum the tub doesn't move. Another symptom of a loose tub weight is grey concrete dust under the washing machine.
It's very tempting to ignore noises while the washing machine is still otherwise working. Some noises can be ignored as they will not develop into serious faults. Other noises, if left, will cause extensive damage and can end up costing considerably more than if tackled early or these days writing the washing machine off. Of course the problem is that you can't tell which of the categories a noise falls into - so ignore them at your own risk.
Jul 28, 2012 | Roper Washing Machines
Making noise when running
It can be tempting to ignore washing machine noises, especially if the machine is still working. But washing machine noise is not only annoying, it can also be a sign of serious damage. When armed with a few tips, you can determine what problem may be causing your washing machine to rattle, and what you can do to stop it.
Instructions: 1)Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings. 2)Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.) 3)Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub. 4)Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water. 5)Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers. 6)Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
Feb 09, 2011 | Washing Machines
When the washer is filling a loud noise is coming from the motor, it sounds like a bearing is going out. It seems to do it mainly when the washer is draining, but it starting to make the noise through the...
Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings. Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.) Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub. Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water. Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers. Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
Thanks for contacting fixya.com
Nov 11, 2009 | Fisher and Paykel GWL11 Top Load Washer
LG WD-3243RHD Front Load Makes grinding, crackling noise
Check the motor at the bottom of the machine. Also check the timer on the unit to make sure the timer is work
Feb 10, 2009 | LG WM2432H Front Load Washing Machine
Motor running drum not emptying
sounds like maybe a blocked pump.Probably got a coin or sock or some lint in the pump.Has your machine got a filter ? What happens when you position the program switch on a spin section and turn it on ? does it pump out the water ?
Sep 14, 2008 | Hotpoint WMA64 Front Load Washer
Spin cycle noise
coins inbetween bowl can be a problem
try tacking machine outside empty of all water
tip upside down sometimes gets the coins out
otherwise you need to pull machine apart
try another way
remove from bellows from machine and turn bowl by hand to remove coins
have fun
Jan 05, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
129 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
