Question about Westclox Audio Players & Recorders
I have a chime westclox model 46078k suppose to not chime between 12am and 6 am but everytime i put new batteries in i can't figure out how to make it not chime during those hours. it's pretty
robotek
  • 1512 Answers
SOURCE: Westclox model 22717
Hi faulkquarter
I take it that the clock displayed with this problem if not a 22717 model. The one I have sighted is a digital clock. Generally, you need to hold down the "time" button and also press the "hours" and "mins" buttons at the same time to set the time. If this is not how your clock appears, please give me the button names and I can write a method of changing the time for you.
regards
Graeme
Posted on Apr 14, 2008
SOURCE: Salton Chiming Wall Clock is chiming inconsistently
yes .
check volume setting.
if you have a manuval volume control try to clean inside of volumecontrol.if ok fine
or
if not ok Replace volume control with same type( new one.).
Posted on Nov 20, 2008
SOURCE: seiko mantle clock (switchable chimes)
See this site
http://www.theclockdepot.com/seiko_westminster_clock_instructions.html
Posted on Apr 22, 2009
SOURCE: Problems with Howard Miller dual chime dual west and Beeth movement clock
If you manually set the time, the chimes will be off unless you wait for the chiming to finish before continuing to turn the hands.
Press the TEST button to get the correct number of chimes in synch with the actual time.
Posted on Jul 03, 2009
escapement
  • 2334 Answers
SOURCE: how dose the chime work on a timex watch
Try to find solution here:
http://www.timex.com/gp/node/n/255235011/190-2521384-6105829?ie=UTF8&timexBrand=core
Rate me, please.
Posted on Jul 23, 2009
I have a Waltham Regulator Wall clock. It chimes 4 minutes late on the hour and 1/2 hour. How do I adjust it to chime on the hour and 1/2 hour? I've tried moving the minute hand with no luck.
Try this,remove batteries,set clock to 6 o'clock,reinstall batteries,then clock should chime,turn adjuster till you are at the right time,make sure your on am or pm,it doesn't chime at 10 pm- 5 am,so that will tell you if your at am or pm.When adjusting it will chime everytime you go past the hour.You can never go backwards,if you do then you will need to remove batteries and start over,use your phone's time to set.
Mar 15, 2018 | Chime Home
Can I order a battery cover for a Westclox 70026?
You can, but Fixya does not sell Westclox battery covers.
Mar 01, 2018 | Westclox Audio Players & Recorders
How do I get it to chime on every hour
most chiming clocks only chime on the hour from 6 am to 9 pm
if it is a digital clock with a chimer the set it to 12 hour and not 24 hour
make sure that the chime has a good battery in the chime circuit and it is set to chime on the correct hour
If the statement made to you was correct then it would be chiming at night instead of the day
Oct 13, 2015 | Home
Howard Miller Christopher Quartz mantel clock chime adjustment
Try pulling the batteries out, set the clock to 5:45 then put the batteries back in. Set the time to 6:00 and count how many times it strikes. If it strikes 6 then your good. If it strikes a different number say 5, take the batteries back out, and set the clock to 4:45 then put the batteries back it, set clock to 5 and count the strike. Most quartz clocks reset their chimes to 5:00 when new batteries are installed regardless of the time shown on the face. I hope this helps. Good Luck.
Nov 30, 2013 | Howard Miller Christopher Quartz Windsor...
1988 ford taurus wagon chimes everytime i go 45+ mph and the speed light flashes... what's wrong?
You probably have the speed reminder set to 45mph. It chimes & flashes to let you know you are speeding. It will tell you how to adjust it in your owners manual. If you don't like it set it high eg: 100mph. then it won't happen.
Jun 02, 2012 | 1988 Ford Taurus
I had to put a new battery in my remote that I use to unlock the doors on my 2002 xtype Jaguar. Since changing the battery I can not get it to operate. How do I reset it?
http://www.bluejag.co.uk/X-Type-keyfob-reprogramming.php
copy/pasted from the above link..
"Programming or pairing a new remote Keyfob for the X Type is a very simple job that will cost a substantial amount if it is done by Jaguar. It's annoying but this may need to be done if your Keyfob battery has been allowed to go flat, or the car battery has been removed for any length of time.
Follow these steps exactly and you should have no problems, pairing old or replacement Keyfobs for your car.
1.)I would recommended that you ensure all key fobs are fitted with new batteries. ( Click here to see battery replacement guide).
2.)Get in the car and close the drivers side door.
3.)Put the key into the ignition and turn to position I.
4.)Wait 5 seconds
5.)Turn the key quickly to position II then back to I four times.
6.)You should hear a single chime.
7.)Remove the Key
8.)For each Keyfob in rapid succesion. Press any single button on the keyfob you wish to pair, you should hear a chime as each Keyfob is paired with the security system. After the chime do the next Keyfob.
9.)Check operation of each Keyfob. "
Hope it works for you!
Sep 21, 2011 | 2002 Jaguar X-Type
I have Westclox Atomic Clock, Model # 70026. I have lost the instructional manual. I only activate the alarm for 6:00 AM on Sunday, then I silence the alarm by pressing the Alarm on/off button. But...
Greetings.
According to the product manual, press the 'ALARM ON/OFF' button on the back of the clock until the bell symbol and 'Zz' disappear from the display screen. These symbols are between the hour and minute digiits, above the colon ( : ).
If you would like to see the instructions, they are in .jpg format:
Front page of instructions:
http://www.poyntsource.com/New/Pathimages/westclox%2070026%20-%20page%201.jpg
Back page of instructions:
http://www.poyntsource.com/New/Pathimages/westclox%2070026%20-%20page%202.jpg
You might want to save these images on your computer in case the webpage is no longer available.
Good luck from Detroit, MI.
Jun 12, 2011 | Vacuums
How do i set the thermo sensor 433mhz to my westclox 70034 model
Hi, First check the both channel of clock and thermometer (you can see the controler in battery insertion of thermometer and you can set up channel by pressing ch button on the clock)
Next press F/C search button until the clock find thermometer and press F/C search button again.
Oct 11, 2010 | Vacuums
51 people viewed this question
Top Westclox Audio Players & Recorders Experts
pawnpower
 Grubhead
Grubhead
ka4iup
ka4iup
Are you a Westclox Audio Player and Recorder Expert? Answer questions, earn points and help others
