Question about AEG D2100-4 Electric Double Oven
Aeg oven not getting hot - AEG D2100-4 Electric Double Oven
  • 45 Answers
I think the coil is dammage..please replace with a New coil
Posted on Nov 04, 2012
I have an aeg d2100-4-m oven. main lower oven not getting hot. Have replaced element, to no avail.Fan and light in oven both come on, but have noticed that the temperature dial light is not illuminating....
Hi .
Sounds like the oven thermostat is faulty.,
This gives a supply to the element .
The temp indicator should be lit, if it is not, then I would suggest repl;acing the oven thermostat.
Sep 28, 2011 | AEG D2100-4 Electric Double Oven
Hi, I have 90 AJC 06 GC. AEG single oven. At thhe moment when the oven is turned off the cooldown fan will not turn off so I have to turn it of at the main fuse box. Also sometimes the oven turns itself...
The oven cooldown fan will sometimes run for 10 to 15 minutes after turning the oven off. This enables the outer shell of the oven to cool down. Most ovens also have an inbuilt thermal overload in the outer shell. If the temperature in the outer shell gets too hot it will open circuit the oven power until it cools down a bit.
Feb 10, 2011 | AEG Ovens
Competence 5208B, fan oven blows cold and won't heat up, ordinary (non fan) oven does get hot
Hi.
You need to replace the oven element, located at the rear of the oven compartment behind a removeable cover.
Nov 09, 2010 | AEG Ovens
Oven does not work with ventitherm fan opereated cooking option. It does not get hot.
I suggest you fit a new fan oen element, located at rear of oven compartment behind a remoeable cover.
Oct 11, 2010 | AEG U7101-4 Electric Double Oven
Aeg d5701-4 bottom oven slow to heat up and does not reach set temperature fan works
It sounds like the oven element is not working.
To check it, remove rear panel in oven compartment, after running it for a few minutes, it should be very hot to the touch, BE CAREFUL, DO NOT BURN YOUR FINGERS.
Apr 21, 2010 | AEG D5701-4 Electric Double Oven
The top oven of our AEG D5701-4 is slow to heat.
Hi it could be the element on the grill it maybe burning out, what slows the grill to get hot quicker. best to turn of the mains or by the main switch. and get a toorch to check around the element or use a continental reader check if it is receving 240volts
Mar 09, 2010 | AEG D5701-4 Electric Double Oven
Aeg 3050b oven not getting hot fan running and both lights on no heat even when turned to 275 degrees oven was working ok yesterday but seems to have gone all at once
Does the thermostat click and the light go off and on when you turn it up and down if so it is mechanically working.
Fan will run irrespective of element working
Either the element has failed or the connections to the element
Both require you to take the back off the machine to check them out
Jan 26, 2010 | AEG B2100-4 Electric Single Oven
Oven gets too hot AEG B3101-4
Hi I am Vortash This sound like the thermostat cut out switch and if it is glowing hot then you have a serious DANGEROUS fault
it means that it is not disconnecting as it should and has shorted ot .. please get it changed immdeatly as it may short to the oven body causing it to become live .. now that should mean that the house fuse should blow .. but on the slight chance it don't you would be electrocuted if you touched the oven please call a domestic service engineer now Regards Vortash
Apr 13, 2009 | AEG B3101-4 Electric Single Oven
AEG D2100-4 Electric Double Oven Logo
112 people viewed this question
Top AEG Ovens Experts
Sal De
Steve
Samyfam
Samyfam
Are you an AEG Oven Expert? Answer questions, earn points and help others
