Question about Brother Sewing Machines
Twin needle not catching bottom thread
When sewing with the twin needle it appears that the bottom thread doesn't catch, mostly on the left hand needle. this used to work on the first two garments i made and now no matter what i try the stiches are not catching the bobbin thread 2/3 of the time. how do i solve this?
  • Myriam Nov 05, 2012
    Hi,i have taken the top plate off and got a pile of fluff out, for the moment it now seems to behave. let shope this have fixed the issue. thanks for all the suggestions :-) (i'll be back with news if this didn't fix it, we'll soon find out)
  • Brother Master
  • 7,365 Answers
It's probably time to get new twin needles, the point of the left
needle could be slightly damaged.
I would also suggest that the machine be rethreaded top & bobbin
make sure to use every thread guide
clean under the needle plate and in the bobbin area for lint
if buying new needles doesn't solve the problem then the machine
may need to be checked to see if there is a problem with the timing.
Posted on Nov 05, 2012
SOURCE: bobbin thread not catching
Whenever you see loops on the underside of the fabric something is snagging the thread. the biggest culprit is burrs on the hook. the hook is what goes round and around the bobbin. The reason for burrs on the tip of the hook areseveral
ONE ...is by helping the fabric through as the machine is doing the sewing which directs the needle too close to the hook thus scarring the smooth surface of the hook and potentially breaking it off and the needle too. You must allow the machine do it on its own and only guide the material.
TWO...Sometimes if you are sewing s-t-r-e-t-c-h-y double knit material the material calls for a ball point needle. I have gotten good results with the Singer brand YELLOW BAND needle.
Three ... The hook could have gotten out of timing. What this means is that the hook is not meeting the needle on the top edge of the eye of the needle. You yourself can check this out by removing the bobbin (or shuttle, cassette). Install the needle flat side to flat side of the mounting rod and all the way up. By slowly turning the handwheel on the right slowly and watching that the eye of the needle is just below the hook on the upward swing of the needle and that they both meet dead center. This when you need to take it in to a repairman. FrankIy I don't like to advise this because of unscruppulous practices. My boss used to call me a virgin Mary because I wouldn't ripp-off the customers. Anyway at this time you can also check the condition of the hook carefully looking for nicks and scratches on or around the tip of the hook. If there is damage present you can file this down with a very fine emory board or by using a strip of 400 to 600 grit sandpaper as if your were buffing a shoe. If the hook is removeable by unsnapping the snaps on either side its easier to buff. Anything courser may contibute to the problem. If the paper won't remove the damage you may need a whole new hook. If its not removeable you will have to take it in to have it installed.They have to time it properly.
Four...The two disk that you mentioned also has a spring. That sping is there to pull up those loops. If the disks are full of lint from the thread going through. the clups of lint won't allow the discs to apply tension on the thread and thereby having tightened the tension so much that that spring is not working properly.You can clean the discs by raising the foot which opens the discs. With a long narrow pick pull out all that lint without scatching the discs. Check closely that the the thread goes across the top of the machine down through the discs pull up snug so the spring engages,through the take up arm,in the two thead guides, then into the needle front to back or right to left, if it is a side loading bobbin. Now the tension will work properly!
TESTING : Move the TENSION dial to mid point of the dial usually 5. This is your starting point.
With two layers of fabric ( not stretchy) and with a regular needle, set stitch length at about 12 per inch on the dial. Now sew about six inches. Raise the fabric and look at the results. Do minor adjustments necessary on your tension dial up 6...7.. if loose on the bottom 4...3..2 if loose on top.
If you did all the steps above those are the steps a repairman performs and charges $75 except me I used to charge $10 .
Brother machines are good quality it is those hidden gremlins that make a fun hobby frustrating when you don't have someone to turn to without having to shell out cash! Its been a pleasure!
jravenus
Posted on Nov 07, 2008
  • 192 Answers
SOURCE: Bottom thread will not catch
Unplug the machine and remove the needle plate so that the bobbin case if fully exposed. Lift out the bobbin case and the cup that it sets in will be visible. Locate the "hook" on this cup. It is a finger with a sharp point at the upper edge of the cup. The hook is what grabs the thread from the needle while sewing.
  • Thread the needle.
  • Turn the handwheel by hand.
  • Watch the hook as it approaches the needle from right to left.
