Question about Samsung R540 Laptop
Hard drive fault - Samsung R540 Laptop
  • max carson
    max carson Nov 04, 2012
    A bit vague.Can you be more specific. Can Boot? what is the fault? What is the OS?
  • Samsung Master
  • 27,725 Answers
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
hope this helps
Posted on Nov 05, 2012
Error code E602-0001
Data read fault of the Hard Disk Drive on boot-up. Hard Drive fault.
Replace hard drive and install firmware
Hard Drives become faulty over time resulting in E602 error
Aug 16, 2013 | Canon imageRUNNER 3300 All-In-One Laser...
Hi, I have some troubles with my Baracuda ATA IV 20gb,so I need to download some softwear for this harddrive.Do you know weare I can find it? Thanks Allex Bulat
Hi
Hard Drive faults can rarely be repaired by downlading drivers. The drivers for almost all hard drives are already in any operating system.
Most hard drive faults are physical faults, such as bad sectors, controller board faults or shock damage.
Some apparent faults may actually be due to incorrect jumper settings. It is worth fully exploring all the jumper setting options available on this drive.
This drive is quite an old ATA drive and because hard drives work so hard spinning several thousand times per minute (yours is 7,200rpm), the older a hard drive gets the more susceptible it is to failure.
Your drive was probably manufactured in 2001 and is likely to have had a 3 year warranty when new, so it is long past its warranty period. This means that little help is now available to you from Seagate.
It is sometimes possible to download Firware Updates for certain hard drives, which can improve the performance of the drive. But Firmware Updates rarely repair hard drive errors.
You can find detailed technical information about your hard drive here:
www.seagate.com/support/disc/manuals/ata/100129212b.pdf
Available Firmware Update Information for Seagate Drives can be found here:
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=207931&NewLang=en To check if any Firmware Updates are available for your drive, you need the full model number, which should be somewhere on the label (possibly ST380021A).
If firmware updates or jumper settings changes don't work, you may have to consider buying a new ATA hard drive.
I hope this helps.
Aug 27, 2011 | Seagate Barracuda ATA IV (ST320011A) 20 GB...
Laptop wont power up..... hard drive light blinks... checked hard drive and it fine... i tryed with 3 different power cords/ power supplies....
You checked the hard drive and did it boot another computer?
Do you achieve POST and get to the BIOS menu?
If you do get that far, then you have a boot sector fault, if you don't reach POST then you have a Motherboard fault and it will require service with a Toshiba agent.
If you have a boot sector fault press F8 as the BIOS screen is leaving the display.
Choose Recovery and follow the prompts.
Hope this helps.
Nov 29, 2010 | Toshiba Satellite A100-S8111TD Notebook
Sony vaio
This fault is usually a disk controller problem/fault or the hard drive is not making proper connection or most likely the hard drive is faulty.
Try reseating the hard drive first.
If this doesn't work, check the BIOS to see if it detects the hard drive.
If the BIOS cannot detect the hard drive then remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot see it as an external hard drive and cannot open the folders and files, then the hard drive is confirmed faulty.
Install a new hard drive and install Windows on this drive together with the device drivers and programs to get a working laptop again.
Sep 09, 2009 | Sony Computers & Internet
Pxe-e61 media test failure
This POST error refers to possible fault with the disk controller or the hard disk. Most likely you have a faulty hard disk.
Try reseating the hard drive first and if the problem remains then you need to test the hard drive. Do this by removing the hard drive and connect it to an USB hard drive adapter and connect the adapter to a working computer's USB port. If this computer see this as an external hard drive and you can open the various folders and files, then the hard drive is OK and the fault is the disk controller on the laptop's motherboard.
If the hard drive is not recogonized then it is faulty and you need to purchase a new hard drive, install Windows etc. to get the laptop functioning again.
Jul 09, 2009 | Toshiba Satellite 1805-S274 Notebook
My laptop doesnt work anymore suddenly!
This error means the operating system on the hard disk couldn't load due to possible faulty hard drive or disk controller. The fault could also mean the hard drive needs reseating to make proper connection. Reseat the hard drive and if you still get this error, then you need to determine if the disk controller is faulty.
To do this, remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer see this hard drive as an external drive and you can also see the contents of the drive, then the hard drive is OK and the fault is a faulty disk controller. If the computer cannot detect the hard drive then the hard drive is faulty.
Then get a new hard drive insert it into youe laptop and install Windows to get your laptop operatioal.
Apr 10, 2009 | Acer Aspire 4720 Notebook
"Error loading operating system" message
Apr 09, 2009 | Sony VAIO VGN-FE660G Notebook
Startup of laptop
Then get a new hard drive insert it into youe laptop and install Windows to get your laptop operational.
Apr 08, 2009 | Acer TravelMate 281LC Notebook
Unable to reconnect hard drive.
check  for the connection first try two r three combinations and still if u dont get it then the hard drive is fault
Mar 08, 2009 | Dell Dimension 4500 PC Desktop
Samsung R540 Laptop Logo
48 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
