Question about Refrigerators
Keypad is locked don't know how to unlock so I can turn temp
  • 5 Answers
Try going to appliancejunk.com, they have alot of service manuals.
Posted on Nov 04, 2012
I can't unlock my vteck 15300 dect6.0 cordless pH handset help
I guess you mean the Keypad Lock/Unlock!
You can turn on the keypad lock of a handset.
In idle mode, press * button and then LOCK to turn on the keypad lock. "PRESS UNLOCK TO USE KEYS" is displayed on the LCD.
In keypad lock mode, press UNLOCK to turn off the keypad lock.
Aug 27, 2016 | Lands Phones
Tip
How to lock a Samsung Intensity cell phone
Unlike flip phones, cell phones like the Samsung Intensity are subject to accidental keypad-pressing and dialing when they are in your pocket, purse, or even a holster. To avoid unintentionally using up voice or data minutes, you can lock your phone and temporarily disable the keypad.
There are two ways to lock a Samsung Intensity - the standard keypad lock and the security lock.
- To use the standard lock:
You can lock your phone at any time from the main screen by holding down the "0" key for about two seconds. The keypad will immediately lock, and you won't be able to use any functions or make any calls (except for calling the local emergency number). To unlock the phone, press the right option button (in the upper right corner of the keypad, next to the End button) followed by the Menu or OK button.
You can also set up Auto Key Lock, which will automatically lock your keypad after the backlight turns off. The Auto Key Lock setting can be found in the menu under Settings & Tools > Phone Settings > Auto Key Lock.
- To use the security lock:
The security lock also prevents your keypad from being used, but it requires a code to be entered in order to unlock the phone. To enable the security lock, go into the main menu and select Settings & Tools > Phone Settings > Security > Lock Phone Now. (You'll need to know your phone's security code in order to access this setting -- by default it is typically the last four digits of your phone number.)
To unlock the phone, press the right option button and then enter your phone's security code, followed by the OK button.
You can set your phone to go into security lock mode as soon as you turn it on by enabling Phone Lock Setting under the Security menu. Every time you turn your phone on, you'll need to enter the security code in order to unlock it. However, once you unlock it, it will remain unlocked until you either manually lock it or turn it off and then back on.
on Mar 04, 2011 | Samsung SCH-U450 Cell Phone
Don't know how to set key pad lock
Before locking the keypad first remember if the keypad lock is assigned with a security code.
Default value of the security code is normally 0000.
1. To lock the keypad first press the option key, then select the LOCK KEYPAD.
2. To unlock the keypad press the option key then press the "C" button.
You can check more lock/unlock optoons in the users manual, downloadable from this link. Read page 63 and on.
http://dl-www.sonyericsson.com/cws/download/1/150/669/1192984731/J230i__UG_R1a_EN.pdf
Sep 04, 2011 | Sony Ericsson J230i Cellular Phone
My keypad is locked and I don't know how to unlock it. Its a Scandick e270
There's a slide switch on the top of the unit, near the headphone jack. Slide it to cover the orange to unlock the unit.
Aug 24, 2011 | Audio Players & Recorders
New battery has been placed in car and passlock system will not deactivate. The lock/unlock keypad system is no longer working, is there an alternative way to unlock the system?
Lock the car, unlock it with the key . turn the ignition on (don't start it) leave it for ten minutes, turn it off for five seconds , start the car.
Aug 22, 2011 | 2006 Chevrolet Equinox
My nokia 1100 keypad locked i dont know what is the keypad code plz send me the format of opining my keypad
keypad code is also connected on security code,to remove or retrieve your code,please follow this link and it will help you step by step way of unlocking your phone code,nothing will be erased so don't be worried.
SECURITY CODE TIP
or you can give me your imei number and i'll be the one to provide your security code.
Good Luck...
Aug 16, 2011 | Nokia 1100
My Luxpro psp511 ca is locked and I don't know how
TO LOCK THE KEYPAD: Start with the System Mode switch in either the
HEAT or COOL positions, and the Set Slide switch in the RUN position.
Perform a single press of each button, in the following sequence: NEXT,
NEXT, NEXT, HOLD.
TO UNLOCK THE KEYPAD: Start with the System Mode switch in either
the HEAT or COOL positions, and the Set Slide switch in the RUN position.
NEXT, NEXT, HOLD. The padlock should no longer be present, with the
thermostat now unlocked. If the padlock is still on the screen, please try
to enter the 4-button sequence again.
Jun 01, 2011 | Heating & Cooling
I can't used my nokia 5800 (show) from korea it can't be unlocked
ineed country code for mobile xpress music 5800 in pakistan
Oct 09, 2010 | Nokia 5800 XpressMusic Smartphone
IDECT cordless phone, on small round base
I have verge 500 twin, the handset just stopped responding to the base and i have not found the manual to check trobleshooting.
Feb 21, 2008 | Uniden Cordless Phone
Refrigerators Logo
71 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
