My frontload washing machine fills water but then it will not turn.
Hope I can get some help? My Bosch washing machine fills with water and after filling the tub will not turn? It also does not spin, but it drains fine. I've changed the carbon brushes, I've also did a resistance check on the motor and it seems fine. I did a resistance check on the water flow meter it seemed to be the issue, I've replaced it, but the tub still does not turn or spin? Please help? Thanks
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
I would check the motor. Sound like it may be at fault.
Posted on Nov 04, 2012
SOURCE: GE frontload washer will not wash cycle or spin out
Thanks to Guest #2 our laundry is back in action and we're not waiting for a serviceperson. We took the front panel off, unscrewed the white plug and was sure our plastic drawer was open to catch the water, a load's worth. We found a small screw driver, 8 or so pony holders, some change, drill bits, bark, games pieces, can tops, etc... unbelievable. Thanks SO MUCH for the hint!
Posted on Nov 22, 2007
defadad
  • 351 Answers
SOURCE: washing machine overflowing
the valve on your inlet pipe may be faulty, have the valve checked or buy a new valve, not very dear, around $30 australian
Posted on May 30, 2009
jsrock516
  • 5911 Answers
SOURCE: tub will fill, but stops after and does nothing else
A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price. If you have questions, please let me know. I hope this helps you.
Posted on Jun 26, 2009
  • 1525 Answers
SOURCE: Washing machine fills with water but drum won't
hello try the module board this control the motor speed it sit at the back of the washer usually as a load of wires coming of it hope it helps
regards
shaun
Posted on Mar 20, 2011
seangosling6
  • 15 Answers
SOURCE: My Bendix BIW103W washing machine has stopped
Timers can be expensive whereas brushes generally arent. First of all unplug the machine and tilt it over. You will see the plastic brush holders either side of the motor at the back. You need to prize them out carefully and check if they are protuding over the end. If they are they are probably ok. Then you need some fine sandpaper. Hold this through the brush holder gap and press against the coil inside. Turn the motor by hand thus cleaning it off. Then put it back together and try it again.
Posted on Nov 09, 2011
Bosch frontloader will not spin or agitate
You can check the following things in your washer:
1. Is the washer door or lid closed?
a. If yes, does it filled with water?
b. if no: Please contact the manufacturer to replace the door latch.
And if it is not filling properly then there is a water supply issues like: hot or cold faucets closed or not open completely, hot and cold hoses reversed, kinked or pinched fill hoses, plugged inlet screens or insufficient water pressure
Jul 22, 2016 | Bosch Washing Machines
Bosch frontload washer
Look under YouTube , there is suppose to be a circle cut out on front, pop the plant is piece off, it actually swist off, get something on the edge and you will see the slot swist it around and it will pop off , also get towels it holds water and can make a little mess, unscrew the cap get a light and clean the items out, hope this helps, seems to be a number 1 problem with them.
Sep 10, 2015 | Bosch Washing Machines
Wshing machine keeps filling with water
You probably have a stuck fill valve. This is the part where the hot and cold water hoses connect. Just to be sure unplug the machine and if it still fills Remove and replace the fill valve assembly. Don't forget to unplug the machine and turn off both the hot and cold water supply valves. This is a rather simple repair.
Aug 07, 2014 | Russell Hobbs RH1042 Frontload Washing...
Washing machine not filling
yes your problem is up the line somewhere. you have to have water coming out of the fill line when the washing machine is unhooked.
you will have to locate the valve to turn on the water.
good luck
Jul 05, 2012 | Russell Hobbs RH1042 Frontload Washing...
Neptune frontloader washed accumulates water
replace water valve if its filling while not being used. if u hear the water in the tub but noty seeing it thats normal they water in them always. as far as mold u can buy some affresh its a cleaner for the frontloads
Mar 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
Bosch Classixx 1000 Express washing machine won't fill with water
cheak the filter witch is at the intake and if when it is going to fill does it buzz if dose that means the vale is working if not call a repaire man out hope this helps
Jan 22, 2009 | Bosch Classixx WVF 2402 Front Load...
Frontload Washer won't spin or wash.
check the door lock/ latch mechanism
Sep 17, 2007 | GE WSXH208A Front Load Washer
How to increase water level in my frontload
The water level is not user adjustable but if there is a problem then the analog pressure switch should be changed.
Mar 09, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
Top Washing Machines Experts