If the hook passes by the needle AFTER the eye of the needle is above it, you timing has slipped and the machine must be taken in for repair.
If the hook catches the thread from the needle, put everything back together and try threading again.
Posted on Nov 14, 2007
SOURCE: the bobbin thread on sewing machine will not catch
how do you retime
Posted on Aug 13, 2008
  • 5 Answers
SOURCE: Sewing Machine (brother XL 3200)
You may have the bobbin case in wrong.  I have this machine, and I know that it is really easy to put the bobbin case in wrong.  Try taking it out and making sure that the little stop is in the front and it is seated down in there and able to wiggle back and forth.  My experience with this machine, until the other day when my cat knocked mine off the table and knocked something out of alignment, is that it just works.  Any time mine hasn't worked, it has either been dirty, needing oil, threaded wrong or the bobbin case wasn't seated right.  In other words, it has always been my fault.
Posted on May 25, 2009
  • 15 Answers
SOURCE: bobbin thread won't catch with needle thread
check that the needle is in the right way round i.e. with cut out on the needle facing into the machine. if this is fine then check that as the needle comes back up from the lowest point that it goes to, that the point on the bobbin case passes just above the hole in the needle, i.e. in the middle of the cut out.(if not it needs re timing) if threaded a small loop should appear at this point for the bottom bobbin to catch if not slacken the top thread and try again.
Posted on Sep 07, 2009
I have a Necchi 535FA sewing machine that will not catch either the thread, just leaves a stright line of thread not catched
try changing the needle
also try rethreading the machine top and bobbin
make sure the bobbin is turned the correct way in the bobbin case
if the suggestions don't help then it's possible that the machine
needs to be checked for a timing problem
Jan 15, 2013 | Sewing Machines
Needle not catching bobbin thread at all
Did you change the needle? If that doesn't solve the problem then it's probably out of time. Take it in for repair.
Oct 27, 2012 | Brother XL-5500 Mechanical Sewing Machine
Thread wont loop, it doesn't sew?
It loops, it's just that your shuttle isn't catching the loop. The loop is formed on the upstroke of the needle on the back or "scarfed" side of the needle. If the shuttle point doesn't catch that loop, no stitch.
First make sure you have a fresh needle. If still no stitch... take it in for service. (clean, lube and time)
Oct 03, 2012 | Brother SE-270D Computerized Sewing...
Second Needle thread isn't stitching
change the second needle
rethread the second needle & every thread guide
see if that helps & if it doesn't then the machine needs to be checked
Aug 13, 2012 | PfaFF Sewing Machines
White 2037 Bobbin thread not spinning and noticed the needle hitting bottom of bobbin casing
it's sounds like the machine could be out of time & the machine needs to be checked at a sewing machine shop, to find out for sure.
May 10, 2012 | White Sewing Sewing Machines
Bobbin thread keeps catching under the plate
Your needle may be new, but Is needle correct size for fabric you are sewing? If so, is needle all the way up as far as it will go in needle bar shaft, flat side in back & more rounded side facing you? Stretch knits and wovens, denims, and leather do not use same needle size. Jimmy
Apr 09, 2012 | Singer Quantum 9940 Computerized Sewing...
Shuttle hook not catching thread
it's possible that when you broke the needle it caused the machine to go out of time & only a sewing machine repair shop can retime the machine
Jan 24, 2012 | Singer Sewing Machines
I have a Toyota RS2000 sewing machine. The thread has suddenly started breaking, and I am getting big bundles of thread under the fabric. What is wrong please?
try a top thread tension of 4
change to a new needle
clean under the needle plate & in bobbin area for lint or loose threads
also rethread machine top thread & bobbin just incase thread is catching somewhere
make sure the thread doesn't come off the thread take up lever
check to see if there are any burrs on the needle plate or the bobbin
Aug 10, 2011 | Toyota Sewing Machines
I have threaded up my machine and have started to sew. The thread on the back of the fabric keeps catching and bunches up. What's going wrong?
try a new needle
keep a check on the thread take up lever that the thread doesn't come off of it
rethread the machine to make sure that the thread isn't catching on anything
clean under the needle plate for loose thread or lint & in the bobbin area also
make sure the bobbin is inserted correctly
Aug 04, 2011 | Bernina 1008
Nov 12, 2007 | Kenmore 12102
Sewing Machines Logo
109 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
