Question about HP Photosmart C6280 Printer
Printer will not print
Message in lcd is "load paper tray". Paper tray is full. Paper is not feeding.
  • ishaka helen Jan 08, 2009
    queen job message
  • mpetrie4 Apr 04, 2009
    The problem is the printer will not print. Since I am unfamiliar with 02 cartridges I am wondering if I should have removed something before inserting them. The same message is given i.e. load paper when the paper tray is full!
I had the same problem and to fix it there was a blue tray I had to pull out (the tray for the photopaper). Once it was pulled out so it was about flush with grey part beside it, the printer worked again. (The photopaper tray is just above where you put the regular paper.)
Posted on Mar 26, 2009
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 26, 2009
HP Lazer 4300dtn keeps trying to print from tray 1. How can I set the default to tray 2?
Selecting which tray is used for printing
You can select how the printer pulls paper from the trays.
Understanding tray order
When the printer receives a print job, it selects the tray by trying to match the requested paper
type and size with what has been loaded in the trays. Using an "autoselect" process, it searches
all available trays for the paper that satisfies the request, starting with the bottom tray and ending
with the top tray (tray 1). The printer begins printing the job as soon as it finds the proper type/
size.
Note The "autoselect" process occurs only if no specific tray is requested for the job. If a specific tray
is requested, the job prints from the requested tray.
 If paper is loaded in tray 1 and tray 1 is set TRAY 1 TYPE=ANY and TRAY 1 SIZE=ANY on the
Paper Handling menu, the printer will always pull paper from tray 1 first. See "Customizing
tray 1 operation" on page 47 for more information.
 If the search fails, a message appears on the printer control panel display requesting that
you load the correct paper type/size. You can load that paper type/size, or you can override
the request by selecting a different type/size at the printer control panel.
 If a tray runs out of paper during a print job, the printer automatically switches to any tray that
contains the same paper type/size.
The autoselect process changes somewhat if you customize tray 1 operation (as explained in
"Customizing tray 1 operation" on page 47) or set tray 1 for manual feed (as explained in
"Manually feeding paper from tray 1" on page 49). See if this works. Good luck !
Jan 08, 2011 | Computers & Internet
Paper feed error message. spits it out fast and
Your printer has a fail safe mechanism that pushs the paper that it's processing out to prevent any other jams during the printing process. Your rollers must have something jamming it's movement during printing. You will need to open the printer through the panels on the back, front, and side to ensure that you see the rollers and remove any paper or debrise blocking hitched on the rollers or in the printer. You may also want to ensure that the holders on the sides of the paper tray where the paper comes in are lined up correctly. Also, make sure not to pack the paper tray to capacity. Only use the tray half full.
Nov 29, 2009 | HP Designjet 70 InkJet Printer
It won't print - says manual feed - load paper tray. Its a brand new printer (Brother HL-4040CDN) and the paper tray is full
The printer has an "alternate" feed, i.e., for envelopes and/or for special paper.
Open the door to access that "manual" tray, take some paper from the "normal" tray, and insert the paper into the "manual" tray.
Or, on the printer's controls, set the "standard" feed, rather than the "manual" feed, and press PRINT.
Nov 11, 2009 | Brother HL 1440 Laser Printer
Dell 3000cn keep getting load mpf when i try to print but there is paper in the tray. how do I get it to recognize the paper. I've changed nothing on the computer but this just started to happen! please...
I have a Dell 3010n myself, and a few times I did run into that "Load MPF" issue.
1.) Before printing a document, please check and see the properties. i.e. Kind/type of paper, which tray, or if printing envelopes or any other document than a regular 8 x11 paper. Putting all the tray and paper type selection on "Auto" can be very helpful.
2.) On the printer itself, there is a menu button where you can configure the type of paper, i.e. regular 20 llb. copy/print paper, glossy photopaper, thicker paper - after you place a fresh load on the paper tray and slide it in, usually it will ask you which type of paper you just loaded. Make sure it is the same settings as the document that you are trying to print: i.e. if document settings on computer was set to print on photopaper and you have regular paper on the tray, the printer will do a "Load MPF".
The paper sensor on it is amazingly (for a Dell, that is) sensitive and it can differentiate across a lot of paper types/thickness. If you have several computers and user across a network, and there are several paper-type settings done on the printer itself, this "Load MPF" issue will present itself more often.
In my case, it's simply because the person who recently changed the paper-type to glossy cover paper from some user who previously printed to a transparency forgot to revert MPF/Tray 1 to regular copy/print paper. Most cases, the printer setting on the PC has been left to print on to a transparency by default, so even if I stack the tray with copy paper to the hilt, it still will do "Load MPF".
Jul 25, 2009 | Dell 3010cn Laser Printer
Mp780 - Paper attempts to feed and fails Message: Load paper
Your paper feed source is wrong .Go to the printers control panel and change the feed source.
If all you do is 8.5X11 you can go into the maintenance tab and choose it to automatically change paper trays by selectin auto continuous feed.Make sure paper is in both trays of the same type and size.You will hear the printer try and grab the paper three times then it will automatically switch to the next tray.
Jun 10, 2009 | Canon PIXMA MP780 All-In-One InkJet...
I have an Easy Share printer dock series 3 that has paper loaded
To prevent misfeeds and to make sure your pictures look their best, we recommend that you keep the feed roller clean. IMPORTANT: Unplug the power before cleaning the feed rollers.
  1. Unplug the AC power cord from the power outlet.
  2. Remove the paper tray from the printer, and leave the paper tray door open. IMPORTANT: Do not use cotton or cotton swabs to clean the feed roller.
  3. Lightly moisten a lint-free cloth with water.
  4. Use the moistened cloth to gently wipe clean the surface of the feed roller. Advance the feed roller with your thumb as necessary, and continue cleaning.
  5. Let the feed roller dry fully before plugging the AC power cord back into the power outlet.
  6. Insert the paper tray into the printer, then press the Print button to resume printing.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 26, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
Microsoft Word displays the following message on the screen: ?Printer out of paper.?
  • The paper trays are empty or overloaded.The paper is curledThe print side, or shiny side, of the paper is not loaded in the input tray face down.The paper might not be engaged with the feed rollers.The paper-width guide is pressed against the paper stack too tightly.The paper tray is not completely inserted into the product.The paper settings in the print driver do not match the paper loaded in the paper tray.The rubber paper-feed rollers are coated with dust.
  • Check the media and print settings
  • Clean the rollers
  • try this. have a nice day.
    Apr 30, 2009 | HP LaserJet 1320 Printer
    Trying to print but it ask me to load paper or form feed. also got a bypass tray message.
    Sound like the computer printer preferences "paper source" is set to bypass if set to "auto select" select the tray you want. Also make sure type of paper matches what is in printer.
    -Carl
    Apr 23, 2009 | Ricoh Aficio CL3500N Laser Printer
    "Out of paper" error message
    i would try clening the paper feed tires and roller and if that dose not work i woudl replace them.also pull the paper tray out adn look in top of the printer where the paper feeds out of the tray to see if the is a peice paper is blocking the sensor that reads that the printer has paper.
    Apr 03, 2008 | HP Photosmart 3210 Printer
    Paper not feeding
    Is this a top feed - that is paper loaded on top at the back bottom feed from a tray underneath? Top feed take one sheet of paper and gently push it down whilst the printer is trying to grab it. Tray feed - take tray out make sure no paper fragments are in the tracks and find a nail board and gently abrade the pick up rollers.
    May 13, 2007 | Brother MFC-620CN All-In-One InkJet...
    HP Photosmart C6280 Printer Logo
    425 people viewed this question
    Seeker5211
    Seeker5211
