'washing machine miele w1714 lock on Message demo programme how i do unlock?
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
Demonstration Mode (Dealer Displays)
Initial requirements
- Switch off the machine.
- Close the door.
Note
Once you begin the access procedure, it must be completed within
10 seconds.
Accessing
1. Press and hold the Start Button while switching the unit on with
the On/Off Button.
2. As soon as the Start LED lights up, release the Start Button.
3. Immediately press and hold the Start Button, until the Start
LED turns off.
Deactivation
Repeat the accessing procedure.
Note
The Demonstration Mode is NOT deactivated when the power is
shut off with the On/Off Button, or by unplugging the appliance.
Posted on Nov 04, 2012
  • 177 Answers
SOURCE: miele front loader washing machine W3275- error co...
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
Posted on May 24, 2010
  • 16 Answers
SOURCE: miele washing machine
All Miele washing machines and dishwashers need to fill in a required time. Flashing inlet (Tap icon) indicates that the machine can not fill in time. There are filters in the end of the hoses which connect to your water supply from the machine and filters in the inlet valves which you can get at by removing the hose from where it fixes onto the machine it'self. You will need some long nose pliers to grab the little tab on the small filter to get it out. Clean all filters and hoses. Still same problem then check the pressure of the water coming into the machine. There should be a good pressure coming out of the hose and will be difficult to stop the flow of water with your finger.
Posted on Feb 08, 2008
skyblue67
  • 71 Answers
SOURCE: Miele W4840 is LOCKED
hi try pressing in the heavy soil button to take off the child lock, good luck
Posted on Jul 19, 2009
SOURCE: ge profile front load washing machine demo mode
I called General Electric and this is the solution:
unplug the machine for 2 to 3 minutes.
Plug it back in the wall
Do not put the power back on.
Open the door
Press the start/pause button 5-6 times
The display will say demo exiting...
This works. Also don't forget to remove the shipping bolts before starting your washing machine!!
Good washing!!
Posted on Apr 10, 2009
mgprice
  • 744 Answers
SOURCE: Miele Washing Machine Code: Check drain
This means that the drain attached to the pump is clogged, remove the drain plug check fro debris and replace...you should be good to go.
Posted on Jun 23, 2009
Miele W1714 The machine says "Close the door", but the door is closed! All I can do is switch it off. Nothing else works.
There is a switch in the door that will make the door is ajar light stay on, if you no what door it is your going to have to replace this switch.this happen to me on my ford expedition
Aug 31, 2015 | Washing Machines
Tip
My Miele washing machine is locked.
Recently I received many requests from users in troubles because they could not unlock their washing machine.
I decided to publish a tip illustrating the unlock procedure.
These instructions apply to most Miele front loading washing machines. They will work on all the W4800 series washers.
Instructions on how to set on and off your Miele’s child lock function are also contained in the user manual.
If you attempt to open the door while the Child Lock function is activated you will get the message "Machine locked" and the picture below on display:
If the door lock is locked during the wash cycle, press the pause button, and the door will open.
In order to deactivate the Child Lock:
  • Press and hold the "Heavy Soil" button until the display shows an unlocked pad lock picture and says Ready to Use (hold up to ten seconds, it should be less).
If you want to re-activate the Child Lock:
  • Press and hold the "Heavy Soil" again, until the display shows a locked pad lock picture and says Ready to Use .
The drum door cannot be opened, and the machine may stay locked if one of conditions below is occurring:
  1. The water temperature is more than 55°C (130°F).
  2. The water level is too high.
  3. The Child Lock function is activated.
  4. There is a fault.
If the washer is in one of the above conditions, you will get the machine locking even if child lock is off.
If the door is locked because of a fault, and there is water in the drum, the machine will also lock up.
In that case the door will open only after accessing the drain pump.
The pump service door is opened using a tool stored behind the dispenser drawer.
The tool must be used only after disconnecting power.
I think I will post a detailed procedure on how to fix a blocked drain pump on the next tip.
I hope this tip has helped you to fix your problem.
Goodbye.
on Dec 10, 2009 | Miele W4840 Front Load Washer
How do i unlock the child lock on my miele W4802 washer
Try to unplug it for 5 minutes and then try again
Nov 11, 2011 | Miele W 4802 Washer
Question about a W4802 washing machine - can the water level / amount of water used in the machine for wash and rinse cycles be increased?
Hi - not under normal conditions, these are factory set only the Miele Agents can alter the programmes pending on their softwares.
Jun 14, 2011 | Miele W 4802 Washer
How do I fix a F53 fault ona Miele W1712 Washing Machine
A call with the Miele tech helpdesk got me an answer: The tacho unit (coil) should have about 500 Ohm resistance, so they told me. My unit only had about 78 Ohm's, so I ordered a new brush unit (which includes the tacho). The new unit actually measures 250 Ohm, but since it was a new one I did fit it. It works like a charm again. No F53 fault code anymore.
The part no. is 6799642 - Module BSTV Mrt40 RK473. It cost me about 70 euro's including shipping. My machine is a type W3821, but the motor and brush unit with tacho is used on a variaty of models.
Cheers!
May 01, 2011 | Miele W1926A Front Load Washer
Cannot get my miele washing machine off demo mode
Press and hold down the start and the on/off buttons together until the display says ' d off ' then release them.
If this works pl giv me a "very helpful" rating.
Oct 24, 2010 | Miele S318 Bagged Canister Vacuum
Jul 19, 2009 | Miele W4840 Front Load Washer
Miele W487WPS Washing Machine
unplug machine, drain water manually by leaving the out let hose down gravity will let the wate out unless its blocked.Close Ire.ps. door should open .reset,and try again
Feb 24, 2008 | Washing Machines
Not working washing machine
Sounds like it's either in demo mode or you changed something when you went into programe mode. Handbook should tell you about how to get in and out of demo mode.
Dec 23, 2007 | Miele Novotronic Premier 500 Front Load...
Washing Machines Logo
470 people viewed this question
Top Washing Machines Experts
